Sharp TV Network Remote Plugin - Introduction & Installation
Fri Nov 01, 2013 12:35 pm
RogueProeliator offline
Introduction
This plugin allows Indigo to control Sharp AQUOS televisions via their network (IP) control protocol. Sharp's protocol is very robust and, as a result, this plugin is able to both read and set nearly every aspect of the television - from volume/channel through configurations such as picture mode, aspect ratio, etc.
Links
Plugin Store Entry | Full Documentation | GitHub Repo | Indigo 6 Plugin
Tue Nov 19, 2013 9:49 pm
Re: Sharp TV Network Remote Plugin - Introduction & Installa
v1.0.3 Released
A new version, v1.0.3, of the Sharp TV Network Remote Plugin has been released. This is a minor update:
  • Created better state detection for disconnected devices and error states
Sun Dec 08, 2013 9:06 pm
v1.0.4 Released
Sharp TV Network Remote has been upgraded to v1.0.4, with the following changes:
  • Improved format and sorting of device configuration and action dialogs/menus to make them easier to use
Sat Jan 25, 2014 11:38 pm
v1.1.6 Released
Sharp TV Network Remote has been upgraded to v1.1.6, with the following changes:
  • Improved error handling for invalid and error responses from the television
  • Added support for LC-60C6500U (Costo/Sam's version of LC-60LE650)
Thu Jul 03, 2014 2:42 pm
v1.2.9 Released
Sharp TV Network Remote has been upgraded to v1.2.9, with the following changes:
  • Improved error handling to suppress a couple of unnecessary errors from hitting the Indigo log
  • Added support to auto-reconnect to the television whenever a connection is lost (e.g. power outage or network interruption). Previously the plugin would attempt to reconnect whenever the next command was issued, but this prevented status updates in the interim.
Tue Sep 02, 2014 8:27 pm
v1.3.9 Released
Sharp TV Network Remote has been upgraded to v1.3.9, with the following changes:
  • Added additional A/V Modes available to enable those on newer televisions
Sun Mar 08, 2015 6:41 pm
v1.3.14 Released
Sharp TV Network Remote has been upgraded to v1.3.14, with the following changes:
  • Faster reaction to multiple key presses (such as multiple volume up/down presses
  • Added the ability to send any arbitrary command for debugging / testing purposes
  • Added event that fires whenever the plugin finds an update available
Thu Oct 08, 2015 7:34 am
v1.4.18 Released
Sharp TV Network Remote has been upgraded to v1.4.18, with the following changes:
  • Better debugging and logging messages to the Indigo Log
  • Added ability to turn off status polling or disable status updates completely
  • Unicode support
Tue Feb 09, 2016 4:07 pm
v1.4.19 Released
Sharp TV Network Remote has been upgraded to v1.4.19, with the following minor changes:
  • Fixes bug that caused plugin to fail to load if the download was renamed prior to installation
Sat Nov 12, 2016 11:29 pm
v2.0.0 Released
Sharp TV Network Remote has been upgraded to v2.0.0 and may be downloaded here. The following changes are included:
  • Changed Status column / display to show On/Off (Power) state rather than connection status
  • Indigo 7 is now required for this and all future plugin versions
Sat Nov 14, 2020 7:47 pm
v2.1.0 Released
  • Brought plugin up to Indigo 7.1+ standards
  • Updated version check to avoid duplicate calls
v2.1.1 Released
  • Updated to Indigo 7.3+ standards
  • Unified plugin UI across all RogueProeliator plugins
  • Now requires Indigo 7.3+ (old versions will remain available for previous versions)
