Niles Audio Initial Feedback
Sun Jan 05, 2014 2:42 pm
RogueProeliator offline
Re: Niles Audio Initial Feedback
:: blank stare ::
Is it disabling the plugin or can you get to the configuration dialog still? If so, please set the debug to on and Full level and then restart the plugin.
That error doesn't make any sense to me - it is coming from with the Indigo code which, I am guessing, means we have a setting or configuration or something that is causing it. I've been running on v1.0.4 without any issues so it SHOULDN'T be in the configuration (famous last words, though...)
Let me know if you can't get in to set it to full debug level...
Sun Jan 05, 2014 2:56 pm
Sanderkoers offline
Stopped plugin "Niles Audio Receiver Plugin 1.0.4"
Starting plugin "Niles Audio Receiver Plugin 1.0.4" (pid 462)
Niles Audio Receiver Plugin Debug RPFrameworkConfig.xml not found, skipping processing
Started plugin "Niles Audio Receiver Plugin 1.0.4"
Niles Audio Receiver Plugin Debug Version check initiated
Niles Audio Receiver Plugin Debug Version File Url:https://www.rogueproeliator.com/IndigoPlugins/NilesAudioReceiver/NilesAudioReceiverVersionInfo.html
Niles Audio Receiver Plugin Your plugin version, v1.0.4, is current.
Niles Audio Receiver Plugin Debug Entering deviceStartComm for AUDIO NILES ZR4; ID=459594108
Niles Audio Receiver Plugin Error exception in deviceStartComm(AUDIO NILES ZR4)
Niles Audio Receiver Plugin Debug Entering deviceStartComm for AUDIO Z1; ID=820184553
Niles Audio Receiver Plugin Error exception in deviceStartComm(AUDIO Z1)
Niles Audio Receiver Plugin Debug Entering deviceStartComm for AUDIO Z2; ID=120498734
Niles Audio Receiver Plugin Error exception in deviceStartComm(AUDIO Z2)
Niles Audio Receiver Plugin Debug Entering deviceStartComm for AUDIO Z3; ID=1743982641
Niles Audio Receiver Plugin Error exception in deviceStartComm(AUDIO Z3)
Niles Audio Receiver Plugin Debug Entering deviceStartComm for AUDIO Z4-KEUKEN; ID=281421761
Niles Audio Receiver Plugin Error exception in deviceStartComm(AUDIO Z4-KEUKEN)
Sun Jan 05, 2014 3:04 pm
Sanderkoers offline
i did a reinstall and works now, exept when a change the baud rate (with text editor?) indigo can not find the config file anymore.
Sanderkoers offline
this is with the baud rate on 38400:
Niles Audio Receiver Plugin Debug Read device state config... isConnected: 'isConnected'; connectionState: 'connectionState'
Niles Audio Receiver Plugin Debug Establishing connection to /dev/cu.KeySerial1
Niles Audio Receiver Plugin Debug Exiting deviceStartComm for AUDIO NILES ZR4
Niles Audio Receiver Plugin Debug Device is child object, attempting to find parent
Niles Audio Receiver Plugin Debug Found parent ID of device 820184553: 459594108
Niles Audio Receiver Plugin Debug Parent object found, adding this child device now
Niles Audio Receiver Plugin Debug Adding child device 820184553 to 459594108
Niles Audio Receiver Plugin Debug Created device key:1
Niles Audio Receiver Plugin Debug Exiting deviceStartComm for AUDIO Z1
Niles Audio Receiver Plugin Debug Found parent ID of device 120498734: 459594108
Niles Audio Receiver Plugin Debug Adding child device 120498734 to 459594108
Niles Audio Receiver Plugin Debug Created device key:2
Niles Audio Receiver Plugin Debug Exiting deviceStartComm for AUDIO Z2
Niles Audio Receiver Plugin Debug Found parent ID of device 1743982641: 459594108
Niles Audio Receiver Plugin Debug Adding child device 1743982641 to 459594108
Niles Audio Receiver Plugin Debug Created device key:3
Niles Audio Receiver Plugin Debug Exiting deviceStartComm for AUDIO Z3
Niles Audio Receiver Plugin Debug Found parent ID of device 281421761: 459594108
Niles Audio Receiver Plugin Debug Adding child device 281421761 to 459594108
Niles Audio Receiver Plugin Debug Created device key:4
Niles Audio Receiver Plugin Debug Exiting deviceStartComm for AUDIO Z4-KEUKEN
Niles Audio Receiver Plugin Debug Connection established
Niles Audio Receiver Plugin Debug Returning default GUIConfigValue for nilesAudioReceiver:telnetConnectionEOLString
Niles Audio Receiver Plugin Debug Returning default GUIConfigValue for nilesAudioReceiver:telnetConnectionStringEncoding
Niles Audio Receiver Plugin Debug Returning default GUIConfigValue for nilesAudioReceiver:telnetConnectionRequiresLoginProperty
Niles Audio Receiver Plugin Debug Command queue has 1 command(s) waiting
Niles Audio Receiver Plugin Debug Create connection command de-queued
Niles Audio Receiver Plugin Debug Executing full status update request...
Niles Audio Receiver Plugin Debug Command queue has 8 command(s) waiting
Niles Audio Receiver Plugin Debug Writing activate zone request for zone 1
Niles Audio Receiver Plugin Debug Post Command Pause: 0.1
Niles Audio Receiver Plugin Debug Command queue has 7 command(s) waiting
Sun Jan 05, 2014 3:18 pm
Sanderkoers offline
Seems i got it working now !!!
did a full re-install, and set the baud rate to 9600 !!!
thanks for al your support so far !
Sun Jan 05, 2014 3:32 pm
That is likely causing your issue, though for the life of me I don't know what it could not find that file...
OK, just read your update... It looked like it connected at the 38400 baud rate -- it didn't happen to work at all there when you executed the action, huh? The only thing that I can think of is maybe editing changing permissions on the file - just using TextEdit or something else to edit?
I could try making you a build with 9600 as the default to try it...
Sun Jan 05, 2014 3:33 pm
Oh, great to hear! Let me know if you find anything else amiss with the ZR-4 and I'll see about incorporating it into the plugin; I'm going to try my ZR-6 at 9600 baud and see what the does... if no issues I'll just default it to that for all.
Sun Jan 05, 2014 3:43 pm
Sanderkoers offline
Thanks, it looks like i can control everything, exempt setting the radio/tuner freq. maybe that is different in ZR6 ??
i really had to set it to 9600 to get it working.
Sun Jan 05, 2014 3:46 pm
What output do you get in the log when executing the radio commands with debug on Full (setting it to Full will show all of the communications) back and forth?
Sun Jan 05, 2014 4:20 pm
Sanderkoers offline
Action Group AUDIO RADIO to Q-Music = 99.9
Niles Audio Receiver Plugin Debug Sending command: src,11,099.9
Niles Audio Receiver Plugin Debug Write command completed.
Niles Audio Receiver Plugin Debug Received: rsrc,11,FAIL,20
Sun Jan 05, 2014 4:22 pm
Sanderkoers offline
Adam,
i used this code list before http://www.nilesaudio.com/techsupport/Z ... 0Codes.pdf
but i don't see a write freq.
Sun Jan 05, 2014 4:25 pm
Sanderkoers offline
Sanderkoers wrote:
Adam,
sorry, it is there, but seems that you have to select a active zone first
Mon Jan 06, 2014 12:21 pm
doug@dynamic.com offline
Mike -
Can you supply the hacks to get the plug-in working with ICS. I am going to spend some time looking at this.
Doug
