Which Niles device will be supported ?
Sat Aug 24, 2013 8:39 am
asw24b offline
Thanks !
Sat Aug 24, 2013 8:46 pm
RogueProeliator offline
Re: Which Niles device will be supported ?
I have written the plugin against the Niles Audio ZR-6 Multizone System with both a master and a slave receiver installed; I believe that the command protocol should allow it to work with the ZR-4 in the exact same manner, but I don't have one to test.
Adam
Sun Aug 25, 2013 9:21 am
asw24b offline
Adam
Cool !
I have an ICS, and the command set is very similar....
Sun Aug 25, 2013 7:28 pm
I am not familiar with that one... but I assume that this is it: http://www.intellicontrol.com/ICS/index.php? If so, I think that the plugin should work fairly out-of-the-box. I can make some additional commands available that are ICS specific as it looks like it supports a few more than the ZR-6.
Let me get the plugin out the door and then we can add those additional commands if you are interested. I am very close to having this finished but need to tweak a couple of out-lying cases, such as when the Niles Audio device loses power; the plugin throws errors with the bootup status information sent. But the actual control itself has been pretty solid thus far, so hopefully won't be long...
Adam
Sun Oct 20, 2013 9:02 am
asw24b offline
Adam
Any chance I could try a version of whatever you have ?
Thanks !
Mike
Mon Oct 21, 2013 9:11 am
Yup, this is still coming but have been working to get a consistent framework for other plugins before getting this polished up; it has some limitations right now not being on that framework, but welcome to try if you want. Sending you a PM with information.
Adam
