Roku 1.5.18 Won't Load
Sat Dec 19, 2015 9:03 pm
ckeyes888 offline
Just upgraded to v 1.5.18 and it doesn't seem to want to load.
Dec 19, 2015 7:59 pm
  Reloading plugin "Roku Network Remote Plugin 1.5.18"
  Starting plugin "Roku Network Remote Plugin 1.5.18" (pid 67197)
  Roku Network Remote Plugin ErrorError in plugin execution InitializeMain:
  File "plugin.py", line 44, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Roku Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/__init__.py", line 17, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Roku Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkRESTfulDevice.py", line 64, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Roku Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/requests/__init__.py", line 53, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Roku Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/requests/packages/__init__.py", line 3, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Roku Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/requests/packages/urllib3/__init__.py", line 10, in <module>
<type 'exceptions.SyntaxError'>: invalid syntax (connectionpool.py, line 342)
I'm still running Indigo 6.0.20 if that matters.
Any help appreciated!
Carl
Sat Dec 19, 2015 10:02 pm
RogueProeliator offline
Re: Roku 1.5.18 Won't Load
So, based on that error, it seems as if I need to update the minimum Indigo requirement to v6.1... the plugin itself isn't using any v6.1+ specific commands, but apparently the supporting libraries that I am using require the later Python version provided by it. Sorry, I didn't realize that was the case or I would have updated it to not to allow installation in the first place. I would suggest you roll back to the previous version OR update to v6.1. Any particular reason you haven't updated to v6.1. I know many other plugins have de facto dropped support for releases previous to v6.1 due to other support libraries.
Adam
Sat Dec 19, 2015 11:53 pm
ckeyes888 offline
Dropping back to the previous version got it working again.
Still running Indigo on an old mini with 10.5.8. Upgrades are always a disaster for me,
especially in this case where I use a lot of Applescripts, an Apple USB modem etc. that, from what
I've been hearing, will all break at 10.7 and above.
I know it's necessary but the thought of rebuilding virtually my entire system and likely ending up
with less function isn't too appealing.
Carl
Sun Dec 20, 2015 10:00 am
There aren't too many new features that have been added recently for normal operation on the Roku plugin as the API available has not changed. A few little tweaks and helpers for debugging and ever so slight performance increases. Nothing to worry about missing in order to stay where you are version-wise.
I don't have a copy of one that I know for sure works at your level; would you mind zipping-up and emailing me your copy? I'll post it up as a separate download and increase the minimum version on the current one so that others don't get into the same situation (and there will be a working version available if someone pre-v6.1 needs to rebuild or re-download). You can email it to adam.d.ashe at gmail.com if you don't mind.
Thanks Carl, and sorry for that trouble!
Adam
Sun Dec 20, 2015 8:58 pm
ckeyes888 offline
Absolutely no trouble at all. I'm a huge fan of your work and very much appreciate it!
I'll pm that ASAP.
Carl
