Safe update checks FTW!!
Sat Mar 03, 2018 4:42 pm
I don't often single out developers because you guys are all awesome, but I'm going to make an exception. Adam gets a big gold star for implementing update checks that handle adversity (in this case, GitHub requiring TLS1.0) very well. Today, this is what I see in my logs:
   TiVo Network Remote Plugin         Checking for updates...
   TiVo Network Remote Plugin Warning Error checking for new plugin version.
Just once with no muss and minimal fuss. Mind you, I'm running a fairly old version of the plugin (from mid last year I think) so it isn't after he's adapted to the current issue.
Congratulations Adam, here's your gold star: Image
Sun Mar 04, 2018 11:23 pm
RogueProeliator offline
Re: Safe update checks FTW!!
ROFL, thanks Jay! :-) I've actually been trying to find some time to take out all those update checks -- it is only in one base class, so as often is the case it isn't the coding but the time to test holding me back. But my plugins SHOULD all handle it that way so it hasn't been a critical priority... (BTW, you can disable the check in the settings or you will get those two lines once per day I believe).
Adam
Thu Mar 29, 2018 11:02 am
nicb offline
I think this GitHub TLS change is also preventing me from creating new triggers
Screen Shot 2018-03-29 at 12.59.58.png (43.44 KiB) Viewed 3409 times
Thu Mar 29, 2018 5:07 pm
Colorado4Wheeler offline
That's a clever way to let a user know there's an update.
Fri Mar 30, 2018 9:30 am
Correct, that Event that fires depends upon the GitHub integration so won't work any longer... It is going away in the next plugin release.
In a nutshell, the GitHub change has affected pretty much everyone's update notifications no matter how they are materialized for you... but Jay mentioned in one of the announcements that they were aware of this and would bring some form of update or notification or what not to the Plugin Store eventually. For now, I guess just check the message boards is all I can say. I haven't always posted of new minor updates but will do so now when they are published to the store.
Adam
Fri Mar 30, 2018 9:59 am
RogueProeliator wrote:
Jay mentioned in one of the announcements that they were aware of this and would bring some form of update or notification or what not to the Plugin Store eventually,
We will be building in update checks into a future release so that plugin developers don't need to do anything special in their plugins. In the meantime, we've published an API that developers can implement, in place of the older library they were using, to do update checks against the Plugin Store.
Fri Mar 30, 2018 10:31 am
Doh, I think I missed that office API, thanks for the pointer... last I remember was the discussion of others creating a few things. Thanks!
Adam
