- Posted on
Wed Nov 18, 2015 12:19 pm
dduff617
offline
you're correct that it does look like plugin got mis-named automatically during download process with "-2" on the end.
within indigo, i disabled the plugin, then went to the plugins (disabled) folder and located the plugin, deleted it. downloaded new plugin, saw that downloaded file was correctly named, double-clicked on it to install. but at that point, it seems that indigo took over and re-installed and enabled the plugin again but still under its former name (with the "-2" on it again).
so the next attempt, i disabled the plugin, stopped indigo server, then manually renamed the plugin (removing "-2" from the name), restarted the server and re-enabled the plugin and that finally seemed to fix it.
one other minor hitch: in the settings for a new tivo network remote control device, there's a pull-down menu of devices found. my roamio has two separate IP addresses. i believe one is for the built-in tivo stream device and one is for the tivo itself. the IP that appears in the pull-down menu is the one for the stream. trying to use the plugin with that address failed. if i manually enter the other address, the plugin then seems to work.
so things seem to be working now - at least i'm not getting error messages. more exhaustive testing will happen this evening when i can actually see the TiVo screen and try some things out.
thanks!
