TiVo Network Remote - Control Page Images
Posted: Sun Sep 15, 2013 9:34 pm
TiVo Network Remote Control Page Images
The Introduction & Installation Thread contains sample control page element that might be used to create a TiVo remote representation on an Indigo control page. The graphics necessary to duplicate that representation are found in the sample control images download. This post will show you how to layout those elements to properly duplicate the look.
The Overall Elements
The images are broken up into 4 distinct sections of control - TiVo Bar, Directional Bar, Play Control Bar and Number Pad. Each of these "bars" contain a set of graphics that must be placed together; there is no reason that you have to stack the bars, but if you do so it will look similar to the left control below:
You will need to copy all of the images that you wish to use into the IndigoWebServer/images/controls/static directory. Unless otherwise noted, it is expected that the buttons will execute a "Send network-based IR command to TiVo" or "Send network-based teleport command" as its server action.
TiVo Bar
This bar is designed to be the top-level TiVo control, to handle the main TiVo button, Channel Up, Channel Down and have space for any additional controls. Suggestions include TV volume up/down (images 4 & 7 below) and mute (3). To create this bar, layout the images prefixed with TiVo-Control-Bar on your control page as per the diagram below:
Directional Bar
The Directional Bar is designed to give you navigation control over TiVo primarily when not watching a show/video. It contains the buttons designed to use the TELEPORT command to navigate straight to a particular screen as well as the standard directional pad and select buttons. To create this bar, layout the images prefixed with TiVo-Directional-Bar on your control page as per the diagram below:
Play Control Bar
The Play Control Bar is designed to give you control over the actual playing of content on the TiVo. All standard play controls are available (play/pause/stop/etc.) To create this bar, layout the images prefixed with TiVo-Play-Control-Bar on your control page as per the diagram below:
Number Pad
The Number Pad is designed to be used to enter, and navigate directly to, channels on the TiVo device. The setup for this functionality takes a bit more than the other images as it is a combination of actions:
The number pad graphics layout should be from those images prefixed with TiVo-Number-Pad and be arranged in the following format:
Conclusion
Well, that is just one man's vision... let me know if you have any questions and feel free to post your own creations that might inspire others!
TiVo Bar
Directional Bar
Play Control Bar
Number Pad
- Create a label (text) display of a device state for the channelSelector device state and add it above the number pad
- Configure each of the number images (0-9) to run a server action of Add a Digit to Channel Selector, adding the appropriate digit
- Configure the Clear Channel button to execute a server action of Clear the Channel Selector
- Configure the Go button to execute a server action of Tune to the Channel Selector's Channel
Conclusion
