Robb Smarrt 5 channel remote control
Posted: Wed Feb 21, 2024 1:41 pm
I've added a Robb Smarrt 5 channel remote control to Indigo.
More details here: https://www.robbshop.nl/robb-smarrt-5-k ... -wave-plus
Indigo info:
It has 6 sets of On/Off buttons and pressing them 1 by 1 shows this in the log:
When I try to add a trigger on this device, I can't selected these scenes. Only the battery level, any command or raw packet options are available.
Indigo info:
- Code: Select all
Z-Wave Indigo Device "Slaapkamer AB" Z-Wave Properties:
Indigo Z-Wave Version: 2023.2.0
Node ID: 128
Model: Basic Wall Controller
Model ID: 0300B301
Manufacturer: Sunricher / RGBgenie
Manufacturer ID: 0330
Protocol Version: 5.03
Application Version: 1.26
Model Definition Version: 0
Library Type: 3
Class Name: Basic Wall Controller
Class Hierarchy: 04 : 18 : 01
Command Class Base: 00
Command Versions: 20v1 5Ev1 85v1 8Ev1 70v1 5Bv1 59v1 55v1 86v1 72v1 5Av1 73v1 80v1 98v1 9Fv1 84v2 6Cv1 7Av1
Features: routing, battery, beaming, security, waking
Neighbors: 1, 4, 5, 8, 12, 15, 16, 19, 21, 22, 23, 24, 25, 26, 28, 30, 32, 33, 34, 35, 37, 38, 39, 40, 43, 51, 66, 67, 69, 72, 80, 85, 86, 100, 101, 102, 107, 108, 109, 110, 111, 127
Associations: 1:[1] 2:[] 3:[] 4:[] 5:[] 6:[]
Config Values: - none -
- Code: Select all
2024-02-20 20:45:52.384 Z-Wave received "Slaapkamer AB" scene 1 (0001)
2024-02-20 20:45:54.025 Z-Wave received "Slaapkamer AB" scene 2 (0002)
2024-02-20 20:45:55.977 Z-Wave received "Slaapkamer AB" scene 3 (0003)
2024-02-20 20:45:57.338 Z-Wave received "Slaapkamer AB" scene 4 (0004)
2024-02-20 20:45:58.619 Z-Wave received "Slaapkamer AB" scene 5 (0005)
2024-02-20 20:45:59.949 Z-Wave received "Slaapkamer AB" scene 6 (0006)
2024-02-20 20:46:00.981 Z-Wave received "Slaapkamer AB" scene 7 (0007)
2024-02-20 20:46:02.110 Z-Wave received "Slaapkamer AB" scene 8 (0008)
2024-02-20 20:46:03.946 Z-Wave received "Slaapkamer AB" scene 9 (0009)
2024-02-20 20:46:05.091 Z-Wave received "Slaapkamer AB" scene 10 (000a)
2024-02-20 20:46:07.096 Z-Wave received "Slaapkamer AB" scene 11 (000b)
2024-02-20 20:46:08.240 Z-Wave received "Slaapkamer AB" scene 12 (000c)
