Does new Zooz ZEN51 with LR designation affect INDIGO
Sat Jan 20, 2024 5:55 pm
norcoscia offline
I noticed a sale on Zooz ZEN51-LR relays but wanted to find out if the ZWAVE LR (Long Range) update to the device affects or breaks the existing indigo integration with the new ZEN51 LR, in other words, will the new ZEN51 LR work but just not support LR.
Support for the original ZEN51 within INDIGO was added in release 2022.2 but INDIGO documentation does not mention the LR designation.
I’m trying to come up to speed on the new ZWAVE LR capability but the sale will likely end before I can fully understand the ramifications that the LR could have.
From what I have read ZWAVE and ZWAVE LR work across the same network and in order for LR to work both the device and the ZWAVE hub must be updated for LR. I know the INDIGO hub does not support LR (at least I think it doesn’t) but I wanted to check in to see if the LR update to the ZEN51 breaks any functionality with INDIGO as it stands now.
ZWAVE LR seems to be a huge update —from max node count (updated to 4000 vice 232 for original ZWAVE) and the range for a working LR network is a mile.
If anyone knows of any issues please let me know and if there is a section on this forum for ZWAVE LR please let me know so I can come up to speed.
Thanks in advance…
_______
Norm
Tue Jan 23, 2024 5:28 pm
Re: Does new Zooz ZEN51 with LR designation affect INDIGO
The LR modules are all supposed to be backwards compatible with the legacy Z-Wave network, so in theory the new ZEN51-LR should work with Indigo. That said, we won't know for sure until someone tries it and we haven't had any reports yet that is the case.
You are correct that Indigo doesn't support the LR protocol. Adding support for it is a large feature since it requires S2 encryption support.
Tue Jan 23, 2024 7:11 pm
norcoscia offline
Thanks - I did order a few so I will post once I hook one up - either, if it works OK or if it does not — so others will know….
_______
Norm
Tue Jan 23, 2024 9:51 pm
jltnol offline
and not that this is the same device, but I added a ZEN76 800LR a few weeks ago and it went smoothly.
Wed Jan 24, 2024 5:44 am
norcoscia offline
Thanks - I hope it will be the same case for the ZEN51 - I have my fingers crossed…
_______
Norm
Fri Jan 26, 2024 9:16 pm
norcoscia offline
Got my shipment from The smartest house but they sent me the wrong devices so I doubt I will be installing these in case anyone was waiting to see how it works with Indigo….
_______
Norm
Sun Jan 28, 2024 12:36 pm
7rdr7 offline
I installed the ZEN52, which is the two relay version, and it works fine with Indigo.
Mon Jan 29, 2024 11:38 am
Excellent, thanks for the report.
Does it identify itself as a ZEN51? Just want to confirm that.
Mon Jan 29, 2024 11:42 am
7rdr7 offline
I'm using the ZEN52, which is the dual relay version of the ZEN51. Indigo configuration below:
Indigo Z-Wave Version: 2023.2.0
Node ID: 52
Model: Relay Switch
Model ID: 09040202
Manufacturer: Zooz
Manufacturer ID: 027A
Protocol Version: 7.15
Application Version: 1.50
Model Definition Version: 0
Library Type: 3
Class Name: Relay Switch
Class Hierarchy: 04 : 10 : 00
Command Class Base: 25
Command Versions: 20v1 25v1 5Ev1 55v1 9Fv1 6Cv1 70v1 85v1 59v1 8Ev1 86v1 72v1 5Av1 73v1 7Av1 60v4 22v1 5Bv1 87v1
Multi-Endpoint Types: 1:(10 : 00), 2:(10 : 00)
Multi-Endpoint Classes: 1:[5E 25 85 59 8E 6C 9F], 2:[5E 25 85 59 8E 6C 9F]
Features: routing, beaming
Neighbors: 2, 3, 4, 5, 6, 7, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 26, 28, 30, 33, 34, 37, 43, 47, 48, 49, 51, 55, 65, 73, 76, 90, 96, 108, 118, 125, 126, 134, 135, 136, 148, 156, 157, 158, 159, 160, 161, 162, 163, 165, 166, 177, 178, 179, 184, 185, 186, 188, 189, 190, 212, 217, 221, 222, 223, 224, 226, 228, 229, 230, 231, 232
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
Mon Jan 29, 2024 2:49 pm
Ok, so to clarify, the ZEN52LR is the actual model you tried and it works correctly (including controlling each contact individually)?
While it's not definitive proof that the ZEN51LR works, it's about as close as you can get!
Mon Jan 29, 2024 3:03 pm
7rdr7 offline
This is it, Zooz 700 Series Z-Wave Long Range Double Relay ZEN52
https://a.co/d/9lpGMiK
Mon Jan 29, 2024 3:54 pm
norcoscia offline
I ended up installing ZEN 71 on/off switches (which had LR designations) and they work from within Indigo - no problems.
_______
Norm
