Fibaro fgd212 dimmer not dimming
Wed Nov 22, 2023 7:32 pm
peszko offline
I have two Fibaro fgd212 dimmers. One is dimming properly, but the other as soon as I dim it, it comes back to 100. I don't have any triggers on it and I see in the log that dimming command was sent, then it reports 100 right after. As far as I can see both have the same settings. Any ideas?
Z-Wave sent "L2_LR_Pot2_LT_Z" set brightness to 44
Z-Wave received "L2_LR_Pot2_LT_Z" status update brightness 100
The settings of the dimmer.
Screenshot 2023-11-22 at 8.30.35 PM.png (300.59 KiB) Viewed 936 times
Thu Nov 30, 2023 10:17 am
peszko offline
Re: Fibaro fgd212 dimmer not dimming
I think I figured out why it isn't dimming. This module has a system that identifies if the load is dimmable and if it thinks it's not, it acts as a switch. In my case, the lights that I have are old and were not dimmable even though the old Insteon modules were able to dim them somewhat (very uneven). When connected to the new dimmable leds it works correctly.
