NEO Smart Plug
Mon Jul 31, 2023 7:09 pm
JonathanKing offline
NEO Smart Plug
Hi all,
I want to buy a smart plug that will allow me to monitor a sump pump to know when it turns on. This looks great on Amazon, but I cannot tell if Indigo supports it, and if so, what features are supported. Can I send myself an email any time the amperage increases over a threshold?
https://www.amazon.com/NEO-Z-Wave-Monit ... C93&sr=8-8
-Jonathan
Tue Aug 01, 2023 9:26 am
Re: NEO Smart Plug
Not sure. That device is actually manufactured by a Chinese company and several vendors offer it. I have a slightly older version (same dimensions) and it does show energy information, so it seems likely this one would work as well. If it doesn't, we can add a definition for it pretty quickly I'd expect.
Tue Aug 01, 2023 9:55 am
Re: NEO Smart Plug
Never mind, it is supported, just look at the plugin module section for appliance devices: https://www.indigodomo.com/devices/category/23/
You can filter by manufacturer using the popup on the top left so it's easier to see.
Tue Aug 01, 2023 8:51 pm
Re: NEO Smart Plug
Thank you Jay. I actually had looked at the compatibility list first but totally missed it!
Tue Oct 03, 2023 8:52 pm
Re: NEO Smart Plug
I purchased the Neo, but am having trouble configuring it as I was hoping. My goal is to know whenever the sump pump connected to the Neo turns on. I have set it to update every second, but it isn't sending emails, and nothing is in the log. Would appreciate any pointers!
Indigo Z-Wave Version: 2022.2.1
Node ID: 36
Model: Power Plug (NAS-WR01ZE)
Model ID: 01001027
Manufacturer: Neo
Manufacturer ID: 0258
Protocol Version: 6.04
Application Version: 2.23
Model Definition Version: 1
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 25v1 27v1 5Ev1 98v1 9Fv1 55v1 73v1 86v1 85v1 8Ev1 59v1 72v1 5Av1 32v4 71v1 70v1 6Cv1
Features: routing, beaming, security, energyMeter, powerMeter
Neighbors: 35
Associations: 1:[1] 2:[]
Config Values: 1:1 3:1 2:0 6:1 7:1
Tue Oct 03, 2023 9:01 pm
Re: NEO Smart Plug
What isn't sending emails?
Tue Oct 03, 2023 9:33 pm
Re: NEO Smart Plug
I have a Trigger with an Action to send an email when the device state changes to current power becomes greater than 0 and another for when the Energy Usage has any change. Tomorrow I'll double-check everything (again) and make sure I didn't miss anything.
Thanks Jay.
Mon Oct 09, 2023 6:38 am
Re: NEO Smart Plug
OK, so I finally had some time to futz around on this, and the other day the plug sent me about 10 emails for the start/stop of 5 pump turn-on/off events that are Triggered by Current Power going over 0, so the email part seems to work. However, the device details still show 0 Watts used, ever, and the Action I have that is supposed to Trigger when Energy Usage increases does not occur.
I upgraded to 2023.1 today (and in a 'glutten-for-punishment' mode am also doing Sonoma on the server) and after all that settles I'm going to sit in the basement with a bucket of water and force the thing to engage and get more data to share.
-Jonathan
Users browsing this forum: No registered users and 24 guests
