Zooz ZEN77 Z-Wave Dimmer Configuration
Thu Mar 16, 2023 5:43 pm
boisy offline
I found an issue with the "Configure Dimmer Module" for the Zooz ZEN77 dimmer, notably that the ramp rate ONLY affects the brightness rate when turning on the device. It does not affect the dimness rate when turning off the device.
In addition to the "Dim ramp rate" field, there should be a "Brightness ramp rate" field. Parameter 9 controls the dimness, and parameter 27 controls the brightness as per the documentation here: https://www.support.getzooz.com/kb/arti ... -settings/
Screenshot 2023-03-16 at 6.39.59 PM.png (176.81 KiB) Viewed 544 times
Fri Mar 17, 2023 9:41 am
Re: Zooz ZEN77 Z-Wave Dimmer Configuration
From the doc:
 NOTE:  On all other previous firmware versions including 1.0, 10.0, and 10.10, this setting was used for all ramp rate control (to adjust behavior for on/off physical and Z-Wave ramp rate). The default value for this parameter used to be 1.
I really hate when vendors make fundamental changes to devices but don't update the model IDs. The code gets very messy when you have to look at model ID, firmware version, classes, and parameters that effect classes, etc. It just leads to very complex code.
We'll add this to the list. In the meantime, you'll need to adjust the device parameters yourself using the Modify Config Param menu/action.
Fri Mar 17, 2023 5:47 pm
boisy offline
Thanks Jay. I was able to make the change with the parameter as you noted.
