Greetings,
I've had a nightmare of trying to get door-window sensors working. I tried 25 times to get 2 different Wink sensors to connect, all failed with the same behavior as this Aeotec S7. I'm "pinning" my issue to the Aeotec because I've had decent success with their products in the past. (And I have a warranty.)
The units will complete the normal, 1st part of Indigo's inclusion normally and quickly. When I click Define and Sync, they fail every time with the same messages:
Mar 14, 2023 at 5:55:31 PM
Z-Wave Syncing - started for "147 - Notification Sensor"
Z-Wave Syncing - retrieved module neighbors list: 75, 79, 80, 84, 87, 90, 91, 92, 94, 95, 96, 97, 104, 105, 108, 114, 116, 117, 119, 121, 123, 144
Z-Wave Syncing - assigning return route to "147 - Notification Sensor"
Mar 14, 2023 at 5:56:19 PM
Z-Wave Error Syncing - failed to assign return route
Z-Wave Error No response from "147 - Notification Sensor". Module might be asleep, or is unreachable.
I have searched for the Syncing failed error message and found this article:
viewtopic.php?f=58&t=13155&p=100863&hilit=Search%E2%80%A6Syncing+failed+to+assign+return+route#p100863
Following those suggestions--tapping the tamper-button to keep the unit awake, I can delay the onset of failure for ...minutes. Many minutes, if I have the patience to keep tapping the button. But fail it does, every time.
This behavior is not unique to these Aeotecs, the Wink sensors did the same. Except for one, I somehow got lucky (or it was defective in the right way) and succeeded in getting a complete sync. (That Wink sensor has been operating without pause for 3 days.)
The thread I linked to mentions an option to not request return routes on sync, but I can't find that option anywhere. Is there some way to trick it into syncing, then later do an Optimization and get the return route then? Other tricks?
Thanks in advance for your wisdom and willingness to share it.
