Fibaro Walli Outlet type E support (FGWOE-011)
Sat Feb 04, 2023 5:42 am
slackman1 offline
When adding an 'Walli Outlet type E' (Fibaro type FGWOE-011) to Indigo, it looks like it is incorrectly recognized as a 'Fibaro System - 010F, Walli Double Switch (FGWDSEU221) - 1F011000', so it is not fully functioning, especially the energy and power updates on power change. (advanced z-wave parameters verified)
Switching and requesting power/energy updates, manually or via a schedule, do work.
How could this be fixed? Can I add these outlets again in some way, selecting another type?
Although this specific device type is not listed as supported, probably because it quite recent Fibaro addition...
Thanks for any advise. :D
Sun Feb 05, 2023 11:37 am
Re: Fibaro Walli Outlet type E support (FGWOE-011)
You cannot manually select a device definition in Indigo.
Can you re-sync it and copy/paste the Event Log window results into a reply for me so I can see exactly what it is reporting?
Sat Feb 11, 2023 11:29 am
slackman1 offline
Hi Matt,
Had to wait for the weekend to do this, log contents for syncing below:
Z-Wave Syncing - started for "stopcontact wasmachine"
Z-Wave Syncing - retrieved module neighbors list: 1, 2, 5, 8, 10, 17, 18, 19, 20, 21, 29, 35, 38
Z-Wave Syncing - assigning return route to "041 - stopcontact wasmachine"
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Walli Double Switch (FGWDSEU221) - 1F011000
Z-Wave Syncing - retrieved protocol version 6.02, app version 5.01
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 25v1 27v1 5Ev1 55v1 98v1 9Fv1 56v1 6Cv1 22v1 85v1 8Ev1 59v1 86v1 72v1 5Av1 73v1 32v3 70v1 71v1 75v1 7Av1
Z-Wave Syncing - retrieved encrypt commands: 70 71 72 73 75 7A 85 86 8E 25 32 59 5A
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - failed to retrieve parameter 20 "Switch Type" (skipping)
Z-Wave Syncing - failed to retrieve parameter 150 "Switch 1 mode" (skipping)
Z-Wave Syncing - failed to retrieve parameter 152 "Switch 1 behavior" (skipping)
Z-Wave Syncing - failed to retrieve parameter 154 "Switch 1 duration" (skipping)
Z-Wave Syncing - failed to retrieve parameter 40 "Switch 1 scenes" (skipping)
Z-Wave Syncing - retrieved parameter 61 "Relay 1 power report threshold" is 1 %
Z-Wave Syncing - retrieved parameter 62 "Relay 1 periodic power reports" is 60 seconds
Z-Wave Syncing - retrieved parameter 65 "Relay 1 energy report threshold" is 5 * 0.01 kWh
Z-Wave Syncing - retrieved parameter 66 "Relay 1 periodic energy reports" is 60 seconds
Z-Wave Syncing - retrieved parameter 60 "Include internal usage in power reports for relay 1" is true
Z-Wave Syncing - failed to retrieve parameter 151 "Switch 2 mode" (skipping)
Z-Wave Syncing - failed to retrieve parameter 153 "Switch 2 behavior" (skipping)
Z-Wave Syncing - failed to retrieve parameter 16 "Switch 2 behavior" (skipping)
Z-Wave Syncing - failed to retrieve parameter 155 "Switch 2 duration" (skipping)
Z-Wave Syncing - failed to retrieve parameter 41 "Switch 2 scenes" (skipping)
Z-Wave Syncing - failed to retrieve parameter 63 "Relay 2 power report threshold" (skipping)
Z-Wave Syncing - failed to retrieve parameter 64 "Relay 2 periodic power reports" (skipping)
Z-Wave Syncing - failed to retrieve parameter 67 "Relay 2 energy report threshold" (skipping)
Z-Wave Syncing - failed to retrieve parameter 68 "Relay 2 periodic energy reports" (skipping)
Z-Wave Syncing - failed to retrieve parameter 24 "Reverse switch controls" (skipping)
Z-Wave Syncing - failed to retrieve parameter 25 "Reverse output operation" (skipping)
Z-Wave Syncing - retrieved parameter 1 "Power up to last known state" is true
Z-Wave Syncing - retrieved parameter 11 "LED frame ON color" is 8 "Smooth Dynamic Based on Power Usage"
Z-Wave Syncing - retrieved parameter 12 "LED frame OFF color" is 0 "OFF"
Z-Wave Syncing - retrieved parameter 13 "LED frame brightness" is 100 "100 - High"
Z-Wave Syncing - retrieved parameter 10 "Power exceeded threshold" is 36800 * 0.1 watts
Z-Wave Syncing - retrieved parameter 2 "Relay 1 power overloaded threshold" is 0 * 0.1 watts
Z-Wave Syncing - failed to retrieve parameter 3 "Relay 2 power overloaded threshold" (skipping)
Z-Wave Syncing - complete
Error client target _autoAssignedId_37 not found for message UiValidate
Mon Feb 13, 2023 4:36 pm
Unfortunately, Fibaro re-used the same model ID for both modules.
That said, I think the reason the energy reports may not be working is because you included it with encryption enabled. Try excluding it and re-including it without encryption, then re-sync it. Does energy reporting and requests then work? We recommend only using encryption for modules where it is essential (door locks, motion sensors, garage controllers), as the additional encryption functionality greatly increases complexity and the number of commands required to communicate with the module.
Fri Jun 09, 2023 8:57 am
slackman1 offline
Matt, thanks for this tip!
Some time ago I changed/re-added these, unencrypted and behaviour is much better now.
Still testing some settings to get faster updates, comparable to Fibaro FGWP101 plug-type switches though.
Anyway, these nice in-wall type outlets look much better than plug-type switches...
