Thank you for the recommendation, Matt!
Wishing you and the entire Indigo community a Happy, Healthy and Prosperous New Year!
For future reference, here is what I did. (
This is from memory, and looking at the log. Please point out any corrections needed. YMMV based on your setup.)
Look up the reference to exclusion mode for the lock, which was here. That confirmed that on the Kwikset 620 I only need to press the A button and confirm my Z-Wave controller has excluded the device
Open Indigo desktop app and also open the Event Log window. For simplicity and sanity, I opened Screen Sharing on my laptop so I could operate my Mini (running Indigo and has Zigbee fob) while sitting next to the lock.
In Indigo / Device list, choose the lock and Delete it
At the device, press the A button and confirm in the Event Log that the device was excluded -Z-Wave - controller excluded module: 021 - Door Lock
Z-Wave Error - device "021 - Door Lock" no longer has a matching module 021 in the controller
Z-Wave Error - to re-enable the device with a new z-wave module, press the "Define and Sync..." button in the device dialog
Z-Wave - stopped controller exclusion mode
On the device (lock), promptly press the A button to begin pairing
The the Event Log had several "Syncing" entries for device 22 Z-Wave Syncing - started for "022 - Door Lock"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 5, 9, 12, 13, 14, 16, 17
Z-Wave Syncing - assigning return route to "022 - Door Lock"
Z-Wave Syncing - retrieved manufacture and model names: Kwikset - 0090, Keypad Door Lock (HomeConnect 620) - 081123A8
Z-Wave Syncing - retrieved protocol version 7.13, app version 7.20
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Entry Control : Door Lock (04 : 40 : 01, base 62)
Z-Wave Syncing - retrieved command classes: 20v1 62v1 5Ev1 55v1 98v1 9Fv1 6Cv1 86v1 72v1 5Av1 87v1 73v1 80v1 70v1 4Cv1 63v1 85v1 8Ev1 59v1 71v1 8Bv1 5Dv1 4Ev1 7Av1
Z-Wave Syncing - retrieved encrypt commands: {removed here]
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, security, frequentWaking
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - created device "022 - Keypad Door Lock (HomeConnect 620)"
Z-Wave Syncing - complete
At this point I could watch the event log for both manual and keypad-related events. I was pleased to see the difference in manual vs keypad actions, but would have been thrilled if the device would pass along the keypad code that was used so I could tie that to the person who activated the keypad.
I could also lock and unlock via the controller.
Z-Wave sent "022 - Keypad Door Lock (HomeConnect 620)" unlock
Z-Wave received "022 - Keypad Door Lock (HomeConnect 620)" status update unlocked (via controller)
Z-Wave received "022 - Keypad Door Lock (HomeConnect 620)" status update locked (manually)
Yet to do:
Set up iMessage notifications on lock events.
Integrate a lock/unlock toggle in my Control Page
And on the WIBNI list (Wouldn't It Be Nice If):
When an unlock is logged, grab a set of stills (or short video) from the Google Nest Cam that is pointing at that door. If anyone has experience integrating Nest Cam into Indigo, I would be very interested to hear of the Whats and Hows!
Thanks to all in the community for the unselfish assistance! It makes a huge difference to have a vibrant and cooperative community in support of a product!
Cheers to 2023!
~ Nat
