Zooz tilt/shock sensor ZSE43
Sun Oct 16, 2022 5:31 pm
ppespepe offline
Hello there,
I tried the Zooz ZSE43 and it is not working with Indigo. I believe this is an insanely cool sensor that can also be used together with the Zooz Zen17 and the virtual garage door plugin to automate a garage door.
here the info I could gather in case this helps:
Oct 16, 2022 at 6:25:38 PM
   Script                          address : 25
allowOnStateChange : False
allowSensorValueChange : False
batteryLevel : 91
buttonGroupCount : 0
configured : True
description :
deviceTypeId : zwOnOffSensorType
displayStateId : onOffState
displayStateImageSel : SensorOff
displayStateValRaw : False
displayStateValUi : off
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 0
     com.perceptiveautomation.indigoplugin.zwave : (dict)
          SupportsBatteryLevel : true (bool)
          SupportsOnState : true (bool)
          SupportsSensorValue : false (bool)
          address : 25 (integer)
          indigoObjVersion : 10 (integer)
          userEnergyPollingEnabled : false (bool)
          userPollInterval : 0 (integer)
          userPollingEnabled : false (bool)
          userWakeInterval : 60 (integer)
          version : 1.20 (string)
          zwAppVersMajor : 1 (integer)
          zwAppVersMinor : 20 (integer)
          zwAssociationsMap : (dict)
               g1 : (list)
                    Item : 1 (integer)
               g2 : (list)
               g3 : (list)
          zwAssociationsMapStr : 1:[1] 2:[] 3:[] (string)
          zwClassCmdBase : 0 (integer)
          zwClassCmdMap : (dict)
               c108 : 1 (integer)
               c112 : 1 (integer)
               c113 : 1 (integer)
               c114 : 1 (integer)
               c115 : 1 (integer)
               c122 : 1 (integer)
               c128 : 1 (integer)
               c132 : 2 (integer)
               c133 : 1 (integer)
               c134 : 1 (integer)
               c135 : 1 (integer)
               c142 : 1 (integer)
               c159 : 1 (integer)
               c32 : 1 (integer)
               c48 : 1 (integer)
               c85 : 1 (integer)
               c89 : 1 (integer)
               c90 : 1 (integer)
               c94 : 1 (integer)
          zwClassCmdMapStr : 20v1 5Ev1 85v1 8Ev1 59v1 55v1 86v1 72v1 5Av1 73v1 80v1 9Fv1 71v1 87v1 30v1 70v1 84v2 6Cv1 7Av1 (string)
          zwClassIds : (list)
               Item : 4 (integer)
               Item : 7 (integer)
               Item : 1 (integer)
          zwClassInstanceCountMap : (dict)
          zwClassInstanceCountMapStr : - none - (string)
          zwClassName : Notification Sensor (string)
          zwConfigVals : (dict)
          zwConfigValsStr : - none - (string)
          zwDevSubIndex : 0 (integer)
          zwEncryptClassCmdMap : (dict)
          zwEncryptClassCmdMapStr : - none - (string)
          zwEncryptionStatusStr : Not Supported (string)
          zwEndpointClassMap : (dict)
          zwEndpointClassMapStr : - none - (string)
          zwEndpointDevTypeMap : (dict)
          zwEndpointDevTypeMapStr : - none - (string)
          zwFeatureListStr : routing, battery, beaming, waking (string)
          zwLibType : 3 (integer)
          zwManufactureId : 634 (integer)
          zwManufactureName : Zooz (string)
          zwModelDefnVers : 0 (integer)
          zwModelId : 1879105539 (integer)
          zwModelName : Notification Sensor (string)
          zwNodeNeighbors : (list)
               Item : 1 (integer)
               Item : 12 (integer)
               Item : 17 (integer)
          zwNodeNeighborsStr : 1, 12, 17 (string)
          zwProtoVersMajor : 7 (integer)
          zwProtoVersMinor : 13 (integer)
          zwShowDumpDevToLog : false (bool)
          zwShowEnergyPollingUI : false (bool)
          zwShowMainUI : true (bool)
          zwShowManualModifyConfigParmUI : true (bool)
          zwShowPollingUI : false (bool)
          zwShowSubmitModelInfoUI : true (bool)
          zwShowWakeIntervalUI : true (bool)
          zwWakeInterval : 60 (integer)
lastChanged : 2022-10-16 18:24:55
lastSuccessfulComm : 2022-10-16 18:24:55
model : Notification Sensor
name : Zooz Shock ensor
onState : False
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
          g1 : (list)
               Item : 1 (integer)
          g2 : (list)
          g3 : (list)
          c108 : 1 (integer)
          c112 : 1 (integer)
          c113 : 1 (integer)
          c114 : 1 (integer)
          c115 : 1 (integer)
          c122 : 1 (integer)
          c128 : 1 (integer)
          c132 : 2 (integer)
          c133 : 1 (integer)
          c134 : 1 (integer)
          c135 : 1 (integer)
          c142 : 1 (integer)
          c159 : 1 (integer)
          c32 : 1 (integer)
          c48 : 1 (integer)
          c85 : 1 (integer)
          c89 : 1 (integer)
          c90 : 1 (integer)
          c94 : 1 (integer)
     zwClassIds : (list)
          Item : 4 (integer)
          Item : 7 (integer)
          Item : 1 (integer)
          Item : 1 (integer)
          Item : 12 (integer)
          Item : 17 (integer)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
remoteDisplay : True
sensorValue : None
states : States : (dict)
     batteryLevel : 91 (integer)
     batteryLevel.ui : 91% (string)
subModel :
subType :
supportsAllOff : False
supportsOnState : True
supportsSensorValue : False
supportsStatusRequest : True
version : 1.20
I hope this helps.
PP
Wed Nov 02, 2022 7:14 am
jalves offline
Re: Zooz tilt/shock sensor ZSE43
I just bought one of these as well. I've got it included in my Z-stick. Created and Indigo device for it. The device does show its last status received was recent (ie, well after the device was added) but a status request comes back with an error. It also does not show any activity in the log when I change its orientation.
Jeff
Sat Jan 14, 2023 5:55 pm
acjobim offline
Same for me. Hopefully, the ZSE43 makes the cut for the next Indigo release.
I usually check the supported list before purchase. Missed this one.
Fri Feb 24, 2023 3:55 pm
We've added support for the Zooz Tilt/Shock Sensor (ZSE43) in Indigo 2022.2.0, which is now available.
