NEO Coolcam Z Wave+ 700 PIR Motion, Temp, Humidity, Light
Tue Oct 26, 2021 6:40 am
CliveS offline
Just received the new NEO Coolcam Z Wave Plus 700 series PIR Motion Detector with Temperature Humidity Light Sensor
Runs from 1 or 2 CR123A batteries or USB
https://www.aliexpress.com/item/1005002309650200.html?spm=a2g0s.9042311.0.0.27424c4dfRnGmp
It includes ok without encryption but I was unable to include with encryption.
At present it does not work with Indigo but details have been sent and further details are below.
(well it does work but I am using it via my Hubitat hub and Jon's Hubitat Bridge plugin)
Manual can be found at https://usermanual.wiki/NEO-ELECTRONICS/NAS-WR12Z1U
2021-10-25 19:41:15.505 Z-Wave started controller inclusion mode
2021-10-25 19:42:08.184 Z-Wave controller included module: 048 - Notification Sensor
2021-10-25 19:42:08.937 Z-Wave stopped controller inclusion mode
2021-10-25 19:42:21.538 Z-Wave Syncing - started for "048 - Notification Sensor"
2021-10-25 19:42:21.615 Z-Wave Syncing - retrieved module neighbors list: 5, 8, 19, 41, 42, 103, 149, 156, 157, 158, 170, 186, 188, 190, 193
2021-10-25 19:42:21.616 Z-Wave Syncing - assigning return route to "048 - Notification Sensor"
2021-10-25 19:42:23.726 Z-Wave Syncing - assigned return route
2021-10-25 19:42:24.106 Z-Wave Syncing - retrieved manufacture and model names: Neo - 0258, Notification Sensor - 00100720
2021-10-25 19:42:24.143 Z-Wave Syncing - retrieved protocol version 7.13, app version 2.06
2021-10-25 19:42:24.227 Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
2021-10-25 19:42:24.229 Z-Wave Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 87v1 8Ev1 55v1 98v1 59v1 5Av1 5Ev1 9Fv1 20v1 70v1 71v1 6Cv1 30v1 31v11 72v1 73v1 7Av1
2021-10-25 19:42:24.229 Z-Wave Syncing - retrieved encrypt commands: - none -
2021-10-25 19:42:24.229 Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, security, waking
2021-10-25 19:42:24.325 Z-Wave Syncing - retrieved wake interval of 0 minutes
2021-10-25 19:42:24.476 Z-Wave Syncing - device "048 - Notification Sensor" wake interval changed to 60 minutes
2021-10-25 19:42:24.560 Z-Wave Syncing - retrieved group 1 associations: []
2021-10-25 19:42:24.597 Z-Wave Syncing - retrieved group 2 associations: []
2021-10-25 19:42:24.666 Z-Wave Syncing - added group 1 association to interface
2021-10-25 19:42:24.703 Z-Wave Syncing - retrieved battery level of 100%
2021-10-25 19:42:25.413 Z-Wave Syncing - created device "048 - Notification Sensor"
2021-10-25 19:42:25.445 Z-Wave Syncing - complete
2021-10-25 19:42:28.553 Z-Wave sent "048 - Notification Sensor" status request
2021-10-25 19:42:28.687 Z-Wave received "048 - Notification Sensor" status update battery level 100%
2021-10-25 19:42:44.072 Z-Wave received "048 - Notification Sensor" status update battery level 100%
2021-10-25 19:42:46.151 Z-Wave received "048 - Notification Sensor" status update battery level 100%
2021-10-25 19:42:55.028 Z-Wave Indigo Device "048 - Notification Sensor" Z-Wave Properties:
Indigo Z-Wave Version: 2021.1.1
Node ID: 48
Model: Notification Sensor
Model ID: 00100720
Manufacturer: Neo
Manufacturer ID: 0258
Protocol Version: 7.13
Application Version: 2.06
Model Definition Version: 0
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 80v1 84v2 85v1 86v1 87v1 8Ev1 55v1 98v1 59v1 5Av1 5Ev1 9Fv1 20v1 70v1 71v1 6Cv1 30v1 31v11 72v1 73v1 7Av1
Features: routing, battery, beaming, security, waking
Neighbors: 5, 8, 19, 41, 42, 103, 149, 156, 157, 158, 170, 186, 188, 190, 193
Associations: 1:[1] 2:[]
Config Values: - none -
CliveS
Sun Oct 31, 2021 3:58 pm
Re: NEO Coolcam Z Wave+ 700 PIR Motion, Temp, Humidity, Ligh
Thanks for the details – I'll look into create a definition to more fully support it.
In the mean time, take a look at this forum post for creating Triggers on the raw motion detected commands it should be sending.
Mon Nov 01, 2021 10:15 am
CliveS offline
Thank you
No need as I wrote a plugin to add unknown devices to Indigo but now have found a better solution with the Hubitat Hub and Jon's plugin, they get devices included pretty fast and the Z-Wave module is the new series 700 so I can spread the load and include Zigbee as well, just seamless integration into Indigo.
CliveS
Thu Dec 16, 2021 12:00 pm
Indigo 2021.2.0 is now available and includes support for the Neo CoolCam Multi Sensor (NAS-PD07Z)..
