Fibaro Switch without wall switch
Mon Oct 04, 2021 10:32 am
MarcoGT offline
would it possible to control a bulb connected to a Fibaro Switch without having in parallel the wall switch?
I would not need the wall switch.
It would mean that S1 pin will be left disconnected, but as far as I know, when switching on, it is exactly S1 contact that is toggled, or am I wrong?
Marco
Mon Oct 04, 2021 11:29 am
Re: Fibaro Switch without wall switch
Yes, I have some exactly like this.
Peter
Mon Oct 04, 2021 11:36 am
MarcoGT offline
Ok, thanks, and you have no problem by switching on/off with Indigo, right?
Mon Oct 04, 2021 11:45 am
Nope. Absolutely fine.
Mon Oct 04, 2021 1:28 pm
MarcoGT offline
And how could Fibaro Switch work if S1 is not connected?
Tue Oct 05, 2021 12:47 am
S1 is the incoming signal from the wall switch. It doesn’t care if there’s any switch there or not.
To clarify your earlier question, it is O1 that is toggled by Fibaro - either by you changing the state of the switch connected to S1, or by an Indigo command.
Also Fibaro doesn’t (by default) directly match the O1 output to S1; that is, they are, can be and often will be out of sync to each other. This confuses some people when imagining the wiring - “the switch is off, so why is my light on?”.
Tue Oct 05, 2021 1:53 am
MarcoGT offline
thank you for the detailed answer, and yes, you are (of course) right, it is O1 that is toggled, not S1.
Thank you
Marco
