Prevent "optimize neighbours" on node fail
Mon Aug 30, 2021 2:29 pm
DrLove offline
I need to optimize alot of battery devices and they tend to not wake up when I need them to.
If I have started optimization for that device and it does not wake up (even if I try to wake it, it happens) Indigo starts to optimize known neighbours, and I have ALOT of them for every battery device. Is it possible to have Indigo NOT start the known neighbours optimization process and just wait for wakeup?
Best regards, L
Love Kull (yes it's my name)
Blog (in Swedish)
Sweden
Mon Aug 30, 2021 3:21 pm
Re: Prevent "optimize neighbours" on node fail
Not currently, but that is a good feature request so I've added it to the list.
Mon Aug 30, 2021 3:23 pm
DrLove offline
OK, thanks.
I have notised that issuing a "stop optimize" does not stop the neighbour optimization, is there some way I can cancel that w/o reloading the interface?
//L
Blog (in Swedish)
Sweden
Mon Aug 30, 2021 3:39 pm
No, and I'm not positive that reloading the interface really cancels the currently active neighbor scan. It might cancel Indigo's awareness that it is being processed, but I suspect the Z-Wave controller is still internally doing the operation regardless.
Mon Aug 30, 2021 3:43 pm
DrLove offline
OK, thanks!
So I guess the only thing I can do is unplug the controller then :)
//L
Blog (in Swedish)
Sweden
Wed Sep 01, 2021 7:39 am
DrLove offline
I have been reorganizing and replacing alot of nodes now to get my network to be stable but running the "optimize" function is kind off messy.
- A high % of my Fibaro Wall connectors fail optimize if I don't do a status request a few seconds before optimize, that prevents the "optimize all" from working.
- All of my Fibaro Smoke (FW 2.01) and Water (FW 23.23) detectors does not play well w/ optimize funktion, allways fail. Only one Smoke detector (FW 3.03) worked and that is my newest one.
Is there some other way to have a node re-discover their neighbours? re-sync does not do that what I can see. Adding the node to a new device an sync, does that trigger a search? And then back to original device in Indigo. I do not want to exclude the problematic nodes and re-include them, my ID's is running out!! I'm on 191 now, what happens if I pass 255??
Is there some way to list devices that do not support "explorer frames"?
//L
Blog (in Swedish)
Sweden
Wed Sep 01, 2021 2:48 pm
Instead of selecting All Devices on the optimize, select the individual device you need to optimize (find neighbor nodes). Note all optimizing does is request that the controller (Z-Stick/etc.) issue a command to the module to find its neighbors, which then causes the controller to rebuild routes (if neighbors change). The ability to repair/optimize/fix routing is pretty much limited by the controller to just asking that it have a module rediscover its neighbors. Indigo has very little control over the process.
DrLove wrote:
Adding the node to a new device an sync, does that trigger a search? And then back to original device in Indigo. I do not want to exclude the problematic nodes and re-include them, my ID's is running out!! I'm on 191 now, [b]what happens if I pass 255??[/b
Excluding and re-including (and re-syncing) will also cause the controller to rediscover the best route to the module. Don't worry about the address limit, it should start re-using old addresses if you hit the end.
No, Indigo doesn't store that information about the devices.
Thu Sep 02, 2021 4:28 am
DrLove offline
Thank you!
I always do them one at a time, but the optimize function does start to optimize known neighbours if it fails and that process talkes forever with 100+ known neighbours (that in turn fails as well). For my battery devices it almost fail atleast the first 1-3 attempts so it takes forever, thats why I would like skip the "optimize known neighbours" part.
//L
Blog (in Swedish)
Sweden
