PS, more on energy report pulling:
Turning off a Fibaro wallplug (with pulling disabled):
30483425 2021-09-09 20:55:46.766 FALSE 7 Z-Wave Debug . .
requestMeterLevel: 0.0 W (float: 0.000000) same value as the wallplug sent before pulling30483424 2021-09-09 20:55:46.766 FALSE 7 Z-Wave Debug . . requestMeterLevel: node 026, endpoint None, meterType 01, raw value 3200...
30483423 2021-09-09 20:55:46.764 FALSE 7 Z-Wave Debug RCVD requestMeterLevel: 01 0E 00 04 00 1A 08 32 02 21 32 00 00 00 00 C4
30483422 2021-09-09 20:55:46.743 FALSE 7 Z-Wave Debug waiting up to 3.0 seconds for module reply after sending request
30483421 2021-09-09 20:55:46.742 FALSE 7 Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 D9 00 00 02 30 (node ACK)
30483420 2021-09-09 20:55:46.717 FALSE 7 Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 1A 03 32 01 10 25 D9 20
30483419 2021-09-09 20:55:46.716 FALSE 7 Z-Wave Debug . .
requestMeterLevel: 0.41 kWh (float: 0.410000) kWh is not sent from wallplug if not over trigger level for energy usage, but if not over we maybe don't need it 30483418 2021-09-09 20:55:46.716 FALSE 7 Z-Wave Debug . . requestMeterLevel: node 026, endpoint None, meterType 01, raw value 4400...
30483417 2021-09-09 20:55:46.714 FALSE 7 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 1A 0A 32 02 21 44 00 00 00 29 00 00 87
30483416 2021-09-09 20:55:46.704 FALSE 7 Z-Wave Debug waiting up to 3.0 seconds for module reply after sending request
30483415 2021-09-09 20:55:46.703 FALSE 7 Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 D8 00 00 02 31 (node ACK)
30483414 2021-09-09 20:55:46.671 FALSE 7 Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 1A 03 32 01 00 25 D8 31
30483413 2021-09-09 20:55:46.663 FALSE 7 Z-Wave Debug
polling status of node "026 - Lödkolv - Wallplug" (post-activity power / energy request)30483412 2021-09-09 20:55:41.654 FALSE 7 Z-Wave Debug
received "Lödkolv - Wallplug" power load to 0.0 W This one is sent from wallplug regardless of pulling I guess30483411 2021-09-09 20:55:41.654 FALSE 7 Z-Wave Debug . . requestVarSensorStatus: 0.0 W (float: 0.000000)
30483410 2021-09-09 20:55:41.654 FALSE 7 Z-Wave Debug . . requestVarSensorStatus: node 026, endpoint None, type 4, raw value 2200...
30483409 2021-09-09 20:55:41.652 FALSE 7 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 1A 06 31 05 04 22 00 00 F9
30483407 2021-09-09 20:55:40.902 FALSE 7 Z-Wave Debug
queueing power / energy request of "026 - Lödkolv - Wallplug" (activity detected)30483406 2021-09-09 20:55:40.9 FALSE 8 Z-Wave
sent "Lödkolv - Wallplug" offAlot of messages on the network and the process takes about 6 seconds, w/o active pulling the process would have been about half a second.
