ZOOZ Water Leak XS Sensor (ZSE42)
Fri Aug 20, 2021 1:31 pm
aldera offline
Just got this the other day. Submitted the device via your website. Below is the device readout.
It does sync and report battery level. That's about it. It doesn't notify when there's a water leak detected.
Indigo Z-Wave Version: 2021.1.1
Node ID: 138
Model: Notification Sensor
Model ID: 7000E002
Manufacturer: Zooz
Manufacturer ID: 027A
Protocol Version: 7.13
Application Version: 1.10
Model Definition Version: 0
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 80v1 84v2 85v1 86v1 87v1 8Ev1 55v1 59v1 5Av1 5Ev1 9Fv1 20v1 70v1 6Cv1 30v1 71v1 72v1 73v1 7Av1
Features: routing, battery, beaming, waking
Neighbors: 2, 10, 16, 30, 37, 38, 39, 41, 45, 47, 48, 50, 52, 58, 70, 80, 93, 95, 97, 118, 121, 132
Associations: 1:[1] 2:[]
Config Values: - none -
Sun Aug 22, 2021 4:52 pm
Re: ZOOZ Water Leak XS Sensor (ZSE42)
Thanks – I'll look into get a definition added for this one.
In the mean time can you try this technique to see if that catches the incoming command correctly?
Thu Sep 09, 2021 7:49 pm
aldera offline
Hi Matt,
Took awhile but I finally got around to it.
WATER DETECTED:
                RCVD requestBinarySensorStatus: 01 0A 00 04 00 8A 04 30 03 FF 06 B5
   Z-Wave Debug                    . .  requestBinarySensorStatus: node 138, endpoint None, type 6, value 255
   Z-Wave Debug                    RCVD requestAlarmSensorStatus: 01 0F 00 04 00 8A 09 71 05 00 00 00 FF 05 02 00 FB
   Z-Wave Debug                    . .  requestAlarmSensorStatus: node 138, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
   Z-Wave Debug                    . .  requestAlarmSensorStatus: typeExt 5, valueExt 2, classSubKeyExt 7100000502
WATER OFF
   Z-Wave Debug                    RCVD requestBinarySensorStatus: 01 0A 00 04 00 8A 04 30 03 00 06 4A
   Z-Wave Debug                    . .  requestBinarySensorStatus: node 138, endpoint None, type 6, value 0
   Z-Wave Debug                    RCVD requestAlarmSensorStatus: 01 0F 00 04 00 8A 09 71 05 00 00 00 FF 05 00 00 F9
   Z-Wave Debug                    . .  requestAlarmSensorStatus: typeExt 5, valueExt 0, classSubKeyExt 7100000500
I used
* 0x71 0x05 0x00 0x00 0x00 0xFF 0x05 0x02 * for Water Detected
and
* 0x71 0x05 0x00 0x00 0x00 0xFF 0x05 0x00 * for Water Off
Both triggers worked! Thanks!
Ralph
Thu Sep 09, 2021 7:56 pm
aldera offline
Matt,
I also emailed Zooz and they said they would send you samples of the device. They seem to have pretty good customer service as they responded within an hour or two on a Thursday night.
Zooz Support
"Hi Ralph,
Thank you for reaching out. It's the notification command class (water alarm) per the latest Z-Wave DSK. I don't believe Indigo fully supports this yet but we'll be sure to send them samples of the sensors and they'll hopefully get them integrated shortly.
Please let me know if we can assist you with anything else in the meantime!
Agnes
Zooz Support Team"
Mon Sep 20, 2021 1:04 pm
They have been great to work with. They are going to send me this module and a few others so I can get device definitions created and QA'd for them.
Tue Oct 19, 2021 2:30 pm
7rdr7 offline
Hey @Matt
Will the ZSE42 come out in an interim release or be included as part of the next major release (v2021.2)? I went ahead and purchased three of them....
Thanks, Ron
BTW, "Match Raw Packet" is working fine as an interim.
Tue Oct 19, 2021 3:22 pm
It'll be in the next release of Indigo, but that might be 2021.2.0 and not a bug fix release.
Thu Oct 28, 2021 2:59 pm
Indigo 2021.1.2 is now available and has a device definition for the ZSE42.
Thu Oct 28, 2021 5:38 pm
aldera offline
Thanks, Matt. It now recognizes the "leak detected" state.
Ralph
Thu Oct 28, 2021 7:20 pm
7rdr7 offline
Thanks Matt, works well. I assume that it’s design intent the it shows the actual state in the application, but latches in the iOS app? Makes sense.
Thu Dec 01, 2022 5:49 pm
Japple55 offline
For those of you using this leak sensor, what has been your experience? I was about to purchase a bunch but a lot of reviews claim battery life is poor.
Has that been your experience? Any other issues?
TIA,
Jim
Thu Dec 01, 2022 6:11 pm
aldera offline
TIA,
Jim
I purchased 2 on 8/2021. One is at 65% and one is at 72% battery life. I have their wake intervals set to twice/day.
Ralph
Fri Dec 02, 2022 12:47 pm
Japple55 offline
Thanks, Aldera. That sounds pretty good to me.
Jim
Wed Jun 21, 2023 6:06 am
Japple55 offline
A heads up for anyone using these sensors: the newer “child safe Duracell batteries” will not power these devices. I had an issue and tech support informed me that these new batteries have a “bitter” coating that prevents them from working with these sensors. They will be replacing the sensor’s gold plating with tin for better conduction in the next production run to resolve this.
Thu Feb 01, 2024 6:32 pm
ryanbuckner offline
Can this sensor be used in Indigo without a ZOOZ Hub?
