New Device (I believe) Aeon Labs Door/Windows Sensor 7
Sat Jul 04, 2020 6:39 pm
GlennNZ offline
https://aeotec.com/z-wave-door-window-sensor/
https://aeotec.freshdesk.com/support/so ... user-guide
New Device definition (or perhaps model ID needed)
Aeotec Door/Window Sensor 7.
Syncs, reports battery - "Notification Sensor" but no on/of state change with magnet door/open close.
Details below:
Indigo Z-Wave Version: 7.4.1
Node ID: 161
Model: Notification Sensor
Model ID: 02020007
Manufacturer: Aeon Labs
Manufacturer ID: 0371
Protocol Version: 6.02
Application Version: 1.00
Model Definition Version: 0
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 80v1 84v2 85v1 86v1 8Ev1 55v1 59v1 5Av1 5Bv1 5Ev1 9Fv1 20v1 70v1 6Cv1 30v1 71v1 72v1 73v1 7Av1
Features: routing, battery, beaming, waking
Neighbors: 5, 10, 29, 35, 44, 46, 47, 48, 51, 52, 55, 56, 93, 102
Associations: 1:[1] 2:[] 3:[] 4:[]
Config Values: - none -
Glenn
Mon Jul 06, 2020 2:52 am
McJohn offline
Re: New Device (I believe) Aeon Labs Door/Windows Sensor 7
Hi Glenn,
I think it's not a new device, but maybe the model ID is changed?
viewtopic.php?f=58&t=22581
Ours is working perfectly with Indigo since 9 months.
Regards,
John
Tue Jul 07, 2020 5:45 pm
John is correct – we'll get the model ID yours is using added to the next version of Indigo.
Wed Dec 23, 2020 3:16 pm
Indigo 7.5 is now available and includes the model ID for your Door/Window Sensor 7.
Sun Jun 27, 2021 5:44 pm
welchgregusa offline
Hello.
Similar issue w/ some ZWA011 versions of Aeotec's Door/Window Sensor 7. I am only able to get them to join as "Notification Sensor" which, as far as I can tell, cannot do anything. At least the open-close functionality (w/ the magnet) does not work.
This is on Indigo 2021.1.0 running on macOS 10.15.7.
I've reported the sensor via the web form (from the device settings dialog, on the server), but here's the information anyway:
Indigo Z-Wave Version: 7.5.1
Node ID: 156
Model ID: 0102000B
Protocol Version: 7.12
Application Version: 1.01
Library Type: 3
Command Versions: 80v1 84v2 85v1 86v1 87v1 8Ev1 55v1 59v1 5Av1 5Ev1 9Fv1 20v1 6Cv1 70v1 71v1 72v1 73v1 7Av1
Neighbors: - none -
As I indicated when I submitted it, I guess this is the "not Pro" (amateur?) ZWA011 version of their Door/Window Sensor 7. I did not even know that there was a "Pro" and "not Pro" version of the sensor, and accidentally ordered some "not Pro" versions from Amazon. (At first I thought they were defective because they don't have the terminal block inside...then I found out that the missing terminal block was intentional....)
I'm holding out hope that supporting them in Indigo won't be involved....
Thanks.
Mon Jun 28, 2021 11:29 am
Indigo supports both versions of the Door/Window Sensor 7, so I think we just need to add the model ID for particular one you have. Is the specific model on the module itself ZWA008?
We'll get it added to the next version. In the mean time, try using a Trigger on the raw command shown on this post to see if that works.
Mon Jun 28, 2021 11:58 am
The label inside the device says
Model: ZWA011-A (908.42MHz)
FCCID: 2AOGIZW011
The raw command triggers appear to work, although I seem to get both open and close messages/triggers every time I bring the magnet close OR move it away. (I would expect either an open or close when I bring it close or far, but not both.)
Thanks Matt.
Thu Aug 26, 2021 1:37 pm
Unless I'm dreaming I think this now works in 2021.1 (.1). I was able to add two, of them, they were identified properly (it seems) and work as expected. Thank you Matt!
Thu Aug 26, 2021 2:19 pm
Yep, the ZWA011 was one of several modules we added support for to 2021.1.1. I'm glad it is working for you now!
Users browsing this forum: dduff617 and 19 guests
