Pleas could you add the Fibaro FGS-214 to the Indigo supported device list.
(And also for the FGS-224)
https://manuals.fibaro.com/content/manu ... EN-1.0.pdf
It's working, but only On and Off. Nothing more.
We are missing for example the Relay off delay function.
Below the Device details.
Thanks for all your work.
Indigo Device "117 - Relay Power Switch" Z-Wave Properties:
Indigo Z-Wave Version: 7.4.1
Node ID: 117
Model: Relay Power Switch
Model ID: 04041000
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 6.04
Application Version: 5.00
Model Definition Version: 0
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 25v1 27v1 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Features: routing, beaming, security
Neighbors: 3, 5, 9, 10, 12, 13, 14, 15, 22, 23, 24, 25, 26, 27, 30, 35, 91, 100, 106, 111, 116
Associations: 1:[1] 2:[]
Config Values: - none -
