New Remotec Aircon IR Interface ZXT-600
Sun Nov 25, 2018 9:16 pm
garywiz offline
Remotec has discontinued their ugly IR Interface (ZXT-120) and replaced it with a much more attractive unit the ZXT-600.
The old device was known to Indigo as "IR Thermostat Bridge (ZXT-120)" but the new one, after inclusion just says "General Thermostat (v2)" and lists no configuration parameters in the status. However, I can access critical config parameters unique to the device and it looks nearly identical to the ZXT-120 (except config parameters look like they are 2 bytes now instead of 1).
I'm going to be setting up two of these as replacements for the ZXT-120 sometime in the next few days and will report if I have any problems. At first glance, it looks like they may work.
However, just to be sure, I am using the "Submit A Device" interface to send the status information directly to you so you can see if better support is easily possible.
Thank you.
Mon Nov 26, 2018 1:01 am
Re: New Remotec Aircon IR Interface ZXT-600
Thanks Gary.
Mon May 13, 2019 1:45 am
mclass offline
Hi!
Any further info about the performance of/support for the ZXT-120 with Indigo 7.3.1?
Have been using the previous model with success but have a couple more units to support.
Any further details greatly appreciated.
mclass
Mon May 13, 2019 2:01 am
ZXT-120 or its successor ZXT-600?
120 still works fine as far as I know; it’s the 600 reported above that didn’t.
Mon May 13, 2019 5:49 am
mclass offline
Whoops!!
I meant the ZXT-600!
Am I to assume that it doesn’t work with Indigo 7.3? Is that because it hasn’t yet been supported, or is it a dud?
If the former is it likely to be supported in the future ie can I risk buying a sample and submitting device details in the usual manner?
If the latter, are there alternatives that will work locally (no internet access) with Daikin codes built in. My understanding is that he Sensibo device and plug in requires access to the Sensibo server.
mclass
Thu May 16, 2019 7:27 am
There’s no reason it won’t ultimately be supported if it isn’t yet; mines the 120 so can’t comment.
Wed Dec 23, 2020 3:11 pm
Indigo 7.5 is now available and includes preliminary (untested) support for the ZXT-600.
Sat Jul 17, 2021 7:36 am
macpro offline
I have two of these and added them to Indigo before version 7.5 was out.
They show as General Thermostat v2.
What do I need to do to let Indigo 7.5 recognize them as ZXT-600?
Sat Jul 17, 2021 12:35 pm
Copy/paste the sync results so we can see how they are identifying themselves. We can get then get it added to the next release of 2021.1, which will be soonish. I can also add it to 7.5, but I don't know when/if we'll be releasing a new build/installer for it.
Sat Jul 17, 2021 2:09 pm
macpro offline
Here's the requested output:
    Z-Wave                          Indigo Device "Woonkamer Airco" Z-Wave Properties:
Indigo Z-Wave Version: 7.5.1
Node ID: 90
Model: General Thermostat (v2)
Model ID: 01018490
Manufacturer: Remotec
Manufacturer ID: 5254
Protocol Version: 4.33
Application Version: 1.05
Model Definition Version: 0
Library Type: 3
Class Name: General Thermostat (v2)
Class Hierarchy: 04 : 08 : 06
Command Class Base: 40
Command Versions: 20v1 40v1 22v1 43v1 44v1 85v1 86v1 80v1 70v1 31v7 72v1 73v1 98v1 59v1 7Av1 5Av1 5Ev1
Features: routing, battery, beaming, security, frequentWaking
Neighbors: 1, 4, 5, 8, 9, 12, 15, 16, 17, 19, 20, 21, 22, 23, 24, 25, 26, 28, 29, 32, 33, 34, 35, 36, 38, 39, 40, 43, 51, 66, 67, 69, 70, 71, 72, 80, 84, 85, 86, 91, 92, 95
Associations: 1:[1]
Config Values: - none -
I am already on 2021.1, so no need for me to add it back to 7.5.
Thu Aug 05, 2021 2:10 am
Indigo 2021.1.1 is now available and adds support for your version of the Remotec IR Thermostat Bridge (ZXT-600).
Thu Aug 05, 2021 2:49 pm
macpro offline
