Qubino RGBW Controller
Sun Dec 13, 2020 10:08 am
7rdr7 offline
Re: Qubino RGBW Controller
I'm about to purchase some Qubino RGBW devices as they have some attractive features. I already have a number of Quibino devices and although they are finicky to set up when leveraging all features, they are a good product. This feels like the same multi-channel issue that I have with the Qubino Flush 1D when I want to use the switch, temperature probe, and sensor input together. Is there a fix on the horizon for the multi-channel issue?
Sun Dec 13, 2020 1:14 pm
We added support for the basic functionality of the Qubino Flush RGBW Dimmer (ZMNHWD) to Indigo 7.4.1, so it should work. That said, it is definitely another complicated Qubino module, so getting it included, configured, and working might not be "simple." Let us know how it works for you.
Sun Dec 13, 2020 1:17 pm
Note also the Flush 1D should be working, I think as of 7.0. If that isn't the case for you then can you describe what you are seeing (or point to the forum thread you are referring to about the multi-channel problem)?
Tue Dec 15, 2020 10:16 am
7rdr7 offline
Thanks Matt. I may have my terminology wrong, but was referencing the the include-exclude-include machinations to get all the Qubino features working. I was hoping that there was a more elegant way in the works to include these devices. It seemed like the RGBW device had similar peculiarities to the Flush 1D. That said, the Qubino RGBW and Flush 1D have unique capabilities, so I'll keep using them.... As always, thanks for the quick response!
Tue Dec 15, 2020 11:38 am
siclark offline
Has anyone got the specific end point associations working with these yet?
Fri Jan 01, 2021 10:56 am
7rdr7 offline
The Qubino Flush RGBW Dimmer (ZMNHWD) auto included and works as expected with an RGBW strip. BTW, on another note, 7.5 is noticeably faster across devices.
Fri Feb 05, 2021 5:16 pm
welchgregusa offline
Matt:
I notice the Z-Wave speedup in 7.5.0 also!
However I am still seeing a need to resync all of my "Qubino Z-Wave Plus RGBW Controller ZMNHWD3" units every time I reboot my Indigo server. (The server is an Intel Mac Mini running macOS 10.15.7 (and Indigo 7.5.0.) Not debilitating but a nuisance, and puzzling. I can't figure out if it's Qubino, Aeotec (Z-Stick), or Indigo, or some combination.
I know you guys have limited cycles, but if me sending you a unit (purchase and have it delivered to you) would help, i.e. if you thought you might find time to try it but don't have one, I could do that.
--greg
Sat Feb 06, 2021 6:17 pm
Hi Greg,
After looking at your previous Event Log posts again, I'm thinking this is an Indigo bug related to how the device defined is dynamic (it can be either a normal dimmer, or an RGB device). I'll look into this some more ASAP and get you a beta version of Indigo's Z-Wave Library to try.
Sat Feb 06, 2021 6:29 pm
Wow! That sounds encouraging. Thank you for any time you can spend on it!!
Thu Mar 18, 2021 2:48 pm
7rdr7 offline
I've noticed the same behavior with my Qubino RGBW Controller.
Tue Mar 30, 2021 7:02 am
@Matt: I just realized something that might (or might not...) be useful or interesting. It seems the Z-Wave connection is actually still working, at least in part, after a reboot. Specifically I just realized that when I reboot the server, the "Turn On" and "Turn Off" buttons of the device actually DO work (the LEDs go on and off), but the "W" (white) slider/dimmer does NOT, and the "RGB" color choosing mechanisms do NOT. The UI elements for those mechanisms (W and RGB) seem to "snap back" to 0/null whenever I change them, and the LEDs never seem to go on. BTW, I'm running Indigo 7.5.0.
As always, thanks.
Wed Apr 07, 2021 7:02 pm
7rdr7 offline
I have a similar experience, and a sync seems to clear it.
Apr 7, 2021 at 8:56:07 PM
Z-Wave connection reset requested
Z-Wave connected to Z-Stick Gen5 (ZW090) interface on /dev/cu.usbmodem14301 (firmware 1.01, minimum SDK 6.51.06)
Z-Wave Error module 036 included in controller does not match device "Kitchen Cabinet Lights" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwColorDimmerType (4, 17, 1))
Apr 7, 2021 at 8:58:20 PM
Z-Wave Syncing - started for "Kitchen Cabinet Lights"
Z-Wave Syncing - retrieved module neighbors list: 9, 10, 11, 13, 17, 18, 33, 45, 51, 62, 108, 118, 126, 134, 135, 156, 157, 177, 179, 185, 186, 217, 222, 224, 228, 229, 231
Z-Wave Syncing - assigning return route to "036 - Kitchen Cabinet Lights"
Z-Wave Syncing - retrieved manufacture and model names: Qubino - 0159, Flush RGBW Dimmer (ZMNHWD) - 00010054
Z-Wave Syncing - retrieved protocol version 4.24, app version 2.98
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01, base 26)
Z-Wave Syncing - retrieved command classes: 20v1 85v1 73v1 26v2 86v1 27v1 70v1 72v1 33v2 59v1 7Av1 5Av1 5Ev1 25v1
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - retrieved parameter 7 "Power up state" is 0 "Off"
Z-Wave Syncing - retrieved parameter 14 "Dimmers mode" is 0 "Single RGBW Color Device"
Z-Wave Syncing - retrieved parameter 1 "Input 1 mode" is 8 "Scene - Momentary Switch Type"
Z-Wave Syncing - retrieved parameter 2 "Input 2 mode" is 4 "Brightness - Momentary Switch Type"
Z-Wave Syncing - retrieved parameter 3 "Input 3 mode" is 4 "Brightness - Momentary Switch Type"
Z-Wave Syncing - retrieved parameter 4 "Input 4 mode" is 7 "Rainbow - Momentary Switch Type"
Z-Wave Syncing - retrieved parameter 5 "Auto scene mode" is 4 "Snow - Flowing Shades of White and Cyan"
Z-Wave Syncing - retrieved parameter 6 "Auto scene duration" is 3 "3 Seconds"
Z-Wave Syncing - retrieved parameter 11 "Minimum value" is 1
Z-Wave Syncing - retrieved parameter 10 "Maximum value" is 99
Z-Wave Syncing - retrieved parameter 12 "Button tap duration" is 10 * 100 milliseconds
Z-Wave Syncing - retrieved parameter 13 "Button down duration" is 3 seconds
Z-Wave Syncing - complete
Z-Wave sent "Kitchen Cabinet Lights" status request
Sat Apr 10, 2021 1:48 pm
Thanks for the updates and additional reports. We'll definitely get this fixed.
Sat Apr 17, 2021 12:29 pm
7rdr7 offline
Thanks Matt!
Sat Jun 19, 2021 1:41 pm
7rdr7 offline
Hey Matt, I loaded the new release today. I noticed that this issue is still there. Was it fixed? If so, do I need to delete and re-include the Qubino RGBW device? Thanks.
