Fibaro Wall Plug Type G FGWPG-111 (UK Socket)
Fri Jun 15, 2018 4:53 am
Suncroft offline
I received and have tested one of the newly released Fibaro Wall Plug Type G FGWPG-111 (UK Socket) today and other than Indigo not having a matching device profile for it, it seems to work fine.
Power on/off via the Indigo UI works fine.
Local power on/off on the module updates on/off status in indigo fine.
Power usage of attached device is reported to indigo fine.
I have submitted a device report to Indigo so hopefully it gets tagged to the next release.
Couple of pics for anyone intrested
Fri Jun 15, 2018 5:17 am
mat offline
Re: Fibaro Wall Plug Type G FGWPG-111 (UK Socket)
Can you switch the led's off that show power usage?
I have a real dislike for glowing things around the house, but do generally like the reliability of the fibaro kit.
Cheers
Mat
Late 2018 mini 10.14
Fri Jun 15, 2018 5:29 am
Suncroft offline
Hi Mat,
Yes you can disable the light by holding down the switch for a few seconds.
Fri Jun 15, 2018 5:38 am
Nice. I’m amazed it’s taken them so long to bring out a U.K. version!
Out of interest does turning it on/off immediately update its status in Indigo or does it needed to be polled?
Fri Jun 15, 2018 5:42 am
Suncroft offline
It updates immediately in Indigo when switched on\off locally so no need for polling which is nice upgrade over my older HomePro modules.
Fri Jun 15, 2018 6:41 am
mat offline
Thanks :D
Fri Jun 15, 2018 8:20 am
Definitely handy to know. Not in a position to get any now but I’m hoping to phase out my lightwaverf plugs at some point and these would certainly be nice options.
Fri Jun 15, 2018 10:36 am
CliveS online
Cheers
Mat
Yes, you can set parameters 41 and 42 to 0 - illumination turned off completely.
CliveS
Tue Jun 19, 2018 6:21 am
Just got a few of these and they seem to be an improvement on the Aeotec Smart Switch 6 (ZW096-C07)
The most significant thing is that the Fibaro physical on/off button is on the side of the switch and you can actually use it when you have a UK plug plugged into the device. :)
This is unlike the Aeotec device where the physical on/off button is on the front face and covered by the UK plug plugged into it, thereby effectively rendering it useless as an on/off switch. :shock:
Tue Jun 19, 2018 10:56 am
CliveS online
Only problem I had was getting them included, one worked when I was about 2 rooms away from the Indigo Server but the other would not include unless I plugged it in right next to the Indigo Server and on both I had to keep pressing the button as it was not press 1-2-3 and include, more like 1-2-3......10, but they work fine and should have a full definition on the (hopefully) soon to be released 7.1.2 ( :wink: )
CliveS
Tue Jun 19, 2018 6:41 pm
Gman34798 offline
I have 3 of the US versions of the Fibaro wall plug. They work fine, but do not report energy usage, usage shows up as 0 in Indigo.
Wed Jun 20, 2018 12:24 am
Gman, we can look at what code it’s sending and see if we can sort that if you want.
Install my Zwave Watcher plugin and create a watcher on the switch.
Peter
Tue Jun 26, 2018 5:51 am
My device is picking up the power usage:
Fibaro UK Plug
Fibaro UK Plug.png (152.2 KiB) Viewed 3302 times
Device Details:
Indigo Device "Power - All Hi-Fi" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.116
Node ID: 6
Model: Relay Power Switch
Model ID: 18011000
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 4.61
Application Version: 4.00
Model Definition Version: 0
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 25v1 27v1 32v3 55v1 56v1 59v1 5Av1 5Ev1 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Features: routing, beaming, security, energyMeter
Neighbors: 3, 5, 7, 8, 9, 18, 20, 21, 22, 26, 27, 28, 29, 30, 31, 32, 33, 35, 61, 62
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
@Suncroft - Thanks for the tip on how to quickly turn off the light. :)
Sat Sep 29, 2018 2:52 pm
CliveS online
Matt/Jay
Just tried a sync on this and still shows as not having a Device Definition after 7.2 upgrade.
Can we add this to the 7.2.1 update please.
CliveS
Sat Sep 29, 2018 2:55 pm
Yeah, there are a handful of device definitions I had really hoped to getting to but just ran out of time. This is one of those... No promises on it being in a 7.2.1 update, but don't rule it out.
