Need device definition for Fortrezz Flow Meter
Mon Apr 23, 2018 5:06 am
six50joe offline
I just had a Fortrezz shutoff valve, and flow meter installed. No problem including them and creating devices for them. The flow valve on/off control works fine, though it shows 'off' when the valve is open., 'on' when it's closed, no biggie.
It doesn't look like there's a device definition for the flow meter yet. I clicked the 'submit to indigo' button in the device's config tab a little while ago to provide the details. Currently, the only thing it reports is temperature (of the flowing water). Anything else needed from me to get flow data working?
Thanks, Joe
Wed Apr 25, 2018 9:18 am
six50joe offline
Re: Need device definition for Fortrezz Flow Meter
The ZWave command class configuration for this device is in this document:
https://static1.squarespace.com/static/ ... Manual.pdf
Wed May 02, 2018 9:13 am
six50joe offline
Any possibility this device will be supported in the near term? I installed one for multiple needs, but most immediately to detect landscapers on my neighbors properties using my outside hoses while I'm away. Most other FortrezZ ZWave devices are supported. Perhaps wasn't a good idea on my part to assume this one would be included, but if there isn't a definition coming soon, is there a way I can implement my own?
Wed May 02, 2018 5:22 pm
Sorry for the slow reply, but I'll get back to you with more details soon.
Wed May 09, 2018 11:14 am
Hi Joe,
I've looked over the technical docs for this one but would like to get some actual command data from you as it works, so can you:
1) Enable Indigo's Z-Wave debug logging checkbox (choose the Interfaces->Z-Wave->Configure... menu item).
2) Turn on a faucet in the house (force water flow).
3) Wait 5 minutes or so.
4) Turn off the faucet.
5) Wait 5 more minutes.
6) Copy/paste the Event Log window results into a reply for me.
Sun May 13, 2018 3:18 pm
six50joe offline
No problem, debug information attached.
Thanks Matt,
Joe
ZWave-Debug.txt
(31.05 KiB) Downloaded 129 times
Thu May 31, 2018 11:53 am
six50joe offline
Any chance this device will have a definition sometime soon?
Fri Jun 08, 2018 9:54 am
six50joe offline
Bump.
Fri Jun 08, 2018 10:45 am
Bumping isn't going to make it happen any faster... :wink:
Fri Jun 08, 2018 12:05 pm
six50joe offline
:) Bump wasn't intended to make the device definition happen faster, but I was hoping to get a rough idea whether we're talking days, weeks or months. If it's the latter I will need to work on an alternate solution for the problems I installed the device to solve this summer. -Joe
Fri Jun 08, 2018 12:22 pm
Earliest is going to be July, possibly later.
Fri Jun 08, 2018 1:05 pm
six50joe offline
Ok, thanks for the update Jay.
Fri Jun 08, 2018 2:29 pm
Colorado4Wheeler offline
I'm looking forward to the integrated support and the reports of how it works with Indigo. I've had my eye on these for a while.
Wed Jun 20, 2018 8:46 am
eme jota ce offline
Having a Fortrezz flow meter installed right now, along with Fortrezz shut-off value while having some other, needed plumbing done.
Looking forward to an Indigo update that will include this device.
Tue Sep 18, 2018 1:29 pm
six50joe offline
Is there an update for availability of this device definition?
Thanks, Joe
