Fibaro relay not reporting device action from switch 2
Mon Apr 16, 2018 11:49 am
noel1983 offline
Hi all,
Just fitted a fibaro relay with 2 channels into a kitchen light switch.
Two switches connected to the relay with 2 outputs to two lighting circuits.
All works fine and is controllable from indigo however when switch 2 is used to turn on the cupboard lights indigo doesn't seem to see the status change of the device.
I've turned on the commands setting so it shows switch 2 pressed but should it show me the end device status as well?
Switch 2 is connected to a separate device called Kitchen Cupboard Lights
Log output below:
Apr 2018, 17:58:00
Schedule TimeIncrement
Z-Wave received "Kitchen Lights" button 2 pressed
Z-Wave received "Kitchen Lights" status update is off
Z-Wave received "Kitchen Lights" button 1 pressed
Z-Wave received "Kitchen Lights" power load to 0.0 W
Z-Wave received "Kitchen Lights" status update is on
Z-Wave received "Kitchen Lights" power load to 38.5 W
Z-Wave received "Kitchen Lights" energy total to 0.58 kWh
Z-Wave received "Kitchen Lights" power load to 38.4 W
Noel
Mon Apr 16, 2018 11:52 am
Re: Fibaro relay not reporting device action from switch 2
Do the cupboard lights change/ respond if you tell them to from Indigo?
Mon Apr 16, 2018 11:53 am
noel1983 offline
Yes they work fine. Both from Indigo and from the switch.
Mon Apr 16, 2018 11:55 am
There was a bug conversation last week about Fibaro Dimmer where Button 2 didn’t get reported to Indigo - but that’s not the case here; it’s reporting and being seen, just not being acted on.
Have you the sync log of when you synced it? I suspect Matt will ask for it shortly. :p
Mon Apr 16, 2018 11:58 am
noel1983 offline
Synced as in when I first associated it? No
Just went in and defined and synched and got this:
16 Apr 2018, 18:56:44
Z-Wave Syncing - started for "Kitchen Lights"
Z-Wave Syncing - retrieved module neighbors list: 1, 3, 4, 5, 6, 13, 14, 18, 19, 24, 26
Z-Wave Syncing - assigning return route to "027 - Kitchen Lights"
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Double Switch 2 (FGS223) - 02031000
Z-Wave Syncing - retrieved protocol version 4.05, app version 3.02
Z-Wave received "Hall - Motion Sensor - 017 - Motion Sensor" status update is on
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 60v4 22v1 25v1 86v1 27v1 72v1 8Ev1 70v1 71v1 32v3 73v1 75v1 56v1 98v1 59v1 5Av1 5Bv1 7Av1 5Ev1 85v1
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved multi-endpoint types: 1:(10 : 01), 2:(10 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 86 25 85 59 8E 32], 2:[5E 86 25 85 59 8E 32]
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Syncing - retrieved parameter 20 "Switch type" is 0 "Momentary"
Z-Wave Syncing - retrieved parameter 10 "Switch 1 mode" is 0 "Normal"
Z-Wave Syncing - retrieved parameter 11 "Switch 1 behavior" is 0 "Cancel Delay or Auto Mode"
Z-Wave Syncing - retrieved parameter 28 "Switch 1 scenes" is 15 "Send All"
Z-Wave Syncing - retrieved parameter 12 "Switch 1 duration" is 50 seconds
Z-Wave Syncing - retrieved parameter 13 "Switch 1 flash" is 5 * 100 milliseconds
Z-Wave Syncing - retrieved parameter 50 "Switch 1 power threshold" is 20 %
Z-Wave received "Bathroom - Temperature" sensor update to 22.8 °C
Z-Wave Syncing - retrieved parameter 51 "Switch 1 power delay" is 10 seconds
Z-Wave Syncing - retrieved parameter 53 "Switch 1 energy threshold" is 100 * 0.01 kWh
Z-Wave Syncing - retrieved parameter 15 "Switch 2 mode" is 0 "Normal"
Z-Wave Syncing - retrieved parameter 16 "Switch 2 behavior" is 0 "Cancel Delay or Auto Mode"
Z-Wave Syncing - retrieved parameter 29 "Switch 2 scenes" is 15 "Send All"
Z-Wave Syncing - retrieved parameter 17 "Switch 2 duration" is 50 seconds
Z-Wave Syncing - retrieved parameter 18 "Switch 2 flash" is 5 * 100 milliseconds
Z-Wave Syncing - retrieved parameter 54 "Switch 2 power threshold" is 20 %
Z-Wave Syncing - retrieved parameter 55 "Switch 2 power delay" is 10 seconds
Z-Wave Syncing - retrieved parameter 57 "Switch 2 energy threshold" is 100 * 0.01 kWh
Z-Wave Syncing - retrieved parameter 58 "Periodic power reports" is 3600 seconds
Z-Wave Syncing - retrieved parameter 59 "Periodic energy reports" is 3600 seconds
Z-Wave Syncing - retrieved parameter 9 "Power up to last known state" is true
Z-Wave Syncing - complete
Z-Wave sent "Kitchen Lights" status request
Z-Wave sent "Kitchen Lights" energy status request
Z-Wave sent "Kitchen Cupboard Lights" status request
Z-Wave sent "Kitchen Cupboard Lights" energy status request
Mon Apr 16, 2018 12:04 pm
Looks healthy to me, but Matt is better at sync/device issues.
I deal more with raw Zwave queries - but we know your command is being seen.
Erm, what is polling set to on this device?
Mon Apr 16, 2018 12:18 pm
noel1983 offline
Enabled
Only when activity detectwd
Mon Apr 16, 2018 12:23 pm
Colly offline
Try this thread - http://forums.indigodomo.com/viewtopic.php?f=58&t=18165 - it may help as I think it solved a similar issue for me in the past.
Mon Apr 16, 2018 12:42 pm
noel1983 offline
Awesome thanks Colly, yes that's fixed it although I don't know scene commands in the logs. I've posted in the other thread about that.
Thanks guys, incredibly responsive of all of you!!!
Cheers
Noel
