Fibaro Dimmer 2 S2 Status
Sun Apr 08, 2018 2:16 am
colinpartridge offline
I have a newly installed Fibaro Dimmer 2 (firmware version 3.05) doesn't appear to be reporting the status of the second input switch S2 to Indigodomo. The status of s1 is reported immediately and also with scenes activated I'm getting a scene 26 ( reporting s2 in the event log). If I query the status of s2 manually then the status is updated as expected. Any ideas on how I can get the second input status updating correctly
Heres the Event log when the fibaro is being synced.
Z-Wave                          Syncing - started for "119 - Kitchen dimmer"
   Z-Wave                          Syncing - retrieved module neighbors list: 4, 8, 9, 14, 24, 25, 29, 33, 35, 40, 53, 55, 60, 64, 75
   Z-Wave                          Syncing - assigning return route to "120 - 119 - Kitchen dimmer"
   Z-Wave                          Syncing - retrieved manufacture and model names: Fibaro System - 010F, Dimmer Switch (FGD212) - 01021000
   Z-Wave                          Syncing - retrieved protocol version 4.05, app version 3.05
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01, base 26)
   Z-Wave                          Syncing - retrieved command classes: 20v1 85v1 86v1 71v1 8Ev1 56v1 98v1 59v1 5Av1 5Ev1 60v4 22v1 26v3 27v1 72v1 70v1 31v4 32v3 73v1 75v1 7Av1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, beaming, security
   Z-Wave                          Syncing - retrieved multi-endpoint types: 1:(11 : 01), 2:(11 : 01)
   Z-Wave                          Syncing - retrieved multi-endpoint classes: 1:[5E 20 86 26 85 59 8E 32 31 71], 2:[5E 20 86 26 85 59 8E]
   Z-Wave                          Syncing - retrieved group 1 associations: [1]
   Z-Wave                          Syncing - retrieved group 2 associations: [1]
   Z-Wave                          Syncing - retrieved group 3 associations: []
   Z-Wave                          Syncing - retrieved group 4 associations: []
   Z-Wave                          Syncing - retrieved group 5 associations: []
   Z-Wave                          Syncing - group 1 association to interface already exists (skipping)
   Z-Wave                          Syncing - group 2 association to interface already exists (skipping)
   Z-Wave                          Syncing - retrieved parameter 20 "Switch type" is 0 "Momentary"
   Z-Wave                          Syncing - retrieved parameter 28 "Enable scene commands" is true
   Z-Wave                          Syncing - retrieved parameter 23 "Enable double-click to full brightness" is true
   Z-Wave                          Syncing - retrieved parameter 9 "Power up to last known state" is true
   Z-Wave                          Syncing - retrieved parameter 26 "Enable 3-way switch mode" is false
   Z-Wave                          Syncing - retrieved parameter 1 "Minimum value" is 4
   Z-Wave                          Syncing - retrieved parameter 2 "Maximum value" is 99
   Z-Wave                          Syncing - retrieved parameter 7 "Local dim delta" is 1
   Z-Wave                          Syncing - retrieved parameter 8 "Local dim timer" is 5 * 10 milliseconds
   Z-Wave                          Syncing - retrieved parameter 5 "On/Off dim delta" is 1
   Z-Wave                          Syncing - retrieved parameter 6 "On/Off dim timer" is 1 * 10 milliseconds
   Z-Wave                          Syncing - retrieved parameter 50 "Immediate power threshold" is 10 %
   Z-Wave                          Syncing - retrieved parameter 52 "Periodic report delay" is 3600 seconds
Sun Apr 08, 2018 3:42 pm
Re: Fibaro Dimmer 2 S2 Status
I'm not sure why it isn't updating, but the firmware version on yours is higher than some of the previous reports we've seen. Try turning on Indigo's Z-Wave debug logging checkbox via the Interfaces->Z-Wave->Configure... menu item, then toggle S2 a few times (pausing several seconds after each toggle). Copy/paste the Event Log window results into a reply so we can see what messages are being sent.
Sun Apr 08, 2018 4:02 pm
mclass offline
I’m also experiencing this issue but with firmware version 2.2
I have located this thread
viewtopic.php?f=58&t=18165&start=15
and understood this issue had been addressed.
I’ll watch with interest for an outcome!
mclass
EDIT: Whoops - my note refers to a Fibaro double relay - not a dimmer. My apologies!
Mon Apr 09, 2018 1:23 am
The s2 switch doesn't appear to be sending any messages when locally pressed. I know the switch is working because when scene commands are enabled I'm getting the following message back
Z-Wave Debug                    RCVD sceneActivateCmd: 01 0A 00 04 00 78 04 2B 01 1A 00 BD
   Z-Wave Debug                    . .  sceneActivateCmd: node 120, scene: 26
   Z-Wave                          received "120 - Kitchen dimmer" scene 26
and when I manually request the status of s2 the status is updated correctly
Z-Wave Debug                    SENT requestDimmerStatus: 01 0D 00 13 78 06 60 0D 01 02 26 02 25 B7 47
   Z-Wave Watcher Debug            Raw command sent (Node 120): 01 0D 00 13 78 06 60 0D 01 02 26 02 25 B7 47 (True)
   Z-Wave                          sent "120 - Switch 2" status request
A quick google search revealed this post on a different platform..https://www.domoticz.com/forum/viewtopic.php?t=15156 so I'm not on my own. Very frustrating. Maybe I'll try a Aeotec dimmer to see if I can get a device that actually works as advertised.
Colin
Mon Apr 09, 2018 3:06 am
The code you’ve quoted there, second, is for the outgoing request (“Raw command sent”).
If you’re not receiving a “Raw Command received” then it’s not sending one.
What associations are set - I wonder if Group 2 needs an association to Node 1? (Completely off top of my head)
Mon Apr 09, 2018 3:16 am
Right, I’ve just read the manual. Always a useful place to start. :-)
Set param 25 to 0, if it isn’t already.
And set association for groups 4 and 5 to Node 1.
That’s the reporting config for Switch 2.
Tue Apr 10, 2018 12:49 am
Hi Howard
Confirmed that parameter 25 is set to 0
Here's whats happening.
>s1 pressed<
Z-Wave Debug                    RCVD dimmerSetLevel: 01 09 00 04 08 79 03 20 01 00 A1
 Z-Wave Debug                    . .  dimmerSetLevel: node 121, endpoint None, value 0
 Z-Wave                          received "121 - Dimmable Load" status update is off
>s1 pressed again<
Z-Wave Debug                    RCVD dimmerSetLevel: 01 09 00 04 08 79 03 20 01 FF 5E
Z-Wave Debug                    . .  dimmerSetLevel: node 121, endpoint None, value 255
Z-Wave                          received "121 - Dimmable Load" status update is on
>s2 pressed< with no association g4,g5
nothing..
>s2 pressed< with association g4
s2 pressed with scene commands active
Z-Wave Debug                    RCVD sceneActivateCmd: 01 0A 00 04 00 79 04 2B 01 1A 00 BC
  Z-Wave Debug                    . .  sceneActivateCmd: node 121, scene: 26
  Z-Wave                          received "121 - Dimmable Load" scene 26
When pressing s2 with group 4 associated with Indigodomo it is sending the same message as if you had pressed s1.
However with scene commands active it is sending the correct scene numbers, Scene 16 for s1 and scene 26 for s2. So I guess I'll have to use that rather than status.
Colin
Tue Apr 10, 2018 1:13 am
Matt - can you explain the multi endpoints in the sync log in post 1 of this thread?
What are 11 and 01?
Peter
Wed Apr 11, 2018 10:54 am
Unfortunately, the Fibaro's are extremely fickle to get configured so they send the information Indigo (or any central controllers) wants. And to top it off, they change the behavior all the time in different firmware versions making it a moving target. For the time being I'd suggest just using the scene capability and triggers that catch the scene command (don't try to use S2's device state).
Peter: 11 01 just means that the both endpoints are of class/type Mulitlevel Switch (0x11 higher level) and Dimmable Power Switch (0x01 more specific). Indigo just uses that to know that it can send dim state requests via command 0x26 to both endpoints.
Thu Apr 12, 2018 3:16 am
Thanks Matt
The scene commands work just fine, so I'll stick with those.
Colin
Sun Jan 31, 2021 12:24 pm
juntta offline
I'm struggling to get these S2 scenes to work. I have Fibaro Switches with similar setup (normal PIR, which output L' connected to S2 input and PIR power feed is fed from SX terminal of Dimmer 2). With Switch 2 this setup & scenes just work but not now when I try the same with Dimmer 2.
So I have Parameter 28 set 1 and Indigo server in association group 4 but no cigar - no scene events when PIR motion event fired. Any ideas? I attached my Dimmer2 device properties below but version seems to be the same 3.05 as some have reported earlier.
Indigo Z-Wave Version: 7.5.0
Node ID: 99
Model: Dimmer Switch (FGD212)
Model ID: 01021000
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 4.24
Application Version: 3.05
Model Definition Version: 2
Library Type: 3
Class Name: Dimmable Power Switch
Class Hierarchy: 04 : 11 : 01
Command Class Base: 26
Command Versions: 20v1 60v4 22v1 26v3 86v1 27v1 7Av1 72v1 8Ev1 70v1 71v1 32v3 73v1 75v1 56v1 98v1 59v1 31v4 5Av1 5Ev1 85v1
Multi-Endpoint Types: 1:(11 : 01), 2:(11 : 01)
Multi-Endpoint Classes: 1:[5E 20 86 26 85 59 8E 32 31 71], 2:[5E 20 86 26 85 59 8E]
Features: routing, beaming, security, energyMeter
Neighbors: 22, 90, 91, 92, 93, 94, 95, 96, 101, 105, 108, 114, 116, 118, 120, 121, 122
Associations: 1:[1] 2:[1] 3:[] 4:[1] 5:[]
Config Values: 1:1 2:99 5:1 6:0 7:1 8:1 9:1 50:10 20:0 23:1 52:3600 26:0 28:1
Sun Jan 31, 2021 12:40 pm
juntta offline
Some debugging with Zwave watcher:
   Z-Wave                          received "Varaston kattovalot" scene 16
   Z-Wave Watcher Debug            Raw command received (Node 99): 01 0A 00 04 00 63 04 2B 01 10 00 AC
   Z-Wave                          received "Varaston kattovalot" status update brightness 100
   Trigger                         Varaston kattovalo päälle (Dimmer 2 S1 ON)
   Z-Wave Watcher Debug            Raw command received (Node 99): 01 09 00 04 00 63 03 26 03 63 D4
   Z-Wave Watcher Debug            Raw command received (Node 99): 01 0C 00 04 00 63 06 31 05 04 22 01 32 B3
   Z-Wave                          received "Varaston kattovalot" scene 12
   Z-Wave Watcher Debug            Raw command received (Node 99): 01 0A 00 04 00 63 04 2B 01 0C 00 B0
   Z-Wave                          received "Varaston kattovalot" status update is off
   Trigger                         Varaston kattovalo pois päältä (Dimmer 2 S1 OFF)
   Z-Wave Watcher Debug            Raw command received (Node 99): 01 09 00 04 00 63 03 26 03 00 B7
   Z-Wave                          received "Varaston kattovalot" scene 13
   Z-Wave Watcher Debug            Raw command received (Node 99): 01 0A 00 04 00 63 04 2B 01 0D 00 B1
   Z-Wave Watcher Debug            Raw command received (Node 99): 01 09 00 04 00 63 03 20 01 00 B3
   Z-Wave                          received "Varaston kattovalot" status update is on
   Z-Wave Watcher Debug            Raw command received (Node 99): 01 09 00 04 00 63 03 20 01 FF 4C
   Z-Wave Watcher Debug            Raw command received (Node 99): 01 0C 00 04 00 63 06 31 05 04 22 01 2C AD
   Z-Wave Watcher Debug            Raw command received (Node 99): 01 0C 00 04 00 63 06 31 05 04 22 00 00 80
   Z-Wave Watcher Debug            Raw command sent (Node 99): 01 0A 00 13 63 03 32 01 00 25 82 12 (True)
   Z-Wave Watcher Debug            Raw command received (Node 99): 01 10 00 04 00 63 0A 32 02 21 44 00 00 01 37 00 00 E1
   Z-Wave Watcher Debug            Raw command sent (Node 99): 01 0A 00 13 63 03 32 01 10 25 83 03 (True)
   Z-Wave Watcher Debug            Raw command received (Node 99): 01 0E 00 04 00 63 08 32 02 21 32 00 00 00 00 BD
Sat Feb 06, 2021 5:06 pm
Your Event Log is showing that Indigo is detecting the scene buttons:
so it looks like it is working? Did you device Triggers based on those scene commands?
Sun Feb 07, 2021 12:11 am
juntta offline
On S1 input scenes do work but on S2 input there should be 26, 22 and 23 and those cannot be triggered at the moment.
Sun Feb 07, 2021 1:00 pm
I see. From the manual I don't see any other parameters besides #28 which should enable scenes for both S1 and S2. I think you'll need to contact Fibaro support to see what they say.
