Qubino Flush 1 - temperature drops out after server restart
Tue Apr 03, 2018 2:18 am
haavarda offline
I have a strange issue with a Qubino Flush 1 device. After the server is restarted the temperature drops out and is not update.
A sync fixes it, and it regularly updates again. Any idea what could cause this?
  Z-Wave                          Syncing - started for "Light - Carport"
   Z-Wave                          Syncing - retrieved module neighbors list: 6, 7, 8, 10, 18, 24, 31, 46, 47, 48, 71, 80, 82, 100, 118, 140
   Z-Wave                          Syncing - assigning return route to "136 - Light - Carport"
   Z-Wave                          Syncing - retrieved manufacture and model names: Qubino - 0159, Flush 1 Micro Relay (ZMNHAD) - 00020052
   Z-Wave                          Syncing - retrieved protocol version 4.05, app version 1.01
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
   Z-Wave                          Syncing - retrieved command classes: 20v1 60v4 25v1 86v1 27v1 72v1 8Ev1 70v1 31v7 32v4 73v1 59v1 5Av1 5Ev1 85v1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, beaming
   Z-Wave                          Syncing - retrieved multi-endpoint types: 1:(10 : 01), 2:(21 : 01)
   Z-Wave                          Syncing - retrieved multi-endpoint classes: 1:[5E 86 20 27 25 32 85 8E 59], 2:[5E 86 31 85 8E 59]
   Z-Wave                          Syncing - retrieved group 1 associations: [1]
   Z-Wave                          Syncing - retrieved group 2 associations: []
   Z-Wave                          Syncing - retrieved group 3 associations: []
   Z-Wave                          Syncing - retrieved group 4 associations: []
   Z-Wave                          Syncing - retrieved group 5 associations: []
   Z-Wave                          Syncing - retrieved group 6 associations: []
   Z-Wave                          Syncing - retrieved group 7 associations: []
   Z-Wave                          Syncing - retrieved group 8 associations: []
   Z-Wave                          Syncing - retrieved group 9 associations: []
   Z-Wave                          Syncing - group 1 association to interface already exists (skipping)
   Z-Wave                          Syncing - added group 2 multi association to interface
   Z-Wave                          Syncing - added group 9 multi association to interface
   Z-Wave                          Syncing - retrieved parameter 30 "Power up state" is 1 "Off"
   Z-Wave                          Syncing - retrieved parameter 100 "Input 2 notifications" is 0 "Disabled"
   Z-Wave                          Syncing - retrieved parameter 101 "Input 3 notifications" is 0 "Disabled"
   Z-Wave                          Syncing - module returned parameter 101 instead of parameter 1 "Input 1 mode" (ignoring)
   Z-Wave                          Syncing - retrieved parameter 1 "Input 1 mode" is 1 "Toggle"
   Z-Wave                          Syncing - retrieved parameter 2 "Input 2 type" is 0 "Normally Open"
   Z-Wave                          Syncing - retrieved parameter 3 "Input 3 type" is 0 "Normally Open"
   Z-Wave                          Syncing - retrieved parameter 63 "Output type" is 0 "Normally Closed"
   Z-Wave                          Syncing - retrieved parameter 110 "Temperature offset" is 0 * 0.1 degrees
   Z-Wave                          Syncing - retrieved parameter 120 "Temperature sensitivity" is 4 * 0.1 degrees
Håvard
Håvard
Fri Apr 06, 2018 6:33 am
Re: Qubino Flush 1 - temperature drops out after server rest
I'm not sure what is causing this. Does it consistently happen every time the Indigo Server is restarted, and I wonder if it is a Mac restart or Indigo Server restart that triggers it? What happens if you restart it immediately, versus waiting several minutes or an hour?
I wonder if the problem only occurs if the module tries to send a temperature value to the Z-Stick but it isn't powered up so it gets back a NAK. That shouldn't cause it to stop sending the sensor updates later, but maybe it is.
Tue Apr 10, 2018 4:24 am
haavarda offline
In the plot below you can see the Qubino module. The plot starts when I restart the indigo server (not the mac). As you can see, no change is recorded until I do a sync some hours later. Then it starts to record the changes again. I have placed a Fibaro multi sensor with a temp module right next to the fibaro, and as you can see that one works perfect.
outside temp.jpg (431.29 KiB) Viewed 623 times
Håvard
Users browsing this forum: Google [Bot] and 24 guests
