Hi all,
Trying to get my head around how to wire up a Fibaro relay to control a 12v device (lock plate).
If my understanding is correct I'll use a normal UK 3 pin mains plug and wire that to the Live and Neutral terminals of the Relay.
Then I need a separate 12v power supply that I wire one side to the relay IN, then a wire from Q1 to one side of the device, then the other side of the device to the other side of the 12v PSU.
Wiring side makes sense I think.
Physically in terms of any required separation etc what do I need to do?
I have a twin plug socket in exactly the right place. Can I simply wall mount a single gang enclosure, run the wire from the mains plug and the 12v psu up and into the enclosure and job done?
Or are there some concerns I should have around separation etc?
Also...what do I do about the Earth wire from the UK mains plug?
Cheers all
Noel
