- Posted on
Sat Mar 31, 2018 9:47 am
PME999
offline
Hello Matt
Here the result with another AN158 which is not syncing until the end
Thanks a lot
Patrice
Z-Wave Syncing - started for "024 - Relay Power Switch"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 18 01 01 61
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 62 6C 23 10 10 80 00 08 00 80 D7 0C 00 50 C2 36 1A 5C 05 46 16 00 20 00 00 00 00 10 18 3F
Z-Wave Debug . . getNodeNeighbors: nodeId 024, neighbors: 2, 6, 7, 11, 12, 14, 15, 17, 18, 22, 29, 37, 48, 60, 80, 81, 82, 83, 85, 87, 88, 91, 92, 109, 111, 114, 119, 120, 122, 123, 125, 126, 130, 132, 133, 139, 140, 141, 143, 145, 147, 154, 155, 159, 162, 163, 165, 182, 221, 228, 229
Z-Wave Syncing - retrieved module neighbors list: 2, 6, 7, 11, 12, 14, 15, 17, 18, 22, 29, 37, 48, 60, 80, 81, 82, 83, 85, 87, 88, 91, 92, 109, 111, 114, 119, 120, 122, 123, 125, 126, 130, 132, 133, 139, 140, 141, 143, 145, 147, 154, 155, 159, 162, 163, 165, 182, 221, 228, 229
Z-Wave Syncing - assigning return route to "024 - Relay Power Switch"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 18 BC 18
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 024, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 18 24 EB 4E
Z-Wave Debug RCVD nodeInfoFrame: 01 11 00 49 84 18 0B 04 10 01 25 20 72 86 27 85 32 70 34
Z-Wave Debug . . nodeInfoFrame: node 024, combined class list: 20v1 85v1 86v1 27v1 72v1 70v1 32v1 25v1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 18 02 72 04 25 EC 40
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 18 08 72 05 00 60 00 04 00 02 F4
Z-Wave Debug . . requestManufactureInfo: node 024, manufacturerId 0060, productId 00040002
Z-Wave Debug . . requestManufactureInfo: Everspring, Appliance Module (AN158)
Z-Wave Syncing - retrieved manufacture and model names: Everspring - 0060, Appliance Module (AN158) - 00040002
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 18 02 86 11 25 ED A0
Z-Wave Debug RCVD requestVersInfoGen: 01 0D 00 04 00 18 07 86 12 06 02 40 01 01 39
Z-Wave Debug . . requestVersInfoGen: node 024, protoVers 2.64, appVers 1.01
Z-Wave Syncing - retrieved protocol version 2.64, app version 1.01
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 18 03 86 13 32 25 EE 91
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 18 04 86 14 32 02 4F
Z-Wave Debug . . requestVersInfoCmdClass: node 024, class command 32 using version 2
Z-Wave Debug . . requestVersInfoCmdClass: node 024, combined class list: 20v1 85v1 86v1 27v1 72v1 70v1 32v2 25v1
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 85v1 86v1 27v1 72v1 70v1 32v2 25v1
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 18 02 85 05 25 EF B5
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 18 03 85 06 02 68
Z-Wave Debug . . requestAssociationGroupCount: node 024, group count: 2
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 07 06 31 05 04 22 00 03 E7
Z-Wave Debug . . requestVarSensorStatus: node 007, endpoint None, type 4, raw value 2200...
Z-Wave Debug . . requestVarSensorStatus: 0.3 W (float: 0.300000)
Z-Wave Debug received "Prise Lave Vaisselle" power load to 0.3 W
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 18 03 85 02 01 25 F0 AE
Z-Wave Debug RCVD requestAssociations: 01 0C 00 04 00 18 06 85 03 01 01 00 BC D3
Z-Wave Debug . . requestAssociations: node 024, group: 1, num associations: 1, max associations: 1, replies left: 0
Z-Wave Debug . . requestAssociations: node 024, group: 1, associations: [188]
Z-Wave Syncing - retrieved group 1 associations: [188]
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 18 03 85 02 02 25 F1 AC
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 18 05 85 03 02 04 00 6D
Z-Wave Debug . . requestAssociations: node 024, group: 2, num associations: 0, max associations: 4, replies left: 0
Z-Wave Debug . . requestAssociations: node 024, group: 2, associations: []
Z-Wave Debug SENT requestMeterInfo: 01 09 00 13 18 02 32 03 25 F2 19
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 07 06 31 05 04 22 00 00 E4
Z-Wave Debug . . requestVarSensorStatus: 0.0 W (float: 0.000000)
Z-Wave Debug received "Prise Lave Vaisselle" power load to 0.0 W
Z-Wave Debug RCVD requestMeterLevel: 01 0E 00 04 00 06 08 32 02 21 12 00 00 00 00 F8
Z-Wave Debug . . requestMeterLevel: node 006, endpoint None, meterType 01, raw value 1200...
Z-Wave Debug . . requestMeterLevel: 0 W (float: 0.000000)
Z-Wave Debug timeout waiting for reply from module (retrying)
Z-Wave Debug SENT requestMeterInfo: 01 09 00 13 18 02 32 03 25 F3 18
Z-Wave Debug RCVD requestMeterLevel: 01 0E 00 04 00 0B 08 32 02 21 12 00 01 00 00 F4
Z-Wave Debug . . requestMeterLevel: node 011, endpoint None, meterType 01, raw value 1200...
Z-Wave Debug . . requestMeterLevel: 1 W (float: 1.000000)
Z-Wave Debug RCVD requestMeterLevel: 01 0E 00 04 00 12 08 32 02 21 12 00 01 00 00 ED
Z-Wave Debug . . requestMeterLevel: node 018, endpoint None, meterType 01, raw value 1200...
Z-Wave Debug RCVD requestMeterLevel: 01 0E 00 04 00 11 08 32 02 21 12 00 05 00 00 EA
Z-Wave Debug . . requestMeterLevel: node 017, endpoint None, meterType 01, raw value 1200...
Z-Wave Debug . . requestMeterLevel: 5 W (float: 5.000000)
Z-Wave received "Prise Lave et Seche Linge" power load to 5 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 50 0A 32 02 21 44 00 00 00 27 00 00 C3
Z-Wave Debug . . requestMeterLevel: node 080, endpoint None, meterType 01, raw value 4400...
Z-Wave Debug . . requestMeterLevel: 0.39 kWh (float: 0.390000)
Z-Wave Debug . . requestVarSensorStatus: ignored (no device found for dispatch)
Z-Wave Debug SENT requestMeterInfo: 01 09 00 13 18 02 32 03 25 F4 1F
Z-Wave Debug RCVD requestMeterLevel: 01 0E 00 04 00 B8 08 32 02 21 12 00 00 00 00 46
Z-Wave Debug . . requestMeterLevel: node 184, endpoint None, meterType 01, raw value 1200...
Z-Wave Debug RCVD requestMeterLevel: 01 0E 00 04 00 3C 08 32 02 21 12 00 00 00 00 C2
Z-Wave Debug . . requestMeterLevel: node 060, endpoint None, meterType 01, raw value 1200...
Z-Wave Debug RCVD requestMeterLevel: 01 0E 00 04 00 90 08 32 02 21 12 00 00 00 00 6E
Z-Wave Debug . . requestMeterLevel: node 144, endpoint None, meterType 01, raw value 1200...
Z-Wave Debug maximum retry count exceeded waiting reply from module
Z-Wave Error Syncing - failed
Z-Wave Error Timeout waiting for "024 - Relay Power Switch". Module might be asleep, or is unreachable.
