ID Lock 150
Sat Mar 10, 2018 2:11 pm
haakon offline
ID Lock 150
Hi, ID Lock 101 is listed among Indigo’s supported devices. Will the more recent model, ID Lock 150, work as well?
Or will support for that model come in a later release? (If so: Any idea when?)
Thanks in advance.
Haakon
Sat Mar 10, 2018 3:14 pm
Re: ID Lock 150
I don't see any reports of folks using that one yet, but it will probably work.
Sat Jan 18, 2020 1:27 pm
Raven offline
Re: ID Lock 150
First post from newbie (trial) user :D (sorry for my poor English)
I have added some dimmers with success and ease. Great!
BUT, I have already run into a little problem: When i try to add my lock ”ID Lock 150”. It is included fine, but when i try to sync it fails, and the following lines show up in the event log:
17 jan. 2020 17:41:51
Z-Wave Syncing - started for "007 - Keypad Door Lock"
Z-Wave Syncing - assigning return route to "007 - Keypad Door Lock"
Z-Wave Error rcvd incomplete interface packet (skipping): 01 26 00 04 00 1C 20 98
Z-Wave Error rcvd unexpected bytes (sent ACK): 81 C8 D4 79 4D 7F FE A0 F7 3A F4 E6 FD 22 7F 56 06 13 C6 8E BF 57 73 5C 56 F1 14 05 9A 67 E1 E8 01 26 00 04 00 1C 20 98
Z-Wave Error rcvd unexpected bytes (sent ACK): 81 C8 D4 79 4D 7F FE A0 F7 3A F4 E6 FD 22 7F 56 06 13 C6 8E BF 57 73 5C 56 F1 14 05 9A 67 E1 E8 06 01 04 01 13 01 E8
Z-Wave Syncing - retrieved manufacture and model names: Unknown - 0373, Keypad Door Lock - 00030001
17 jan. 2020 17:42:38
Z-Wave Error Syncing - failed
Z-Wave Error Timeout waiting for "007 - Keypad Door Lock". Module might be asleep, or is unreachable.
I have the lock and the server approx 10cm apart.
I realize this is because I’m doing something wrong. But can someone please tell me how to do it the right way?
Sat Jan 18, 2020 1:41 pm
jalves offline
Re: ID Lock 150
Did you include the device with encryption on?
Jeff
Sat Jan 18, 2020 1:43 pm
RogueProeliator offline
Re: ID Lock 150
Almost always the first thing I would try to do is get it excluded and then try the include again -- make sure you include with encryption. Capture the logs when including and synchronization (assuming it fails again), just in case, and post those here.
Adam
Sun Jan 19, 2020 3:03 pm
Raven offline
Re: ID Lock 150
Thanks guys for trying to help me out!
I did include the lock with Encryption ON. Several times. And it included just fine every time. But the following sync fails with the messages from the event log I attached previously.
I also have excluded and included the lock several times. And performed a Z-Wave reset a couple of times (on the lock). But no success.
Successfully upgraded the locks Z-Wave firmware, with newest firmware from lock manufacturer (using PC). Tried all the above steps again without success. The lock is not sleeping as far as I can tell: For example it responds to the Z-Wave upgrade software without a previous “wake-up touch”.
Guess I’m misunderstanding you? I’ve already pasted the log? Or is it a different log You are talking about?
Regards
Anders
Sun Jan 19, 2020 3:32 pm
Re: ID Lock 150
User RAID5 is using an ID Lock 150 with my Lock Manager plugin so presumably has no problems with including/syncing.
Raven, you've pasted the logs for re-syncing the lock.
Can you paste logs of the inclusion process, which has far more data in it.
Sun Jan 19, 2020 3:47 pm
Raven offline
Re: ID Lock 150
Sounds promising that someone (who know what he is doing) is successful.
I’ll do a new exclude/include first thing tomorrow. And post the correct logs afterwards.
Thanks for helping! (I've already installed Your plugin and are eagerliy waiting to use it :D )
Mon Jan 20, 2020 6:19 am
Raven offline
Re: ID Lock 150
Below are the logs when first excluding, and the including the lock.
20 jan. 2020 13:03:33
Z-Wave started controller exclusion mode
20 jan. 2020 13:03:58
Z-Wave controller excluded module: 028 - Keypad Door Lock
Z-Wave stopped controller exclusion mode
20 jan. 2020 13:05:01
Z-Wave started controller inclusion mode with encryption
20 jan. 2020 13:07:08
Z-Wave controller included module: 029 - Keypad Door Lock
Z-Wave querying module for encryption support
Z-Wave starting encryption key exchange with module
Z-Wave completed encryption key exchange with module
Z-Wave stopped controller inclusion mode
Z-Wave Syncing - started for "029 - Keypad Door Lock"
Z-Wave Syncing - retrieved module neighbors list: 2, 7, 8, 9
Z-Wave Syncing - assigning return route to "029 - Keypad Door Lock"
Z-Wave Error rcvd incomplete interface packet (skipping): 01 26 00 04 00 1D 20 98
Z-Wave Error rcvd unexpected bytes (sent ACK): 81 D7 7D 2C BB 54 FC 29 21 AC AD 37 DD A3 70 EF 03 FD 54 47 0E 9A FA B3 F3 BA BB 7B 98 84 8D 9B 01 26 00 04 00 1D 20 98
Z-Wave Error rcvd unexpected bytes (sent ACK): 81 D7 7D 2C BB 54 FC 29 21 AC AD 37 DD A3 70 EF 03 FD 54 47 0E 9A FA B3 F3 BA BB 7B 98 84 8D 9B 06 01 04 01 13 01 E8
20 jan. 2020 13:08:03
Z-Wave Error Timeout waiting for "029 - Keypad Door Lock". Module might be asleep, or is unreachable.
Mon Jan 20, 2020 7:58 am
Re: ID Lock 150
I think Raven is commuting identity fraud, trying to pass himself off as Matt...?!
Mon Jan 20, 2020 8:07 am
Raven offline
Re: ID Lock 150
:D Sorry! How did i managed to do that?? (I can not see it myself though?)
Mon Jan 20, 2020 8:14 am
McJohn offline
Re: ID Lock 150
I think it's the Tapatalk client of Peter's old Nokia :P ? because here we didn't see that fraud :shock:
Mon Jan 20, 2020 8:26 am
Raven offline
Re: ID Lock 150
:lol:
Mon Jan 20, 2020 2:14 pm
Re: ID Lock 150
It looks like the inclusion and key exchange with the module completed successfully, but then the syncing failed.
Re-try just re-syncing it a few (say 3 more) times. Copy/paste the Event Log results. I'm wondering if it always fails in the same spot or not. Also turn on Indigo's Z-Wave debug logging checkbox (via the Interfaces->Z-Wave->Configuration... menu item) so we can more detailed logging.
Mon Jan 20, 2020 3:13 pm
Raven offline
Re: ID Lock 150
Additional log entries with debugging on as requested.
This time I was lazy and didn’t move the controller close to the lock. I you think it’ll make a difference I’ can absolutely do that and send new log.
20 jan. 2020 21:40:34
Z-Wave Debug stopping node healing thread
Z-Wave Debug stopping node status polling thread
Z-Wave Debug stopped zwave packet parser thread
Z-Wave connection reset requested
Z-Wave Debug starting serial connection loop
Z-Wave Debug starting zwave packet parser thread
Z-Wave Debug SENT getVersion: 01 03 00 15 E9
Z-Wave Debug RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 33 2E 39 35 00 01 99
Z-Wave Debug . . getVersion: Z-Wave 3.95 static controller
Z-Wave Debug SENT getHomeID: 01 03 00 20 DC
Z-Wave Debug RCVD getHomeID: 01 08 01 20 F8 0A 7A 86 01 D9
Z-Wave Debug . . getHomeID: F80A7A86, nodeID: 001
Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9
Z-Wave Debug RCVD getInterfaceFeatures: 01 04 01 05 18 E7
Z-Wave Debug . . getInterfaceFeatures: 18
Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB
Z-Wave Debug RCVD getInterfaceApiCapabilities: 01 2B 01 07 01 00 00 86 00 01 00 5A FE 81 FF 88 4F 1F 00 00 FB 9F 7D A0 67 00 00 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00 FB
Z-Wave Debug . . getInterfaceApiCapabilities: supportedFuncIDs: 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 1C 20 21 22 23 24 27 29 2A 2B 2C 2D 41 42 44 45 46 47 48 49 4A 4B 4C 4D 50 51 53 54 55 56 57 5E 60 61 62 63 66 67 80 90 92 93 98 B4 B6 B7 B8 B9 BA BD BE BF D2 D3 D4 EE EF
Z-Wave Debug . . getInterfaceApiCapabilities: serialApi 1.00, manufactureId 0086, productType 0001, productId 005A
Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodem221 (firmware 1.00)
Z-Wave Debug SENT forceSUC: 01 05 00 54 01 01 AE
Z-Wave Debug RCVD forceSUC: 01 04 01 54 01 AF
Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE
Z-Wave Debug RCVD getInitialNodeData: 01 25 01 02 05 08 1D E3 01 03 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 3D
Z-Wave Debug . . getInitialNodeData: is static update controller
Z-Wave Debug . . getInitialNodeData: [1, 2, 6, 7, 8, 9, 17, 18, 29]
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 93 16 01 02 02 01 33
Z-Wave Debug . . getNodeProtocolInfo: node 001, class name: Static Computer Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
Z-Wave Debug . . getNodeProtocolInfo: features: beaming
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 02 B8
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 10 01 ED
Z-Wave Debug . . getNodeProtocolInfo: node 002, class name: Relay Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 06 BC
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 11 01 EC
Z-Wave Debug . . getNodeProtocolInfo: node 006, class name: Dimmable Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 26
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 26 27
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 07 BD
Z-Wave Debug . . getNodeProtocolInfo: node 007, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 08 B2
Z-Wave Debug . . getNodeProtocolInfo: node 008, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 09 B3
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 21 01 DC
Z-Wave Debug . . getNodeProtocolInfo: node 009, class name: Multilevel Sensor (routing)
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Multilevel Sensor : Multilevel Sensor (routing) (04 : 21 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 31
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 31
Z-Wave Debug overriding node 009 type from zwValueSensorType to zwOnOffSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 11 AB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 DC 01 04 40 03 7F
Z-Wave Debug . . getNodeProtocolInfo: node 017, class name: Keypad Door Lock
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Entry Control : Keypad Door Lock (04 : 40 : 03)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 62
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 62 63 86 72 98
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming, security, frequentWaking
Z-Wave found module included in controller with no matching device (missing or disabled): 017 - Keypad Door Lock
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 12 A8
Z-Wave Debug . . getNodeProtocolInfo: node 018, class name: Keypad Door Lock
Z-Wave found module included in controller with no matching device (missing or disabled): 018 - Keypad Door Lock
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1D A7
Z-Wave Debug . . getNodeProtocolInfo: node 029, class name: Keypad Door Lock
Z-Wave found module included in controller with no matching device (missing or disabled): 029 - Keypad Door Lock
Z-Wave Debug starting node healing thread
Z-Wave Debug starting node status polling thread
20 jan. 2020 21:41:16
Z-Wave Debug intiatingSyncUI (timeout in 1500 seconds)
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 1D 01 01 64
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 C2 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9D
Z-Wave Debug . . getNodeNeighbors: nodeId 029, neighbors: 2, 7, 8, 9
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 1D 01 A0
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 029, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 1D 24 F6 56
Z-Wave Debug RCVD nodeInfoFrame: 01 0F 00 49 84 1D 09 04 40 03 5E 72 98 5A 73 70 83
Z-Wave Debug . . nodeInfoFrame: node 029, combined class list: 20v1 70v1 62v1 63v1 86v1 98v1 5Av1 72v1 5Ev1 73v1
Z-Wave Debug SENT nonceRequest: 01 09 00 13 1D 02 98 40 25 F7 F0
Z-Wave Debug RCVD nonceReport: node 029, nonce 30 38 A2 0C C2 4E 18 D8
Z-Wave Debug SENT requestEncryptedCmdClasses: 98 02 (encrypted)
Z-Wave Debug RCVD nonceFetch: node 029
Z-Wave Debug SENT nonceReport: 01 11 00 13 1D 0A 98 80 02 CF FE 87 45 12 EF 6B 25 F9 49
Z-Wave Error rcvd unexpected bytes (sent ACK): 81 69 2D 7E C3 C4 27 15 23 81 1C 8F 88 43 01 02 D7 65 49 4E 34 68 02 72 BA 40 F5 E1 D7 C5 FF 95 01 26 00 04 00 1D 20 98
Z-Wave Debug timeout waiting for module command after sending nonce report (not critical)
Z-Wave Debug timeout waiting for reply from module (non-fatal, skipping request)
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 1D 02 72 04 25 FA 53
Z-Wave Error rcvd unexpected bytes (sent ACK): 81 69 2D 7E C3 C4 27 15 23 81 1C 8F 88 43 01 02 D7 65 49 4E 34 68 02 72 BA 40 F5 E1 D7 C5 FF 95 06 01 04 01 13 01 E8
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 1D 02 72 04 25 FA 53 (re-sent because no response)
Z-Wave Debug . . requestManufactureInfo: requeuing 2 unsolicited packets
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 1D 08 72 05 03 73 00 03 00 01 E5
Z-Wave Debug . . requestManufactureInfo: node 029, manufacturerId 0373, productId 00030001
Z-Wave Debug . . requestManufactureInfo: Unknown, Keypad Door Lock
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 1D 02 86 11 25 FB B3
Z-Wave Debug RCVD packet: 01 07 00 13 FB 00 00 68 78 (hex)
Z-Wave Debug timeout waiting for reply from module (retrying)
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 1D 02 86 11 25 FC B4
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 1D 02 86 11 25 FD B5
Z-Wave Debug maximum retry count exceeded waiting reply from module
20 jan. 2020 21:43:00
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 1D 24 FE 5E
Z-Wave Debug SENT nonceRequest: 01 09 00 13 1D 02 98 40 25 FF F8
Z-Wave Debug RCVD nonceReport: node 029, nonce 78 18 96 21 F2 F0 20 77
Z-Wave Debug SENT nonceReport: 01 11 00 13 1D 0A 98 80 5B 6E 07 7D C3 43 68 E7 25 02 95
Z-Wave Error rcvd unexpected bytes (sent ACK): 81 72 23 E2 51 22 5A 75 7F 3C 6A 12 99 DF 4C 44 BF 2F BA A3 5B C4 5B 97 45 E8 15 16 5F 7E 79 4F 01 26 00 04 00 1D 20 98
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 1D 02 72 04 25 03 AA
Z-Wave Error rcvd unexpected bytes (sent ACK): 81 72 23 E2 51 22 5A 75 7F 3C 6A 12 99 DF 4C 44 BF 2F BA A3 5B C4 5B 97 45 E8 15 16 5F 7E 79 4F 06 01 04 01 13 01 E8
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 1D 02 72 04 25 03 AA (re-sent because no response)
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 1D 02 86 11 25 04 4C
Z-Wave Debug RCVD packet: 01 07 00 13 04 00 00 67 88 (hex)
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 1D 02 86 11 25 05 4D
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 1D 02 86 11 25 06 4E
20 jan. 2020 21:44:06
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 1D 24 07 A7
Z-Wave Debug SENT nonceRequest: 01 09 00 13 1D 02 98 40 25 08 0F
Z-Wave Debug RCVD nonceReport: node 029, nonce 65 1C 3D 4A 13 CF 2F 1F
Z-Wave Debug SENT nonceReport: 01 11 00 13 1D 0A 98 80 17 B3 8B A7 15 B3 2A CD 25 0A 14
Z-Wave Error rcvd unexpected bytes (sent ACK): 81 37 64 65 32 F4 A4 44 F8 53 4E 07 CD D8 F6 9E 0E 6F DE 1F 92 57 17 98 4E 8C DD 5F 39 C9 C4 E8 01 26 00 04 00 1D 20 98
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 1D 02 72 04 25 0B A2
Z-Wave Error rcvd unexpected bytes (sent ACK): 81 37 64 65 32 F4 A4 44 F8 53 4E 07 CD D8 F6 9E 0E 6F DE 1F 92 57 17 98 4E 8C DD 5F 39 C9 C4 E8 06 01 04 01 13 01 E8
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 1D 02 72 04 25 0B A2 (re-sent because no response)
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 1D 02 86 11 25 0C 44
Z-Wave Debug RCVD packet: 01 07 00 13 0C 00 00 69 8E (hex)
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 1D 02 86 11 25 0D 45
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 07 0E 32 02 21 34 00 00 03 8D 00 00 00 00 00 00 4D
Z-Wave Debug . . requestMeterLevel: node 007, endpoint None, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 90.9 W (float: 90.900000)
Z-Wave received "Matbord" power load to 90.9 W
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 1D 02 86 11 25 0E 46
20 jan. 2020 21:45:36
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 1D 24 0F AF
Z-Wave Debug SENT nonceRequest: 01 09 00 13 1D 02 98 40 25 10 17
Z-Wave Debug RCVD nonceReport: node 029, nonce F9 52 3C 51 2D 25 0E 8D
Z-Wave Debug SENT nonceReport: 01 11 00 13 1D 0A 98 80 9C D6 65 36 80 E8 9D AB 25 12 82
Z-Wave Error rcvd unexpected bytes (sent ACK): 81 9A 9D DA 30 BD 48 52 CC 0F 55 7E F6 89 74 DD 00 FE B0 28 85 D2 9C EF 5C 8B F8 95 E5 15 AD 28 01 26 00 04 00 1D 20 98
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 1D 02 72 04 25 13 BA
Z-Wave Error rcvd unexpected bytes (sent ACK): 81 9A 9D DA 30 BD 48 52 CC 0F 55 7E F6 89 74 DD 00 FE B0 28 85 D2 9C EF 5C 8B F8 95 E5 15 AD 28 06 01 04 01 13 01 E8
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 1D 02 72 04 25 13 BA (re-sent because no response)
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 1D 02 86 11 25 14 5C
Z-Wave Debug RCVD packet: 01 07 00 13 14 00 00 66 99 (hex)
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 1D 02 86 11 25 15 5D
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 1D 02 86 11 25 16 5E
20 jan. 2020 21:48:21
Users browsing this forum: No registered users and 32 guests
