Re-instate Encrypted Devices
Sun Mar 04, 2018 12:59 pm
AndyVirus offline
I had my HDD FS corruption. I was able to deregister my license and i already had backups of my Indigo directory and DB.
I wiped and re-installed OSX.
I re-installed Indigo and all plugins.
All works... except...
My locks now no longer communicate. When i sync'd them i sync'd them as encrypted. They worked great prior to the rebuild.
Now they just do communicate. I thought the Z-Wave stick would hold the keys but now I am thinking maybe its a software side key pair? If so i still have a backup of the indigo dir, is there a file or files i need to put back?
Basically am i boned or is there a fix as I you cant exclude these devices to re-include unless done by the original system (which has not changed other than OSX and and Indigo re-install)
They are Yale Keyfree Connected Locks and a Yale Keyless Connected lock.
Any advise would be greatly appreciated.
Sun Mar 04, 2018 1:06 pm
AndyVirus offline
Re: Re-instate Encrypted Devices
If i try to re-sync I get:
Z-Wave Syncing - started for "Front Door Lock"
Z-Wave Syncing - retrieved module neighbors list: 10, 11, 12, 21, 30, 31, 37, 38, 40, 41, 42, 43, 44, 46, 47, 48, 49, 50, 53, 54, 55, 56, 57, 58, 59, 60
Z-Wave Syncing - assigning return route to "074 - Front Door Lock"
Z-Wave Syncing - retrieved manufacture and model names: Yale - 0129, Keyfree Connected Lock - 00060000
Z-Wave Syncing - retrieved protocol version 3.34, app version 22.32
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Entry Control : Keypad Door Lock (04 : 40 : 03, base 62)
Z-Wave Syncing - retrieved command classes: 20v1 62v1 63v1 86v1 98v1 72v1
Z-Wave Syncing - retrieved encrypt commands: 80 85 86 8A 8B 4C 4E 98 62 63 70 71 72 75
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, security, frequentWaking
Z-Wave Error Syncing - failed
Z-Wave Error Timeout waiting for "074 - Front Door Lock". Module might be asleep, or is unreachable.
Sun Mar 04, 2018 1:14 pm
You can exclude any Z-Wave module with any Z-Wave interface (Z-Stick, etc.) even if it wasn't the original one to include it. So you should be able to exclude the module using Indigo or manually using the Z-Stick, then re-include it using Indigo w/ encryption enabled.
Sun Mar 04, 2018 1:27 pm
AndyVirus offline
Unfortunately not with the Yale modules it seems. I tried and exclusion does not happen, just times out. If it try to include in gives errors. I had this once before with a yale module and in the end i had to get a replacement as there is no way to exclude unless by the same system.
Page 21 of the manual back this up also : https://www.yale.co.uk/Yale/Yale_co_uk/ ... 014-2%20(1).pdf
"For security reasons a lock will not connect to a new home automation system if it is linked to another. If you have changed your home automation system please run through the disconnecting settings before adding the new one."
Sun Mar 04, 2018 1:28 pm
AndyVirus offline
Tried to reply to your PM but could not. I have it all working again now thanks to your info.
Users browsing this forum: No registered users and 18 guests
