HomeSeer HS-LS100+ Z-Wave Plus Leak Sensor
Sun Feb 04, 2018 4:26 pm
smillerdad offline
I'm trying to incorporate the HomeSeer water sensor even though it is not in the included hardware list. Maybe that is my problem. I can "include" the device, read and change advanced settings but the only response I can get from the device is: " received "003 - Notification Sensor" status update battery level 99%."
I get this message when I "wet' the device and the same message when I "dry"the device.
I had different issues trying a Veraedge controller.
Am I overlooking something or is this device simply not going to work with Indigo at this time? Indigo certainly knows a lot about the device. Log below.
Thanks.
Steve
Feb 4, 2018, 3:13:32 PM
Z-Wave started controller inclusion mode
Feb 4, 2018, 3:14:01 PM
Z-Wave controller included module: 003 - Notification Sensor
Z-Wave stopped controller inclusion mode
Z-Wave Syncing - started for "003 - Notification Sensor"
Z-Wave Syncing - assigning return route to "003 - Notification Sensor"
Z-Wave Syncing - retrieved manufacture and model names: HomeSeer - 000C, Notification Sensor - 0201000A
Z-Wave Syncing - retrieved protocol version 4.61, app version 1.02
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 55v1 59v1 5Av1 5Ev1 20v1 70v1 71v1 6Cv1 30v1 31v5 72v1 73v1 7Av1
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
Z-Wave Syncing - retrieved wake interval of 0 minutes
Z-Wave Syncing - device "003 - Notification Sensor" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - retrieved battery level of 99%
Z-Wave Syncing - created device "003 - Notification Sensor"
Z-Wave Syncing - complete
Z-Wave sent "003 - Notification Sensor" status request
Z-Wave received "003 - Notification Sensor" status update battery level 99%
Feb 4, 2018, 3:14:32 PM
Z-Wave received "003 - Notification Sensor" status update battery level 87%
Feb 4, 2018, 3:15:25 PM
Z-Wave Indigo Device "A Homeseer Leak Detector" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.111
Node ID: 3
Model: Notification Sensor
Model ID: 0201000A
Manufacturer: HomeSeer
Manufacturer ID: 000C
Protocol Version: 4.61
Application Version: 1.02
Model Definition Version: 0
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 80v1 84v2 85v1 86v1 55v1 59v1 5Av1 5Ev1 20v1 70v1 71v1 6Cv1 30v1 31v5 72v1 73v1 7Av1
Features: routing, battery, beaming, waking
Neighbors: - none -
Associations: 1:[1] 2:[]
Config Values: - none
smillerdad
Mon Feb 05, 2018 1:33 pm
Re: HomeSeer HS-LS100+ Z-Wave Plus Leak Sensor
We'll need to add a device definition to Indigo for it, but in the mean time you should be able to use Indigo's Match Raw Packet trigger type with it. See this forum post where I explained the details for an Ecolink flood sensor. The Match Bytes might be slightly different for the HomeSeer module – you'll need to turn on Indigo Z-Wave debug logging checkbox (via the Interfaces->Z-Wave->Configure... menu item) then get the sensor wet to see what commands it is sending.
Tue Feb 06, 2018 11:01 am
smillerdad offline
Thanks. Looks good. I won't be able to try it until Wednesday and will report back then.
Steve
smillerdad
Wed Feb 07, 2018 7:59 pm
smillerdad offline
Yes, it works! It took some careful study and experimentation but the sensor can trigger what I want it to when it is wet or dry. The next challenge will be to distinguish one sensor from another. The log does identify which sensor was activated through the battery level report which is also available through Indigo Touch.
Thank you again for such a clever solution.
Steve
smillerdad
Thu Feb 08, 2018 4:28 am
CliveS offline
If you look at the 6th set of numbers in your raw data then in the sensor you posted above it should be 03, just extend the raw data to start at that point and only that sensor will trigger, then you set another trigger for the other sensor you have also starting at the 6th number and only that one will trigger.
CliveS
Users browsing this forum: No registered users and 35 guests
