I just switched to the new Gen5 stick and started with inclusion of the new Spirit ZW+ thermostats. The first 2 devives were recognized as 'General Thermostat (v2)' but the 3rd device was synced as ‚Thermostat - Thermostat (Spirit)‘ although all 3 devices are listed with firmware 0.15 in Indigo.
The one listed as Spirit has this returned: node 004, manufacturerId 0148, productId 00030001
and the other two this: node 003, manufacturerId 0148, productId 00030003
Are these different models although they look exactly the same? Node 4 has an additional Valve listed after syncing where I can change the Brightness(???) but this setting doesn’t do anything when changed as far as I can tell.
Anyone already using the Spirit thermostat has the same issue?
