suppress "received "xxx" power load to 1.140 W"
Sat Jan 20, 2018 12:01 pm
I have a strobe light attached to a zwave dimmer/ switch (to chase away squirrels in my attic)
it now reports watt usage every 2 seconds as the power usage goes up and down every 0.7 seconds.
Z-Wave received "strobe1 attic" power load to 1.232 W
Z-Wave received "strobe1 attic" power load to 1.130 W
Z-Wave received "strobe1 attic" power load to 1.192 W
Z-Wave received "strobe1 attic" power load to 1.120 W
Z-Wave received "strobe1 attic" power load to 0.921 W
Z-Wave received "strobe1 attic" power load to 1.125 W
here the zwave dump from the device edit..
Indigo Z-Wave Version: 2.0.111
Node ID: 27
Model: Dimmable Power Switch
Model ID: 00030019
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 3.67
Application Version: 1.20
Model Definition Version: 0
Library Type: 3
Class Name: Dimmable Power Switch
Class Hierarchy: 04 : 11 : 01
Command Class Base: 26
Command Versions: 20v1 85v1 26v2 27v1 2Bv1 2Cv1 32v3 70v1 72v1 56v1 86v1
Features: routing, beaming, energyMeter
Neighbors: 2, 3, 4, 5, 6, 7, 9, 18, 21, 24, 26, 28
Associations: 1:[1] 2:[]
which params do I have to set to suppress the constant reporting of wattage?
Sat Jan 20, 2018 12:49 pm
Re: suppress "received "xxx" power load to 1.140 W"
If it’s a “Micro Smart Dimmer v2” then set 101 to 0.
That says “Send the following reports to group 1: No reports”
Sat Jan 20, 2018 1:13 pm
yes that seems to do the trick.. thanks
Sat Jan 20, 2018 1:14 pm
http://www.vesternet.com/downloads/dl/f ... cation.pdf
