Very cheap (AN158) Z-Wave Plug-in Switch with Power Meter
Fri Jan 19, 2018 7:12 am
McJohn offline
Hello Indigo-friends,
Maybe this is interesting for the European Z-Wave users;
We discovered this e-Domotica Z-Wave Plug-in Switch with Power Meter.
The inside is 100% the Everspring AN158 module.
We have tested it and it's working 100% with Indigo.
So, we don't want to advertise or do marketing for products here at the forum but this price (17,75) is so cheap, we had to tell you this.
http://www.domotica-shop.nl/e-domotica- ... 16348.html
(there is also a French version)
Kind regards,
John
Node ID: 109
Model: Appliance Module (AN158)
Model ID: 00040002
Manufacturer: Everspring
Manufacturer ID: 0060
Protocol Version: 2.64
Application Version: 1.01
Model Definition Version: 0
Library Type: 6
Class Name: Relay Power Switch
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 85v1 86v1 27v1 72v1 70v1 32v2 25v1
Features: routing, beaming, energyMeter
Neighbors: 1, 11, 15, 16, 17, 25, 27, 34, 38, 40, 41, 45, 54, 62, 64, 65, 77, 92, 95, 99, 108
Associations: 1:[1] 2:[]
Config Values: - none -
