- Code: Select all
Z-Wave Indigo Device "094 - Notification Sensor" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.111
Node ID: 94
Model: Notification Sensor
Model ID: 0003108A
Manufacturer: Neo
Manufacturer ID: 0258
Protocol Version: 4.38
Application Version: 3.11
Model Definition Version: 0
Library Type: 6
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 70v1 30v1 71v1 72v1 73v1 59v1 5Av1 5Bv1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 43, 45, 46, 82
Associations: 1:[1] 2:[] 3:[] 4:[] 5:[]
Config Values: - none -
I've managed to get the buttons to trigger from a raw command as an interim measure until a new device definition is created - no panic .
