Neo Coolcam SOS Key Fob
Tue Jan 16, 2018 5:00 pm
Colly offline
I recently decided to purchase another of the Neo Z-wave devices, http://www.szneo.com/en/products/show.php?id=195. I've submitted the device details in the normal way. Below is the log entry:
   Z-Wave                          Indigo Device "094 - Notification Sensor" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.111
Node ID: 94
Model: Notification Sensor
Model ID: 0003108A
Manufacturer: Neo
Manufacturer ID: 0258
Protocol Version: 4.38
Application Version: 3.11
Model Definition Version: 0
Library Type: 6
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 70v1 30v1 71v1 72v1 73v1 59v1 5Av1 5Bv1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 43, 45, 46, 82
Associations: 1:[1] 2:[] 3:[] 4:[] 5:[]
Config Values: - none -
I've managed to get the buttons to trigger from a raw command as an interim measure until a new device definition is created - no panic :) .
Tue Jan 16, 2018 5:23 pm
Re: Neo Coolcam SOS Key Fob
Can you turn on Indigo's Z-Wave debug logging checkbox (via the Interfaces->Z-Wave->Configure... menu item) and capture the Event Log results of all the different button presses for us?
Tue Jan 16, 2018 5:55 pm
Colly offline
Button 1
   Z-Wave Debug                    RCVD sceneActivateCmd2: 01 0B 00 04 00 5E 05 5B 03 00 00 01 F2
   Z-Wave Debug                    . .  sceneActivateCmd2: node 094, type: 0, scene: 1
   Z-Wave                          received "094 - Notification Sensor" scene 1
Button 2
   Z-Wave Debug                    RCVD sceneActivateCmd2: 01 0B 00 04 00 5E 05 5B 03 00 00 02 F1
   Z-Wave Debug                    . .  sceneActivateCmd2: node 094, type: 0, scene: 2
   Z-Wave                          received "094 - Notification Sensor" scene 2
Button 3
   Z-Wave Debug                    RCVD sceneActivateCmd2: 01 0B 00 04 00 5E 05 5B 03 00 00 03 F0
   Z-Wave Debug                    . .  sceneActivateCmd2: node 094, type: 0, scene: 3
   Z-Wave                          received "094 - Notification Sensor" scene 3
SOS
   Z-Wave Debug                    RCVD requestAlarmSensorStatus: 01 0F 00 04 00 5E 09 71 05 00 00 00 FF 0A 01 00 23
   Z-Wave Debug                    . .  requestAlarmSensorStatus: node 094, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
   Z-Wave Debug                    . .  requestAlarmSensorStatus: typeExt 10, valueExt 1, classSubKeyExt 7100000A01
   Z-Wave Debug                    RCVD requestBinarySensorStatus: 01 0A 00 04 00 5E 04 30 03 FF 01 66
   Z-Wave Debug                    . .  requestBinarySensorStatus: node 094, endpoint None, type 1, value 255
Wed Jan 17, 2018 12:04 am
That should work out of the box with the Zwave Scene Controller Plugin if anyone else buys one before the device definition is published.
Peter
Wed Jan 17, 2018 12:54 am
Colly offline
Will give that a try later.
Wed Dec 23, 2020 4:50 pm
Indigo 7.5 is now available and includes support for scene Triggers from the Neo Coolcam SOS Key Fob (RC01Z).
