Every week or so some z-wave devices communications (once it happens with >50% of devices, but "normally" 10-20) disabled.
Enabling manually - no issues, continues to work.
What could it be?
jay (support) wrote:Is everyone who is seeing this repeatedly running High Sierra? Is everyone using the Gen5 stick?
2017-12-13 02:04:59.898 Z-Wave Optimizing - neighbor list updated from 5, 85, 150, 151, 156, 157, 158, 160, 165, 166, 167 to 5, 85, 103, 150, 151, 156, 157, 158, 160, 165, 166, 167
2017-12-13 02:04:59.909 Z-Wave Optimizing - finished "006 - Living Room Display Lights Switch"
2017-12-13 02:09:59.165 Z-Wave Optimizing - starting "008 - Garage Far Power Switch"
2017-12-13 02:10:14.168 Z-Wave Optimizing - ping timeout
2017-12-13 02:10:14.170 Z-Wave Optimizing - skipped "008 - Garage Far Power Switch" (unreachable)
2017-12-13 02:10:15.174 Z-Wave Optimizing - starting "028 - En Suite Floor Heating Thermostat"
2017-12-13 02:10:30.176 Z-Wave Optimizing - ping timeout
2017-12-13 02:10:30.178 Z-Wave Optimizing - skipped "028 - En Suite Floor Heating Thermostat" (unreachable)
2017-12-13 02:10:59.390 Z-Wave Error no ack/nak/busy reply (008) for sendPingZwaveCommand (re-sending)
2017-12-13 02:11:46.576 Z-Wave Error send sendPingZwaveCommand failed after 9 attempts
2017-12-13 02:11:46.578 Z-Wave Error restarting serial connection in 5.0 seconds
2017-12-13 02:11:50.409 Interface Failure lost connection with interface
2017-12-13 02:12:41.064 Z-Wave Error send getVersion failed after 9 attempts
2017-12-13 02:12:41.066 Z-Wave Error restarting serial connection in 5.0 seconds
2017-12-13 02:12:44.409 Interface Failure lost connection with interface
2017-12-13 02:13:32.237 Z-Wave Error send getVersion failed after 9 attempts
2017-12-13 02:13:32.238 Z-Wave Error restarting serial connection in 5.0 seconds
2017-12-13 02:13:35.414 Interface Failure lost connection with interface
2017-12-13 02:14:22.414 Z-Wave Error send getVersion failed after 9 attempts
2017-12-13 02:14:22.415 Z-Wave Error restarting serial connection in 5.0 seconds
2017-12-13 02:14:25.410 Interface Failure lost connection with interface
2017-12-13 02:14:40.358 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodemFA121 (firmware 1.00)
2017-12-13 02:14:40.545 Z-Wave Error module 028 included in controller no longer matches device "En Suite Floor Heating Thermostat" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwThermostatType (4, 8, 6))
2017-12-13 02:14:40.559 Z-Wave Error module 055 included in controller no longer matches device "Front Door Keypad Lock" type (controller module type: zwThermostatType/zwThermostatType (4, 8, 6), indigo device type: zwLockType (4, 64, 3))
2017-12-13 02:14:40.573 Z-Wave Error module 073 included in controller no longer matches device "Kitchen Fibaro Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 64, 3), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 02:14:40.602 Z-Wave Error module 085 included in controller no longer matches device "Living Room Honeywell Controller Switch" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 02:14:40.616 Z-Wave Error module 093 included in controller no longer matches device "Keyfob (FGKF601)" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwCustomType (4, 24, 1))
2017-12-13 02:14:40.628 Z-Wave Error module 094 included in controller no longer matches device ".En Suite Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 24, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 02:14:40.641 Z-Wave Error module 099 included in controller no longer matches device "Living Room PST02 Motion Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 24, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 02:14:40.679 Z-Wave Error module 103 included in controller no longer matches device "En Suite Floor Heating Switch" type (controller module type: zwRelayType/zwRelayType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 02:14:40.706 Z-Wave Error module 116 included in controller no longer matches device ".Bathroom Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 02:14:40.736 Z-Wave Error module 120 included in controller no longer matches device ".Bedroom 1 Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwOnOffSensorType (4, 86, 104))
2017-12-13 02:14:40.754 Z-Wave Error module 122 included in controller no longer matches device "Bathroom Neo Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 86, 104), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 02:14:40.768 Z-Wave found module included in controller with no matching device (missing or disabled): 124 - Notification Sensor
2017-12-13 02:14:40.780 Z-Wave Error module 126 included in controller no longer matches device "126 Door/Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 02:14:40.798 Z-Wave Error module 135 included in controller no longer matches device "Bedroom 1 Jane WallMote" type (controller module type: zwCustomType/zwCustomType (4, 7, 1), indigo device type: zwCustomType (4, 24, 1))
2017-12-13 02:14:40.816 Z-Wave Error module 137 included in controller no longer matches device "137 Door/Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 24, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 02:14:40.833 Z-Wave Error module 139 included in controller no longer matches device "Motorhome Neo Charger Socket" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 02:14:40.850 Z-Wave Error module 141 included in controller no longer matches device "141 Door/Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 02:14:40.897 Z-Wave Error module 150 included in controller no longer matches device "Bedroom 1 Ceiling Light" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
2017-12-13 02:14:40.924 Z-Wave Error module 152 included in controller no longer matches device "Kitchen Neo Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 02:14:40.941 Z-Wave Error module 153 included in controller no longer matches device "Neo Relay Power Plug - MacBook Air" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 02:14:40.961 Z-Wave Error module 156 included in controller no longer matches device "Living Room Aeon 4 Motion Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 02:14:40.989 Z-Wave Error module 157 included in controller no longer matches device "Kitchen Spot Lights" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
2017-12-13 02:14:41.010 Z-Wave Error module 158 included in controller no longer matches device "Kitchen Undercupboard Lights" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
2017-12-13 02:14:41.030 Z-Wave Error module 159 included in controller no longer matches device "Garden Lights" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 02:14:41.042 Z-Wave Error module 160 included in controller no longer matches device "Repeater Relay Power Switch" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 02:14:41.054 Z-Wave Error module 163 included in controller no longer matches device "163 - Motion Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 02:14:41.070 Z-Wave Error module 164 included in controller no longer matches device "Siren" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwRelayType (4, 16, 5))
2017-12-13 02:14:41.091 Z-Wave Error module 166 included in controller no longer matches device "Living Room Christmas Tree" type (controller module type: zwRelayType/zwRelayType (4, 16, 5), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 02:14:41.108 Z-Wave found module included in controller with no matching device (missing or disabled): 168 - Relay Power Switch
2017-12-13 02:14:41.114 Z-Wave Error module 169 included in controller no longer matches device "Bathroom Fibaro Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 02:14:41.136 Z-Wave Error to re-enable the devices with new z-wave modules, press the "Define and Sync..." button in the device dialog
2017-12-13 02:14:54.178 Z-Wave Optimizing - starting "085 - Notification Sensor"
2017-12-13 02:14:54.299 Z-Wave Optimizing - ping completed in 73 ms
2017-12-13 02:14:54.300 Z-Wave Optimizing - finding neighbors
2017-12-13 02:14:54.302 Z-Wave Optimizing - requesting neighbor list update
2017-12-13 02:15:06.607 Z-Wave Optimizing - neighbor list updated from - none - to 5, 6, 150, 151, 156, 157, 158, 160, 165, 166, 167
2017-12-13 02:15:06.608 Z-Wave Optimizing - finished "085 - Notification Sensor"
2017-12-13 02:15:13.364 Z-Wave Optimizing - starting "103 - Notification Sensor"
2017-12-13 02:15:13.488 Z-Wave Optimizing - ping completed in 17 ms
2017-12-13 02:15:13.489 Z-Wave Optimizing - finding neighbors
2017-12-13 02:15:13.515 Z-Wave Optimizing - requesting neighbor list update
2017-12-13 02:15:21.819 Z-Wave Optimizing - neighbor list updated from - none - to 5, 6, 150, 151, 157, 158, 160, 166, 167
2017-12-13 02:15:21.821 Z-Wave Optimizing - finished "103 - Notification Sensor"
2017-12-13 02:15:28.530 Z-Wave Optimizing - starting "139 - Notification Sensor"
2017-12-13 02:15:28.764 Z-Wave Optimizing - ping completed in 175 ms
2017-12-13 02:15:28.765 Z-Wave Optimizing - finding neighbors
2017-12-13 18:34:17.876 Z-Wave Optimizing - update queued for next awake message: "143 - Drive Garage Door Motion"
2017-12-13 18:34:17.876 Z-Wave Optimizing - update queued for next awake message: "145 - Living Room Neo Motion"
2017-12-13 18:34:17.876 Z-Wave Optimizing - update queued for next awake message: "146 - Drive Front Door Motion"
2017-12-13 18:34:17.877 Z-Wave Optimizing - update queued for next awake message: "148 - Heiman 1 Notification Sensor"
2017-12-13 18:34:17.877 Z-Wave Optimizing - update queued for next awake message: "152 - Kitchen Neo Motion"
2017-12-13 18:34:17.878 Z-Wave Optimizing - update queued for next awake message: "155 - .Bathroom Door Sensor"
2017-12-13 18:34:17.878 Z-Wave Optimizing - update queued for next awake message: "163 - Motion Sensor"
2017-12-13 18:34:17.878 Z-Wave Optimizing - update queued for next awake message: "169 - Bathroom Fibaro Motion"
2017-12-13 18:34:17.879 Z-Wave Error Optimizing - update failed: "008 - Garage Far Power Switch"
2017-12-13 18:34:17.879 Z-Wave Error Optimizing - update failed: "028 - En Suite Floor Heating Thermostat"
2017-12-13 18:34:17.880 Z-Wave Error Optimizing - update failed: "124 - Relay Switch 1"
2017-12-13 18:34:41.006 Z-Wave Optimizing - started network optimization for nodes: 8
2017-12-13 18:34:41.370 Z-Wave Optimizing - starting "008 - Garage Far Power Switch"
2017-12-13 18:34:56.375 Z-Wave Optimizing - ping timeout
2017-12-13 18:34:56.376 Z-Wave Optimizing - finding neighbors
2017-12-13 18:35:28.553 Z-Wave Error send sendPingZwaveCommand failed after 9 attempts
2017-12-13 18:35:28.554 Z-Wave Error restarting serial connection in 5.0 seconds
2017-12-13 18:35:32.464 Interface Failure lost connection with interface
2017-12-13 18:36:18.742 Z-Wave Error send getVersion failed after 9 attempts
2017-12-13 18:36:18.742 Z-Wave Error restarting serial connection in 5.0 seconds
2017-12-13 18:36:22.465 Interface Failure lost connection with interface
2017-12-13 18:36:55.020 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodemFA131 (firmware 1.00)
2017-12-13 18:36:55.199 Z-Wave Error module 028 included in controller no longer matches device "En Suite Floor Heating Thermostat" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwThermostatType (4, 8, 6))
2017-12-13 18:36:55.226 Z-Wave Error module 073 included in controller no longer matches device "Kitchen Fibaro Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 64, 3), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:36:55.260 Z-Wave Error module 085 included in controller no longer matches device "Server Room Repeater Controller Switch" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:36:55.275 Z-Wave Error module 093 included in controller no longer matches device "Keyfob (FGKF601)" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwCustomType (4, 24, 1))
2017-12-13 18:36:55.288 Z-Wave Error module 094 included in controller no longer matches device ".En Suite Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:36:55.303 Z-Wave Error module 099 included in controller no longer matches device "Living Room PST02 Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 24, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:36:55.345 Z-Wave Error module 103 included in controller no longer matches device "En Suite Floor Heating Switch" type (controller module type: zwRelayType/zwRelayType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:36:55.383 Z-Wave Error module 118 included in controller no longer matches device ".Conservatory Right Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:36:55.402 Z-Wave Error module 120 included in controller no longer matches device ".Bedroom 1 Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwOnOffSensorType (4, 86, 104))
2017-12-13 18:36:55.428 Z-Wave Error module 124 included in controller no longer matches device "124 - Relay Switch 1" type (controller module type: zwRelayType/zwRelayType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:36:55.447 Z-Wave Error module 125 included in controller no longer matches device ".Kitchen Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 86, 104), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:36:55.473 Z-Wave Error module 135 included in controller no longer matches device "Bedroom 1 Jane WallMote" type (controller module type: zwCustomType/zwCustomType (4, 16, 1), indigo device type: zwCustomType (4, 24, 1))
2017-12-13 18:36:55.507 Z-Wave Error module 139 included in controller no longer matches device "Motorhome Neo Charger Socket" type (controller module type: zwCustomType/zwCustomType (4, 24, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:36:55.540 Z-Wave Error module 143 included in controller no longer matches device "Drive Garage Door Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:36:55.592 Z-Wave Error module 150 included in controller no longer matches device "Bedroom 1 Ceiling Light" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
2017-12-13 18:36:55.613 Z-Wave Error module 151 included in controller no longer matches device "Bathroom Light" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
2017-12-13 18:36:55.640 Z-Wave Error module 153 included in controller no longer matches device "Neo Relay Power Plug - MacBook Air" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:36:55.655 Z-Wave Error module 155 included in controller no longer matches device ".Bathroom Door Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:36:55.668 Z-Wave Error module 156 included in controller no longer matches device "Living Room Aeon 4 Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:36:55.698 Z-Wave Error module 157 included in controller no longer matches device "Kitchen Spot Lights" type (controller module type: zwRelayType/zwDimmerType (4, 16, 1), indigo device type: zwDimmerType (4, 17, 1))
2017-12-13 18:36:55.719 Z-Wave Error module 158 included in controller no longer matches device "Kitchen Undercupboard Lights" type (controller module type: zwRelayType/zwDimmerType (4, 16, 1), indigo device type: zwDimmerType (4, 17, 1))
2017-12-13 18:36:55.740 Z-Wave Error module 159 included in controller no longer matches device "Garden Lights" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:36:55.753 Z-Wave Error module 160 included in controller no longer matches device "Hall Repeater Relay Power Switch" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:36:55.766 Z-Wave Error module 163 included in controller no longer matches device "163 - Motion Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:36:55.786 Z-Wave Error module 164 included in controller no longer matches device "Siren" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 5))
2017-12-13 18:36:55.816 Z-Wave Error module 167 included in controller no longer matches device "Dining Room Relay Power Switch" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:36:55.826 Z-Wave found module included in controller with no matching device (missing or disabled): 168 - Siren
2017-12-13 18:36:55.832 Z-Wave Error module 169 included in controller no longer matches device "Bathroom Fibaro Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:36:55.858 Z-Wave Error to re-enable the devices with new z-wave modules, press the "Define and Sync..." button in the device dialog
2017-12-13 18:36:55.871 Z-Wave Optimizing - requesting neighbor list update
2017-12-13 18:37:05.096 Z-Wave Optimizing - stopped
2017-12-13 18:37:10.921 Z-Wave neighbor list update complete (no change)
2017-12-13 18:37:10.922 Z-Wave Optimizing - finished "008 - Garage Far Power Switch"
2017-12-13 18:37:10.922 Z-Wave Optimizing - complete
2017-12-13 18:37:10.923 Z-Wave Optimizing - update succeeded: "008 - Garage Far Power Switch"
2017-12-13 18:38:46.940 Z-Wave received "Living Room Christmas Tree" power load to 4.90 W
2017-12-13 18:39:20.040 Timed Devices "Garage Freezer Power Alive" off
2017-12-13 18:39:20.046 Trigger Garage Freezer Power Socket Off - PushOver Notification
2017-12-13 18:39:20.055 Pushover Debug Garage Freezer
2017-12-13 18:39:20.056 Pushover Debug Alive Alert - No Responce from Freezer Socket
2017-12-13 18:40:05.509 Z-Wave Error send setRelayValue failed after 9 attempts
2017-12-13 18:40:05.510 Z-Wave Error restarting serial connection in 5.0 seconds
2017-12-13 18:40:09.476 Interface Failure lost connection with interface
2017-12-13 18:40:55.669 Z-Wave Error send getVersion failed after 9 attempts
2017-12-13 18:40:55.669 Z-Wave Error restarting serial connection in 5.0 seconds
2017-12-13 18:40:59.477 Interface Failure lost connection with interface
2017-12-13 18:41:31.979 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodemFA131 (firmware 1.00)
2017-12-13 18:41:32.163 Z-Wave Error module 028 included in controller no longer matches device "En Suite Floor Heating Thermostat" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwThermostatType (4, 8, 6))
2017-12-13 18:41:32.178 Z-Wave Error module 055 included in controller no longer matches device "Front Door Keypad Lock" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwLockType (4, 64, 3))
2017-12-13 18:41:32.192 Z-Wave Error module 073 included in controller no longer matches device "Kitchen Fibaro Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 8, 6), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:41:32.222 Z-Wave Error module 085 included in controller no longer matches device "Server Room Repeater Controller Switch" type (controller module type: zwLockType/zwLockType (4, 64, 3), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:41:32.234 Z-Wave Error module 093 included in controller no longer matches device "Keyfob (FGKF601)" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwCustomType (4, 24, 1))
2017-12-13 18:41:32.246 Z-Wave Error module 094 included in controller no longer matches device ".En Suite Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:41:32.259 Z-Wave Error module 099 included in controller no longer matches device "Living Room PST02 Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:41:32.298 Z-Wave Error module 103 included in controller no longer matches device "En Suite Floor Heating Switch" type (controller module type: zwRelayType/zwRelayType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:41:32.350 Z-Wave Error module 120 included in controller no longer matches device ".Bedroom 1 Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwOnOffSensorType (4, 86, 104))
2017-12-13 18:41:32.369 Z-Wave Error module 122 included in controller no longer matches device "Bathroom Neo Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 86, 104), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:41:32.396 Z-Wave Error module 124 included in controller no longer matches device "124 - Relay Switch 1" type (controller module type: zwRelayType/zwRelayType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:41:32.412 Z-Wave Error module 125 included in controller no longer matches device ".Kitchen Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:41:32.440 Z-Wave Error module 135 included in controller no longer matches device "Bedroom 1 Jane WallMote" type (controller module type: zwCustomType/zwCustomType (4, 7, 1), indigo device type: zwCustomType (4, 24, 1))
2017-12-13 18:41:32.459 Z-Wave Error module 137 included in controller no longer matches device "137 Door/Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 24, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:41:32.478 Z-Wave Error module 139 included in controller no longer matches device "Motorhome Neo Charger Socket" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:41:32.497 Z-Wave Error module 141 included in controller no longer matches device "141 Door/Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:41:32.542 Z-Wave Error module 150 included in controller no longer matches device "Bedroom 1 Ceiling Light" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
2017-12-13 18:41:32.562 Z-Wave Error module 151 included in controller no longer matches device "Bathroom Light" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
2017-12-13 18:41:32.582 Z-Wave Error module 152 included in controller no longer matches device "Kitchen Neo Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:41:32.601 Z-Wave Error module 153 included in controller no longer matches device "Neo Relay Power Plug - MacBook Air" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:41:32.621 Z-Wave Error module 156 included in controller no longer matches device "Living Room Aeon 4 Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:41:32.649 Z-Wave Error module 157 included in controller no longer matches device "Kitchen Spot Lights" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
2017-12-13 18:41:32.669 Z-Wave Error module 158 included in controller no longer matches device "Kitchen Undercupboard Lights" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
2017-12-13 18:41:32.689 Z-Wave Error module 159 included in controller no longer matches device "Garden Lights" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:41:32.701 Z-Wave Error module 160 included in controller no longer matches device "Hall Repeater Relay Power Switch" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:41:32.714 Z-Wave Error module 163 included in controller no longer matches device "163 - Motion Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:41:32.730 Z-Wave Error module 164 included in controller no longer matches device "Siren" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwRelayType (4, 16, 5))
2017-12-13 18:41:32.751 Z-Wave Error module 166 included in controller no longer matches device "Living Room Christmas Tree" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:41:32.762 Z-Wave Error module 167 included in controller no longer matches device "Dining Room Relay Power Switch" type (controller module type: zwRelayType/zwRelayType (4, 16, 5), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:41:32.772 Z-Wave found module included in controller with no matching device (missing or disabled): 168 - Relay Power Switch
2017-12-13 18:41:32.779 Z-Wave Error module 169 included in controller no longer matches device "Bathroom Fibaro Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:41:32.800 Z-Wave Error to re-enable the devices with new z-wave modules, press the "Define and Sync..." button in the device dialog
2017-12-13 18:42:19.974 Z-Wave Error send setRelayValue failed after 9 attempts
2017-12-13 18:42:19.975 Z-Wave Error restarting serial connection in 5.0 seconds
2017-12-13 18:42:23.476 Interface Failure lost connection with interface
2017-12-13 18:43:10.129 Z-Wave Error send getVersion failed after 9 attempts
2017-12-13 18:43:10.129 Z-Wave Error restarting serial connection in 5.0 seconds
2017-12-13 18:43:13.478 Interface Failure lost connection with interface
2017-12-13 18:43:46.420 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodemFA131 (firmware 1.00)
2017-12-13 18:43:46.593 Z-Wave found module included in controller with no matching device (missing or disabled): 028 - Relay Power Switch
2017-12-13 18:43:46.596 Z-Wave found module included in controller with no matching device (missing or disabled): 055 - General Thermostat (v2)
2017-12-13 18:43:46.599 Z-Wave found module included in controller with no matching device (missing or disabled): 073 - General Thermostat (v2)
2017-12-13 18:43:46.603 Z-Wave found module included in controller with no matching device (missing or disabled): 085 - Keypad Door Lock
2017-12-13 18:43:46.605 Z-Wave found module included in controller with no matching device (missing or disabled): 093 - Notification Sensor
2017-12-13 18:43:46.631 Z-Wave found module included in controller with no matching device (missing or disabled): 094 - Notification Sensor
2017-12-13 18:43:46.636 Z-Wave found module included in controller with no matching device (missing or disabled): 099 - Notification Sensor
2017-12-13 18:43:46.659 Z-Wave found module included in controller with no matching device (missing or disabled): 103 - Notification Sensor
2017-12-13 18:43:46.668 Z-Wave Error module 113 included in controller no longer matches device "Kitchen PST02 Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:43:46.720 Z-Wave found module included in controller with no matching device (missing or disabled): 120 - Notification Sensor
2017-12-13 18:43:46.729 Z-Wave found module included in controller with no matching device (missing or disabled): 122 - Notification Sensor
2017-12-13 18:43:46.732 Z-Wave found module included in controller with no matching device (missing or disabled): 124 - Routing Slave
2017-12-13 18:43:46.734 Z-Wave found module included in controller with no matching device (missing or disabled): 125 - Notification Sensor
2017-12-13 18:43:46.744 Z-Wave Error module 127 included in controller no longer matches device ".Utility Room Outside Door Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:43:46.755 Z-Wave found module included in controller with no matching device (missing or disabled): 135 - Notification Sensor
2017-12-13 18:43:46.771 Z-Wave found module included in controller with no matching device (missing or disabled): 137 - Notification Sensor
2017-12-13 18:43:46.783 Z-Wave found module included in controller with no matching device (missing or disabled): 139 - Notification Sensor
2017-12-13 18:43:46.789 Z-Wave Error module 140 included in controller no longer matches device "140 Door/Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:43:46.800 Z-Wave found module included in controller with no matching device (missing or disabled): 141 - Relay Power Switch
2017-12-13 18:43:46.836 Z-Wave found module included in controller with no matching device (missing or disabled): 150 - Notification Sensor
2017-12-13 18:43:46.840 Z-Wave found module included in controller with no matching device (missing or disabled): 151 - Notification Sensor
2017-12-13 18:43:46.844 Z-Wave found module included in controller with no matching device (missing or disabled): 152 - Notification Sensor
2017-12-13 18:43:46.848 Z-Wave found module included in controller with no matching device (missing or disabled): 153 - Dimmable Power Switch
2017-12-13 18:43:46.853 Z-Wave Error module 155 included in controller no longer matches device ".Bathroom Door Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-13 18:43:46.865 Z-Wave found module included in controller with no matching device (missing or disabled): 156 - Notification Sensor
2017-12-13 18:43:46.868 Z-Wave found module included in controller with no matching device (missing or disabled): 157 - Relay Power Switch
2017-12-13 18:43:46.870 Z-Wave found module included in controller with no matching device (missing or disabled): 158 - Notification Sensor
2017-12-13 18:43:46.882 Z-Wave found module included in controller with no matching device (missing or disabled): 159 - Relay Power Switch
2017-12-13 18:43:46.890 Z-Wave found module included in controller with no matching device (missing or disabled): 160 - Relay Power Switch
2017-12-13 18:43:46.897 Z-Wave found module included in controller with no matching device (missing or disabled): 163 - Notification Sensor
2017-12-13 18:43:46.901 Z-Wave found module included in controller with no matching device (missing or disabled): 164 - Notification Sensor
2017-12-13 18:43:46.910 Z-Wave Error module 165 included in controller no longer matches device "Living Room Twigs" type (controller module type: zwRelayType/zwRelayType (4, 16, 5), indigo device type: zwRelayType (4, 16, 1))
2017-12-13 18:43:46.929 Z-Wave found module included in controller with no matching device (missing or disabled): 166 - Relay Power Switch
2017-12-13 18:43:46.935 Z-Wave found module included in controller with no matching device (missing or disabled): 167 - Relay Power Switch
2017-12-13 18:43:46.938 Z-Wave found module included in controller with no matching device (missing or disabled): 168 - Relay Power Switch
2017-12-13 18:43:46.946 Z-Wave found module included in controller with no matching device (missing or disabled): 169 - Relay Power Switch
2017-12-13 18:43:46.947 Z-Wave Error to re-enable the devices with new z-wave modules, press the "Define and Sync..." button in the device dialog
2017-12-13 18:50:52.821 Timed Devices "Living Room 5 Minute Timer" on
2017-12-13 18:52:02.435 Updated "Kitchen Hue GU10" on to 100
2017-12-13 18:52:41.407 Z-Wave Error serial port communication error: read failed: [Errno 6] Device not configured
2017-12-13 18:52:41.407 Z-Wave Error Z-Wave 3.95 static controller might be disconnected
2017-12-13 18:52:41.408 Z-Wave Error silently retrying serial connection every 5.0 seconds
2017-12-13 18:52:44.496 Interface Failure lost connection with interface
2017-12-13 18:52:47.222 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodemFA131 (firmware 1.00)
2017-12-13 18:52:47.420 Z-Wave found module included in controller with no matching device (missing or disabled): 028 - General Thermostat (v2)
2017-12-13 18:52:47.424 Z-Wave found module included in controller with no matching device (missing or disabled): 055 - Keypad Door Lock
2017-12-13 18:52:47.428 Z-Wave found module included in controller with no matching device (missing or disabled): 073 - Notification Sensor
2017-12-13 18:52:47.432 Z-Wave found module included in controller with no matching device (missing or disabled): 085 - Relay Power Switch
2017-12-13 18:52:47.436 Z-Wave found module included in controller with no matching device (missing or disabled): 093 - Basic Wall Controller
2017-12-13 18:52:47.440 Z-Wave found module included in controller with no matching device (missing or disabled): 094 - Notification Sensor
2017-12-13 18:52:47.445 Z-Wave found module included in controller with no matching device (missing or disabled): 099 - Notification Sensor
2017-12-13 18:52:47.456 Z-Wave found module included in controller with no matching device (missing or disabled): 103 - Relay Power Switch
2017-12-13 18:52:47.461 Z-Wave found module included in controller with no matching device (missing or disabled): 113 - Notification Sensor
2017-12-13 18:52:47.493 Z-Wave found module included in controller with no matching device (missing or disabled): 120 - Routing Slave
2017-12-13 18:52:47.504 Z-Wave found module included in controller with no matching device (missing or disabled): 122 - Notification Sensor
2017-12-13 18:52:47.508 Z-Wave found module included in controller with no matching device (missing or disabled): 124 - Relay Power Switch
2017-12-13 18:52:47.512 Z-Wave found module included in controller with no matching device (missing or disabled): 125 - Notification Sensor
2017-12-13 18:52:47.523 Z-Wave found module included in controller with no matching device (missing or disabled): 127 - Notification Sensor
2017-12-13 18:52:47.527 Z-Wave found module included in controller with no matching device (missing or disabled): 135 - Basic Wall Controller
2017-12-13 18:52:47.538 Z-Wave found module included in controller with no matching device (missing or disabled): 137 - Notification Sensor
2017-12-13 18:52:47.548 Z-Wave found module included in controller with no matching device (missing or disabled): 139 - Relay Power Switch
2017-12-13 18:52:47.553 Z-Wave found module included in controller with no matching device (missing or disabled): 140 - Notification Sensor
2017-12-13 18:52:47.557 Z-Wave found module included in controller with no matching device (missing or disabled): 141 - Notification Sensor
2017-12-13 18:52:47.596 Z-Wave found module included in controller with no matching device (missing or disabled): 150 - Dimmable Power Switch
2017-12-13 18:52:47.600 Z-Wave found module included in controller with no matching device (missing or disabled): 151 - Dimmable Power Switch
2017-12-13 18:52:47.605 Z-Wave found module included in controller with no matching device (missing or disabled): 152 - Notification Sensor
2017-12-13 18:52:47.609 Z-Wave found module included in controller with no matching device (missing or disabled): 153 - Relay Power Switch
2017-12-13 18:52:47.612 Z-Wave found module included in controller with no matching device (missing or disabled): 155 - Notification Sensor
2017-12-13 18:52:47.616 Z-Wave found module included in controller with no matching device (missing or disabled): 156 - Notification Sensor
2017-12-13 18:52:47.621 Z-Wave found module included in controller with no matching device (missing or disabled): 157 - Dimmable Power Switch
2017-12-13 18:52:47.625 Z-Wave found module included in controller with no matching device (missing or disabled): 158 - Dimmable Power Switch
2017-12-13 18:52:47.629 Z-Wave found module included in controller with no matching device (missing or disabled): 159 - Relay Power Switch
2017-12-13 18:52:47.633 Z-Wave found module included in controller with no matching device (missing or disabled): 160 - Relay Power Switch
2017-12-13 18:52:47.637 Z-Wave found module included in controller with no matching device (missing or disabled): 163 - Notification Sensor
2017-12-13 18:52:47.642 Z-Wave found module included in controller with no matching device (missing or disabled): 164 - Siren
2017-12-13 18:52:47.646 Z-Wave found module included in controller with no matching device (missing or disabled): 165 - Relay Power Switch
2017-12-13 18:52:47.650 Z-Wave found module included in controller with no matching device (missing or disabled): 166 - Relay Power Switch
2017-12-13 18:52:47.654 Z-Wave found module included in controller with no matching device (missing or disabled): 167 - Relay Power Switch
2017-12-13 18:52:47.658 Z-Wave found module included in controller with no matching device (missing or disabled): 168 - Notification Sensor
2017-12-13 18:52:47.662 Z-Wave found module included in controller with no matching device (missing or disabled): 169 - Notification Sensor
2017-12-13 18:52:49.010 Timed Devices "Garage Freezer Power Alive" on
2017-12-13 18:55:53.565 Timed Devices "Living Room 5 Minute Timer" off
2017-12-13 18:58:12.451 Email Scanned from "ebay@ebay.co.uk"; subject "6 NEW: z wave, UK Only, Under £45.00"
2017-12-13 18:58:43.984 Ignored device "Kitchen Spot Lights" action request (communication is disabled)
2017-12-13 18:58:44.011 Sent Hue Lights "Kitchen Hue GU10" on to 100 at ramp rate 0.0 sec.
2017-12-13 18:58:44.027 Sent Hue Lights "Kitchen Hue GU10" on to 100 with RGB values 255, 255 and 255 at ramp rate 0.0 sec.
2017-12-13 18:58:59.571 Z-Wave received "138 - 138 Door/Window Sensor" status update battery level 95%
2017-12-13 18:59:10.094 Z-Wave received "Bedroom 1 Ceiling Light" status update is on
2017-12-13 18:59:10.984 Z-Wave received "127 - .Utility Room Outside Door Sensor" status update battery level 100%
2017-12-13 18:59:15.371 Updated "Bedroom 1 Hue Ceiling Light" on to 100
2017-12-13 18:59:27.544 Z-Wave received "Living Room Christmas Tree" power load to 4.87 W
2017-12-13 19:00:00.512 Schedule Update Highsteads IP Address
2017-12-13 19:00:00.512 Action Group Highsteads.co.uk Update
2017-12-13 19:00:00.722 Honeywell [EV Zone: Bathroom]: Setting Heat Setpoint to: 18.0
2017-12-13 19:00:01.926 Honeywell [EV Zone: Bedroom 1]: Setting Heat Setpoint to: 16.0
2017-12-13 19:00:03.811 Honeywell [EV Zone: Bedroom 2]: Setting Heat Setpoint to: 12.0
2017-12-13 19:00:05.058 Honeywell [EV Zone: Bedroom 3]: Setting Heat Setpoint to: 12.0
2017-12-13 19:00:06.256 Honeywell [EV Zone: Conservatory]: Setting Heat Setpoint to: 22.0
2017-12-13 19:00:07.338 Honeywell [EV Zone: Dining Room]: Setting Heat Setpoint to: 20.0
2017-12-13 19:00:08.307 Trigger Evohome Dining Room Setpoint Change
2017-12-13 19:00:08.418 Honeywell [EV Zone: En Suite]: Setting Heat Setpoint to: 16.0
2017-12-13 19:00:09.484 Honeywell [EV Zone: Hall-Bedroom]: Setting Heat Setpoint to: 20.0
2017-12-13 19:00:10.629 Honeywell [EV Zone: Hall-Kitchen]: Setting Heat Setpoint to: 20.0
2017-12-13 19:00:11.681 Honeywell [EV Zone: Living Room Door]: Setting Heat Setpoint to: 22.0
2017-12-13 19:00:12.792 Honeywell [EV Zone: Living Room Front]: Setting Heat Setpoint to: 22.0
2017-12-13 19:00:13.493 Sent Hue Lights "Kitchen Hue GU10" off at ramp rate 0.0 sec.
2017-12-13 19:00:13.598 Z-Wave sent "Kitchen Spot Lights" off
2017-12-13 19:00:13.687 Z-Wave sent "Kitchen Undercupboard Lights" off
2017-12-13 19:00:13.859 Honeywell [EV Zone: Utility Room]: Setting Heat Setpoint to: 15.0
2017-12-13 19:00:29.676 Z-Wave received "Kitchen Undercupboard Lights" energy total to 0.14 kWh
2017-12-13 19:00:30.011 Z-Wave received "Kitchen Undercupboard Lights" power load to 89.0 W
2017-12-13 19:00:47.588 Z-Wave received "Living Room Christmas Tree" power load to 0.00 W
2017-12-13 19:00:52.681 Z-Wave received "094 - .En Suite Window Sensor" status update battery level 100%
2017-12-13 19:01:27.609 Z-Wave received "Living Room Christmas Tree" power load to 4.90 W
2017-12-13 19:01:35.677 Z-Wave received "Bedroom 1 Ceiling Light" status update is off
2017-12-13 19:01:37.277 Trigger Kitchen Spot Lights On Daytime PST02
2017-12-13 19:01:37.278 Action Group Kitchen Spot Lights On Daytime
2017-09-15 14:44:59.946 Z-Wave Optimizing - skipped "071 - Kitchen Fibaro 2 - Motion" (unreachable)
2017-09-15 14:45:00.951 Z-Wave Optimizing - starting "073 - Kitchen Fibaro 1 - Motion"
2017-09-15 14:45:15.956 Z-Wave Optimizing - ping timeout
2017-09-15 14:45:15.956 Z-Wave Optimizing - skipped "073 - Kitchen Fibaro 1 - Motion" (unreachable)
2017-09-15 14:45:32.332 Z-Wave Error send sendPingZwaveCommand failed after 9 attempts
2017-09-15 14:45:32.333 Z-Wave Error restarting serial connection in 5.0 seconds
2017-09-15 14:45:35.442 Interface Failure lost connection with interface
2017-09-15 14:45:41.711 Timed Devices "Kitchen Lights 1 Minute Motion Timer" off
2017-09-15 14:45:58.905 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodemFD131 (firmware 1.00)
2017-09-15 14:45:59.082 Z-Wave Error module 028 included in controller no longer matches device "En Suite Floor Heating Thermostat" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwThermostatType (4, 8, 6))
2017-09-15 14:45:59.096 Z-Wave Error module 037 included in controller no longer matches device "Kitchen Spot Lights" type (controller module type: zwThermostatType/zwDimmerType (4, 8, 6), indigo device type: zwDimmerType (4, 17, 1))
2017-09-15 14:45:59.125 Z-Wave Error module 055 included in controller no longer matches device "Front Door Keypad Lock" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwLockType (4, 64, 3))
2017-09-15 14:45:59.142 Z-Wave Error module 071 included in controller no longer matches device "Kitchen Fibaro 2 - Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 64, 3), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-09-15 14:45:59.171 Z-Wave Error module 084 included in controller no longer matches device "Hall Power Repeater Switch" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-09-15 14:45:59.183 Z-Wave Error module 085 included in controller no longer matches device "Dining Room Repeater Switch" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-09-15 14:45:59.195 Z-Wave Error module 086 included in controller no longer matches device "En Suite Aeon 6 - Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 33, 1))
2017-09-15 14:45:59.222 Z-Wave Error module 089 included in controller no longer matches device "Bedroom 3 Light - Dimmable Load" type (controller module type: zwRelayType/zwDimmerType (4, 16, 1), indigo device type: zwDimmerType (4, 17, 1))
2017-09-15 14:45:59.238 Z-Wave Error module 093 included in controller no longer matches device "Keyfob (FGKF601)" type (controller module type: zwValueSensorType/zwValueSensorType (4, 33, 1), indigo device type: zwCustomType (4, 24, 1))
2017-09-15 14:45:59.250 Z-Wave Error module 094 included in controller no longer matches device ".En Suite Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-09-15 14:45:59.260 Z-Wave Error module 099 included in controller no longer matches device "Living Room PST02 - Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-09-15 14:45:59.274 Z-Wave Error module 100 included in controller no longer matches device "Living Room Twigs Switch" type (controller module type: zwRelayType/zwRelayType (4, 24, 1), indigo device type: zwRelayType (4, 16, 1))
2017-09-15 14:45:59.439 Z-Wave Error module 113 included in controller no longer matches device "Kitchen PST02 - Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-09-15 14:45:59.481 Z-Wave Error module 120 included in controller no longer matches device ".Bedroom 1 Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwOnOffSensorType (4, 86, 104))
2017-09-15 14:45:59.499 Z-Wave Error module 122 included in controller no longer matches device "122 - Notification Sensor" type (controller module type: zwCustomType/zwCustomType (4, 86, 104), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-09-15 14:45:59.509 Z-Wave Error module 124 included in controller no longer matches device "124 - Relay Switch 1" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-09-15 14:45:59.532 Z-Wave Error module 126 included in controller no longer matches device "126 - Door/Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-09-15 14:45:59.551 Z-Wave Error module 135 included in controller no longer matches device "135 - WallMote Quad (ZW130)" type (controller module type: zwCustomType/zwCustomType (4, 7, 1), indigo device type: zwCustomType (4, 24, 1))
2017-09-15 14:45:59.570 Z-Wave Error module 137 included in controller no longer matches device "137 - Door/Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 24, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-09-15 14:45:59.586 Z-Wave Error module 139 included in controller no longer matches device "139 - Relay Power Switch" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-09-15 14:45:59.603 Z-Wave Error module 141 included in controller no longer matches device "141 - Door/Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-09-15 14:45:59.615 Z-Wave Error to re-enable the devices with new z-wave modules, press the "Define and Sync..." button in the device dialog
2017-09-15 14:46:10.641 Z-Wave Optimizing - starting "093 - Multilevel Sensor (routing)"
2017-09-15 14:46:16.750 Z-Wave Optimizing - ping failed
2017-09-15 14:46:16.750 Z-Wave Optimizing - finding neighbors
2017-09-15 14:46:16.779 Z-Wave Optimizing - requesting neighbor list update
2017-09-15 14:46:42.683 Z-Wave Optimizing - neighbor list update failed
2017-09-15 14:46:42.684 Z-Wave Optimizing - failed "093 - Multilevel Sensor (routing)"
2017-09-15 14:46:45.811 Z-Wave Optimizing - starting "094 - Dimmable Power Switch"
2017-12-27 09:37:24.040 Z-Wave Error send "Power - Yamaha NX-N500 Speakers" on failed
2017-12-27 13:29:08.427 Z-Wave Error no ack/nak/busy reply (022) for requestDimmerStatus (re-sending)
2017-12-27 14:04:14.914 Z-Wave Error no ack/nak/busy reply (022) for requestDimmerStatus (re-sending)
2017-12-27 16:36:10.796 Z-Wave Error rcvd incomplete interface packet (skipping): 01 09 00 04 36 03 80 03 2F 6B
2017-12-27 16:36:11.287 Z-Wave Error rcvd packet checksum mismatch: 01 00
2017-12-27 16:36:11.289 Z-Wave Error calculated checksum FF, received 00 (sent NAK)
2017-12-27 16:36:13.918 Z-Wave Error serial port communication error: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2017-12-27 16:36:13.919 Z-Wave Error Z-Wave 3.95 static controller might be disconnected
2017-12-27 16:36:13.920 Z-Wave Error silently retrying serial connection every 5.0 seconds
2017-12-27 16:36:17.650 Interface Failure lost connection with interface
2017-12-27 16:36:20.302 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodem1431 (firmware 1.00)
2017-12-27 16:36:20.486 Z-Wave found module included in controller with no matching device (missing or disabled): 016 - Dimmable Power Switch
2017-12-27 16:36:20.494 Z-Wave found module included in controller with no matching device (missing or disabled): 019 - General Thermostat (v2)
2017-12-27 16:36:20.666 Z-Wave found module included in controller with no matching device (missing or disabled): 082 - General Thermostat (v2)
2017-12-27 16:36:20.851 Z-Wave found module included in controller with no matching device (missing or disabled): 122 - Remote Control Simple
2017-12-27 16:36:20.885 Z-Wave found module included in controller with no matching device (missing or disabled): 138 - General Thermostat (v2)
2017-12-27 16:38:43.081 Z-Wave Error rcvd packet checksum mismatch: 01 00
2017-12-27 16:38:43.118 Z-Wave Error calculated checksum FF, received 00 (sent NAK)
2017-12-27 16:38:45.582 Z-Wave Error rcvd unexpected bytes (sent ACK): 10 00 04 00 17 0A 32 02 34 00 00 00 00 00 00 D3
2017-12-27 16:38:47.512 Z-Wave Error serial port communication error: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2017-12-27 16:38:47.513 Z-Wave Error silently retrying serial connection every 5.0 seconds
2017-12-27 16:38:47.513 Z-Wave Error Z-Wave 3.95 static controller might be disconnected
2017-12-27 16:38:50.652 Interface Failure lost connection with interface
2017-12-27 16:38:53.077 Z-Wave Error rcvd packet checksum mismatch: 01 00
2017-12-27 16:38:53.079 Z-Wave Error calculated checksum FF, received 00 (sent NAK)
2017-12-27 16:38:53.080 Z-Wave Error calculated checksum FF, received 00 (sent NAK)
2017-12-27 16:38:53.080 Z-Wave Error rcvd packet checksum mismatch: 01 00
2017-12-27 16:38:54.080 Z-Wave Error rcvd unexpected bytes (sent ACK): 09 00 04 00 33 03 20 01 00 E3 01 09 00 04 00 33 03 20 01 00 E3
2017-12-27 16:38:59.127 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodem1431 (firmware 1.00)
2017-12-27 16:38:59.308 Z-Wave found module included in controller with no matching device (missing or disabled): 016 - Dimmable Power Switch
2017-12-27 16:38:59.316 Z-Wave found module included in controller with no matching device (missing or disabled): 019 - General Thermostat (v2)
2017-12-27 16:38:59.472 Z-Wave found module included in controller with no matching device (missing or disabled): 082 - General Thermostat (v2)
2017-12-27 16:38:59.654 Z-Wave found module included in controller with no matching device (missing or disabled): 122 - Remote Control Simple
2017-12-27 16:38:59.688 Z-Wave found module included in controller with no matching device (missing or disabled): 138 - General Thermostat (v2)
2017-12-27 16:39:50.914 Z-Wave Error serial port communication error: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2017-12-27 16:39:50.916 Z-Wave Error silently retrying serial connection every 5.0 seconds
2017-12-27 16:39:50.916 Z-Wave Error Z-Wave 3.95 static controller might be disconnected
2017-12-27 16:39:54.650 Interface Failure lost connection with interface
2017-12-27 16:40:02.218 Z-Wave Error rcvd packet checksum mismatch: 01 00
2017-12-27 16:40:02.219 Z-Wave Error calculated checksum FF, received 00 (sent NAK)
2017-12-27 16:40:07.243 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodem1431 (firmware 1.00)
2017-12-27 16:40:07.437 Z-Wave found module included in controller with no matching device (missing or disabled): 016 - Dimmable Power Switch
2017-12-27 16:40:07.445 Z-Wave found module included in controller with no matching device (missing or disabled): 019 - General Thermostat (v2)
2017-12-27 16:40:07.607 Z-Wave found module included in controller with no matching device (missing or disabled): 082 - General Thermostat (v2)
2017-12-27 16:40:07.786 Z-Wave found module included in controller with no matching device (missing or disabled): 122 - Remote Control Simple
2017-12-27 16:40:07.819 Z-Wave found module included in controller with no matching device (missing or disabled): 138 - General Thermostat (v2)
2017-12-27 16:41:27.832 Z-Wave Error rcvd incomplete interface packet (skipping): 01 08 00 04 00 14 02 84 07
2017-12-27 16:41:28.327 Z-Wave Error rcvd packet checksum mismatch: 01 04 00 14 84 07
2017-12-27 16:41:28.329 Z-Wave Error calculated checksum 6B, received 07 (sent NAK)
2017-12-27 16:41:30.184 Z-Wave Error serial port communication error: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2017-12-27 16:41:30.185 Z-Wave Error Z-Wave 3.95 static controller might be disconnected
2017-12-27 16:41:30.186 Z-Wave Error silently retrying serial connection every 5.0 seconds
2017-12-27 16:41:33.649 Interface Failure lost connection with interface
2017-12-27 16:41:41.842 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodem1431 (firmware 1.00)
2017-12-27 16:41:42.014 Z-Wave found module included in controller with no matching device (missing or disabled): 016 - Dimmable Power Switch
2017-12-27 16:41:42.023 Z-Wave found module included in controller with no matching device (missing or disabled): 019 - General Thermostat (v2)
2017-12-27 16:41:42.179 Z-Wave found module included in controller with no matching device (missing or disabled): 082 - General Thermostat (v2)
2017-12-27 16:41:42.362 Z-Wave found module included in controller with no matching device (missing or disabled): 122 - Remote Control Simple
2017-12-27 16:41:42.398 Z-Wave found module included in controller with no matching device (missing or disabled): 138 - General Thermostat (v2)
2017-12-27 16:42:19.424 Z-Wave Error rcvd unexpected bytes (sent ACK): E8
2017-12-27 16:42:20.421 Z-Wave Error failed to process node 027 awake processing: (device reports readiness to read but returned no data (device disconnected or multiple access on port?))
2017-12-27 16:42:58.993 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodem1431 (firmware 1.00)
2017-12-27 16:42:59.351 Z-Wave found module included in controller with no matching device (missing or disabled): 016 - Dimmable Power Switch
2017-12-27 16:42:59.419 Z-Wave found module included in controller with no matching device (missing or disabled): 019 - General Thermostat (v2)
2017-12-27 16:42:59.828 Z-Wave found module included in controller with no matching device (missing or disabled): 082 - General Thermostat (v2)
2017-12-27 16:43:00.061 Z-Wave found module included in controller with no matching device (missing or disabled): 122 - Remote Control Simple
2017-12-27 16:43:00.121 Z-Wave found module included in controller with no matching device (missing or disabled): 138 - General Thermostat (v2)
2017-12-27 16:43:06.275 Z-Wave Error rcvd unexpected bytes (sent ACK): 00 04 00 15 12 32 02 21 64 00 04 C1 81 02 58 00 04 C1 81 00 00 00 00 CB
2017-12-27 16:43:16.231 Z-Wave Error serial port communication error: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2017-12-27 16:43:16.232 Z-Wave Error Z-Wave 3.95 static controller might be disconnected
2017-12-27 16:43:16.233 Z-Wave Error silently retrying serial connection every 5.0 seconds
2017-12-27 16:43:19.649 Interface Failure lost connection with interface
2017-12-27 16:43:21.292 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodem1431 (firmware 1.00)
2017-12-27 16:43:21.467 Z-Wave found module included in controller with no matching device (missing or disabled): 016 - Dimmable Power Switch
2017-12-27 16:43:21.475 Z-Wave found module included in controller with no matching device (missing or disabled): 019 - General Thermostat (v2)
2017-12-27 16:43:21.632 Z-Wave found module included in controller with no matching device (missing or disabled): 082 - General Thermostat (v2)
2017-12-27 16:43:21.814 Z-Wave found module included in controller with no matching device (missing or disabled): 122 - Remote Control Simple
2017-12-27 16:43:21.846 Z-Wave found module included in controller with no matching device (missing or disabled): 138 - General Thermostat (v2)
2017-12-27 16:44:03.999 Z-Wave Error serial port communication error: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2017-12-27 16:44:04.001 Z-Wave Error silently retrying serial connection every 5.0 seconds
2017-12-27 16:44:04.001 Z-Wave Error Z-Wave 3.95 static controller might be disconnected
2017-12-27 16:44:07.651 Interface Failure lost connection with interface
2017-12-27 16:44:09.941 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodem1431 (firmware 1.00)
2017-12-27 16:44:10.113 Z-Wave found module included in controller with no matching device (missing or disabled): 016 - Dimmable Power Switch
2017-12-27 16:44:10.121 Z-Wave found module included in controller with no matching device (missing or disabled): 019 - General Thermostat (v2)
2017-12-27 16:44:10.281 Z-Wave found module included in controller with no matching device (missing or disabled): 082 - General Thermostat (v2)
2017-12-27 16:44:10.466 Z-Wave found module included in controller with no matching device (missing or disabled): 122 - Remote Control Simple
2017-12-27 16:44:10.499 Z-Wave found module included in controller with no matching device (missing or disabled): 138 - General Thermostat (v2)
2017-12-27 16:44:34.609 Z-Wave Error serial port communication error: read failed: [Errno 6] Device not configured
2017-12-27 16:44:34.610 Z-Wave Error Z-Wave 3.95 static controller might be disconnected
2017-12-27 16:44:34.611 Z-Wave Error silently retrying serial connection every 5.0 seconds
2017-12-27 16:44:37.649 Interface Failure lost connection with interface
2017-12-27 16:44:50.252 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodem1431 (firmware 1.00)
2017-12-27 16:44:50.427 Z-Wave found module included in controller with no matching device (missing or disabled): 016 - Dimmable Power Switch
2017-12-27 16:44:50.435 Z-Wave found module included in controller with no matching device (missing or disabled): 019 - General Thermostat (v2)
2017-12-27 16:44:50.592 Z-Wave found module included in controller with no matching device (missing or disabled): 082 - General Thermostat (v2)
2017-12-27 16:44:50.779 Z-Wave found module included in controller with no matching device (missing or disabled): 122 - Remote Control Simple
2017-12-27 16:44:50.815 Z-Wave found module included in controller with no matching device (missing or disabled): 138 - General Thermostat (v2)
2017-12-27 16:46:33.066 Z-Wave Error serial port communication error: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2017-12-27 16:46:33.068 Z-Wave Error silently retrying serial connection every 5.0 seconds
2017-12-27 16:46:33.068 Z-Wave Error Z-Wave 3.95 static controller might be disconnected
2017-12-27 16:46:36.652 Interface Failure lost connection with interface
2017-12-27 16:46:43.705 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodem1431 (firmware 1.00)
2017-12-27 16:46:43.878 Z-Wave found module included in controller with no matching device (missing or disabled): 016 - Dimmable Power Switch
2017-12-27 16:46:43.886 Z-Wave found module included in controller with no matching device (missing or disabled): 019 - General Thermostat (v2)
2017-12-27 16:46:44.052 Z-Wave found module included in controller with no matching device (missing or disabled): 082 - General Thermostat (v2)
2017-12-27 16:46:44.236 Z-Wave found module included in controller with no matching device (missing or disabled): 122 - Remote Control Simple
2017-12-27 16:46:44.269 Z-Wave found module included in controller with no matching device (missing or disabled): 138 - General Thermostat (v2)
2017-12-27 16:48:17.040 Z-Wave Error rcvd packet checksum mismatch: 01 00
2017-12-27 16:48:17.042 Z-Wave Error calculated checksum FF, received 00 (sent NAK)
2017-12-27 16:48:18.043 Z-Wave Error rcvd unexpected bytes (sent ACK): 21 34 00 00 00 00 00 00 D2 01 10 00 04 00 0A 21 34 00 00 00 00 00 00 D2
2017-12-27 16:49:03.799 Z-Wave Error rcvd incomplete interface packet (skipping): 01 10 00 04 00 18 0A 21 34 00 00 00 00 00 00 DC
2017-12-27 16:49:06.681 Z-Wave Error serial port communication error: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2017-12-27 16:49:06.682 Z-Wave Error Z-Wave 3.95 static controller might be disconnected
2017-12-27 16:49:06.683 Z-Wave Error silently retrying serial connection every 5.0 seconds
2017-12-27 16:49:10.647 Interface Failure lost connection with interface
2017-12-27 16:49:11.811 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodem1431 (firmware 1.00)
2017-12-27 16:49:11.988 Z-Wave found module included in controller with no matching device (missing or disabled): 016 - Dimmable Power Switch
2017-12-27 16:49:11.996 Z-Wave found module included in controller with no matching device (missing or disabled): 019 - General Thermostat (v2)
2017-12-27 16:49:12.189 Z-Wave found module included in controller with no matching device (missing or disabled): 082 - General Thermostat (v2)
2017-12-27 16:49:12.379 Z-Wave found module included in controller with no matching device (missing or disabled): 122 - Remote Control Simple
2017-12-27 16:49:12.412 Z-Wave found module included in controller with no matching device (missing or disabled): 138 - General Thermostat (v2)
2017-12-27 16:49:48.748 Z-Wave Error rcvd packet checksum mismatch: 01 00
2017-12-27 16:49:48.749 Z-Wave Error calculated checksum FF, received 00 (sent NAK)
2017-12-27 16:49:48.801 Z-Wave Error rcvd packet checksum mismatch: 01 01 13
2017-12-27 16:49:48.802 Z-Wave Error calculated checksum FE, received 13 (sent NAK)
2017-12-27 16:49:50.538 Z-Wave Error serial port communication error: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2017-12-27 16:49:50.540 Z-Wave Error silently retrying serial connection every 5.0 seconds
2017-12-27 16:49:50.540 Z-Wave Error Z-Wave 3.95 static controller might be disconnected
2017-12-27 16:49:53.647 Interface Failure lost connection with interface
2017-12-27 16:50:02.602 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodem1431 (firmware 1.00)
2017-12-27 16:50:02.776 Z-Wave found module included in controller with no matching device (missing or disabled): 016 - Dimmable Power Switch
2017-12-27 16:50:02.784 Z-Wave found module included in controller with no matching device (missing or disabled): 019 - General Thermostat (v2)
2017-12-27 16:50:02.941 Z-Wave found module included in controller with no matching device (missing or disabled): 082 - General Thermostat (v2)
2017-12-27 16:50:03.135 Z-Wave found module included in controller with no matching device (missing or disabled): 122 - Remote Control Simple
2017-12-27 16:50:03.176 Z-Wave found module included in controller with no matching device (missing or disabled): 138 - General Thermostat (v2)
2017-12-27 16:51:27.423 Z-Wave Error serial port communication error: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2017-12-27 16:51:27.425 Z-Wave Error silently retrying serial connection every 5.0 seconds
2017-12-27 16:51:27.425 Z-Wave Error Z-Wave 3.95 static controller might be disconnected
2017-12-27 16:51:30.650 Interface Failure lost connection with interface
2017-12-27 16:51:36.646 Application Quitting Indigo Server - received slow quit signal
2017-12-27 16:51:36.653 Application Quitting Indigo Server - stopping plugins
CliveS wrote:I had this problem earlier this month (see http://forums.indigodomo.com/viewtopic.php?f=131&t=19826#p150959) which I think we pinned it down to the Z-Wave devices in the garage being in and out off range. I have added a Fibaro dimmer in the light outside the garage as a repeater and no more loosing devices but I still get sometimes the Z-Wave bar in the bottom left seem to lock for 5-10 seconds randomly.
2017-12-31 16:58:47.624 Z-Wave sent "Bathroom Light" off
2017-12-31 17:00:00.803 Honeywell [EV Zone: Bathroom]: Setting Heat Setpoint to: 18.0
2017-12-31 17:00:04.625 Honeywell [EV Zone: Bedroom 1]: Setting Heat Setpoint to: 16.0
2017-12-31 17:00:07.185 Honeywell [EV Zone: Bedroom 2]: Setting Heat Setpoint to: 12.0
2017-12-31 17:00:10.317 Honeywell [EV Zone: Bedroom 3]: Setting Heat Setpoint to: 12.0
2017-12-31 17:00:11.872 Honeywell [EV Zone: Conservatory]: Setting Heat Setpoint to: 26.0
2017-12-31 17:00:13.653 Honeywell [EV Zone: Dining Room]: Setting Heat Setpoint to: 21.0
2017-12-31 17:00:17.111 Honeywell [EV Zone: En Suite]: Setting Heat Setpoint to: 15.0
2017-12-31 17:00:18.473 Honeywell [EV Zone: Hall-Bedroom]: Setting Heat Setpoint to: 20.0
2017-12-31 17:00:19.787 Honeywell [EV Zone: Hall-Kitchen]: Setting Heat Setpoint to: 20.0
2017-12-31 17:00:21.357 Honeywell [EV Zone: Living Room Door]: Setting Heat Setpoint to: 21.0
2017-12-31 17:00:23.491 Honeywell [EV Zone: Living Room Front]: Setting Heat Setpoint to: 21.0
2017-12-31 17:00:25.798 Sent Hue Lights "Kitchen Hue GU10" on to 100 at ramp rate 0.0 sec.
2017-12-31 17:00:25.832 Sent Hue Lights "Kitchen Hue GU10" on to 100 with RGB values 255, 255 and 255 at ramp rate 0.0 sec.
2017-12-31 17:00:26.013 Honeywell [EV Zone: Utility Room]: Setting Heat Setpoint to: 12.0
2017-12-31 17:00:26.272 Z-Wave sent "Kitchen Spot Lights" set brightness to 100
2017-12-31 17:04:49.610 Z-Wave Error no ack/nak/busy reply (004) for requestRelayStatus (re-sending)
2017-12-31 17:05:16.529 Sent Hue Lights "Kitchen Hue GU10" off at ramp rate 0.0 sec.
2017-12-31 17:05:36.024 Z-Wave Error send requestRelayStatus failed after 9 attempts
2017-12-31 17:05:36.025 Z-Wave Error restarting serial connection in 5.0 seconds
2017-12-31 17:05:39.596 Interface Failure lost connection with interface
2017-12-31 17:06:01.985 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodemFA131 (firmware 1.00)
2017-12-31 17:06:02.157 Z-Wave Error module 028 included in controller no longer matches device "En Suite Floor Heating Thermostat" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwThermostatType (4, 8, 6))
2017-12-31 17:06:02.172 Z-Wave Error module 039 included in controller no longer matches device "039 - Dimmable Load" type (controller module type: zwThermostatType/zwDimmerType (4, 8, 6), indigo device type: zwDimmerType (4, 17, 1))
2017-12-31 17:06:02.209 Z-Wave Error module 085 included in controller no longer matches device "Server Room Repeater Controller Switch" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-31 17:06:02.227 Z-Wave Error module 093 included in controller no longer matches device "Keyfob (FGKF601)" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwCustomType (4, 24, 1))
2017-12-31 17:06:02.241 Z-Wave Error module 094 included in controller no longer matches device ".En Suite Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 24, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-31 17:06:02.258 Z-Wave Error module 099 included in controller no longer matches device "Living Room PST02 Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 24, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-31 17:06:02.337 Z-Wave Error module 113 included in controller no longer matches device "Kitchen PST02 Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-31 17:06:02.421 Z-Wave Error module 120 included in controller no longer matches device ".Bedroom 1 Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwOnOffSensorType (4, 86, 104))
2017-12-31 17:06:02.443 Z-Wave Error module 121 included in controller no longer matches device "121 Door/Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 86, 104), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-31 17:06:02.460 Z-Wave Error module 122 included in controller no longer matches device "Bathroom Neo Motion Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 86, 104), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-31 17:06:02.483 Z-Wave found module included in controller with no matching device (missing or disabled): 124 - Notification Sensor
2017-12-31 17:06:02.525 Z-Wave Error module 135 included in controller no longer matches device "Bedroom 1 Jane WallMote" type (controller module type: zwCustomType/zwCustomType (4, 7, 1), indigo device type: zwCustomType (4, 24, 1))
2017-12-31 17:06:02.547 Z-Wave Error module 136 included in controller no longer matches device ".Utility Room Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 24, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-31 17:06:02.565 Z-Wave Error module 137 included in controller no longer matches device "137 Door/Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 24, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-31 17:06:02.593 Z-Wave Error module 139 included in controller no longer matches device "Motorhome Neo Charger Socket" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-31 17:06:02.628 Z-Wave Error module 142 included in controller no longer matches device ".Conservatory Sliding Door Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-31 17:06:02.671 Z-Wave found module included in controller with no matching device (missing or disabled): 148 - Notification Sensor
2017-12-31 17:06:02.681 Z-Wave Error module 150 included in controller no longer matches device "Bedroom 1 Ceiling Light" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
2017-12-31 17:06:02.713 Z-Wave Error module 151 included in controller no longer matches device "Bathroom Light" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
2017-12-31 17:06:02.753 Z-Wave Error module 153 included in controller no longer matches device "Neo Relay Power Plug - MacBook Air" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-31 17:06:02.773 Z-Wave Error module 155 included in controller no longer matches device ".Bathroom Door Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-31 17:06:02.809 Z-Wave Error module 157 included in controller no longer matches device "Kitchen Spot Lights" type (controller module type: zwRelayType/zwDimmerType (4, 16, 1), indigo device type: zwDimmerType (4, 17, 1))
2017-12-31 17:06:02.836 Ignored device "Bathroom Light" action request (communication is disabled)
2017-12-31 17:06:02.848 Z-Wave Error module 158 included in controller no longer matches device "Kitchen Undercupboard Lights" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
2017-12-31 17:06:02.887 Z-Wave Error module 159 included in controller no longer matches device "Garden Lights" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-31 17:06:02.904 Z-Wave Error module 160 included in controller no longer matches device "Hall Repeater Relay Power Switch" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-31 17:06:02.921 Z-Wave Error module 163 included in controller no longer matches device "163 - Motion Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-31 17:06:02.944 Z-Wave Error module 164 included in controller no longer matches device "Siren" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwRelayType (4, 16, 5))
2017-12-31 17:06:02.970 Z-Wave Error module 166 included in controller no longer matches device "Garage Repeater And Christmas Lights" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-31 17:06:02.986 Z-Wave Error module 167 included in controller no longer matches device "Dining Room Relay Power Switch" type (controller module type: zwRelayType/zwRelayType (4, 16, 5), indigo device type: zwRelayType (4, 16, 1))
2017-12-31 17:06:03.001 Z-Wave found module included in controller with no matching device (missing or disabled): 168 - Relay Power Switch
2017-12-31 17:06:03.009 Z-Wave Error module 169 included in controller no longer matches device "Bathroom Fibaro Motion Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-31 17:06:03.068 Z-Wave Error to re-enable the devices with new z-wave modules, press the "Define and Sync..." button in the device dialog
2017-12-31 17:06:03.134 Ignored device "Bathroom Light" action request (communication is disabled)
2017-12-31 17:06:03.270 Ignored device "Bathroom Light" action request (communication is disabled)
2017-12-31 17:06:04.230 Z-Wave Error could not find module/node for action
2017-12-31 17:06:04.231 Z-Wave Error could not find module/node for action
2017-12-31 17:06:40.023 Z-Wave received "Living Room Twigs" power load to 16.5 W
2017-12-31 17:07:32.981 Ignored device "Kitchen Spot Lights" action request (communication is disabled)
2017-12-31 17:07:32.983 Ignored device "Kitchen Undercupboard Lights" action request (communication is disabled)
2017-12-31 17:07:32.994 Sent Hue Lights "Kitchen Hue GU10" off at ramp rate 0.0 sec.
2017-12-31 17:09:03.109 Trigger Bathroom Lights Off
2017-12-31 17:09:03.296 Ignored device "Bathroom Light" action request (communication is disabled)
2017-12-31 17:09:05.909 Z-Wave device "113 - Relay Power Switch" wake interval changed to 60 minutes
2017-12-31 17:09:09.272 Action Group Kitchen Spot Lights Off
2017-12-31 17:09:09.277 Alexa-Hue Bridge Set on state of Alexa device "Kitchen Lights" to OFF
2017-12-31 17:09:09.470 Ignored device "Kitchen Spot Lights" action request (communication is disabled)
2017-12-31 17:09:09.473 Ignored device "Kitchen Undercupboard Lights" action request (communication is disabled)
2017-12-31 17:09:09.484 Sent Hue Lights "Kitchen Hue GU10" off at ramp rate 0.0 sec.
2017-12-31 17:09:37.859 Action Group Kitchen Spot Lights Off
2017-12-31 17:09:37.864 Alexa-Hue Bridge Set on state of Alexa device "Kitchen Lights" to OFF
2017-12-31 17:09:38.060 Ignored device "Kitchen Spot Lights" action request (communication is disabled)
2017-12-31 17:09:38.062 Ignored device "Kitchen Undercupboard Lights" action request (communication is disabled)
2017-12-31 17:09:38.073 Sent Hue Lights "Kitchen Hue GU10" off at ramp rate 0.0 sec.
2017-12-31 17:09:47.081 Action Group Kitchen Spot Lights Off
2017-12-31 17:09:47.086 Alexa-Hue Bridge Set on state of Alexa device "Kitchen Lights" to OFF
2017-12-31 17:09:47.268 Ignored device "Kitchen Spot Lights" action request (communication is disabled)
2017-12-31 17:09:47.270 Ignored device "Kitchen Undercupboard Lights" action request (communication is disabled)
2017-12-31 17:09:47.286 Sent Hue Lights "Kitchen Hue GU10" off at ramp rate 0.0 sec.
2017-12-31 17:10:40.538 Ignored device "Bathroom Light" action request (communication is disabled)
2017-12-31 17:10:48.889 Ignored device "Bathroom Light" action request (communication is disabled)
2017-12-31 17:10:50.660 Z-Wave sent "Bathroom Light" set brightness to 100
2017-12-31 17:11:16.606 Application Quitting Indigo Server - received slow quit signal
2017-12-31 17:11:16.607 Application Quitting Indigo Server - stopping plugins
2017-12-31 17:11:16.607 Application Stopping plugin "Adapters 1.0.0" (pid 48495)
2017-12-31 17:11:16.607 Application Stopping plugin "Domotics Pad Mobile Client 2.1.1" (pid 48497)
2017-12-31 17:11:16.608 Application Stopping plugin "Z-Wave Lock Manager 1.0.48" (pid 48508)
2017-12-31 17:11:16.608 Application Stopping plugin "Alexa-Hue Bridge 3.0.20" (pid 48496)
2017-12-31 17:11:16.608 Application Stopping plugin "utilities 1.12.7" (pid 48506)
2017-12-31 17:11:16.608 Application Stopping plugin "Group Change Listener 0.0.7" (pid 48498)
2017-12-31 17:11:16.609 Application Stopping plugin "Online Sensor 0.0.10" (pid 48501)
2017-12-31 17:11:16.609 Application Stopping plugin "Timed Devices 0.0.18" (pid 48504)
2017-12-31 17:11:16.609 Application Stopping plugin "Hue Lights 1.6.11" (pid 54178)
31 Dec 2017, 20:00:35
Z-Wave sent "Heating - Upstairs" mode change to off
Z-Wave sent "Heating - Downstairs" mode change to off
Autolog Stella-Z Error WARNING: At least one wakeup has now been missed for 'Bedroom 1 - Heating Control' [Stella-Z]. Wakeup interval is set to 10 minutes; last Z-Wave command processed 11 minutes ago.
Z-Wave Error send "Bedroom 1 - Stella-Z TRV" change heat setpoint failed
31 Dec 2017, 20:01:22
Trigger Motion: Lounge - Motion Detected
Schedule _delayed_action_20042
Schedule _delayed_action_20044
Z-Wave sent "Kitchen - Worktop Counter Lights" off
Z-Wave sent "Kitchen - Main Light" off
Autolog Stella-Z Error WARNING: At least one wakeup has now been missed for 'Dining - Heating Control' [Stella-Z]. Wakeup interval is set to 5 minutes; last Z-Wave command processed 6 minutes ago.
Z-Wave queued "Dining - Stella Z TRV" change heat setpoint to 6.0° for next awake notification
31 Dec 2017, 20:02:09
Autolog Stella-Z Error WARNING: At least one wakeup has now been missed for 'Lounge - Heating Control (Window)' [Stella-Z]. Wakeup interval is set to 5 minutes; last Z-Wave command processed 6 minutes ago.
Z-Wave queued "Lounge - Stella Z TRV (Window)" change heat setpoint to 6.0° for next awake notification
Trigger Motion: Landing - No Motion Detected
Z-Wave sent "Landing - Light" off
Z-Wave sent "Hall - Light" off
Autolog Stella-Z Error WARNING: At least one wakeup has now been missed for 'Lounge - Heating Control (Wall)' [Stella-Z]. Wakeup interval is set to 5 minutes; last Z-Wave command processed 6 minutes ago.
Z-Wave queued "Lounge - Stella Z TRV (Wall)" change heat setpoint to 6.0° for next awake notification
durosity wrote:(Also is it just UK users who are experiencing this issue?)
2017-12-31 21:25:08.015 Z-Wave Debug received "Living Room TV Switch" power load to 378.3 W
2017-12-31 21:25:09.306 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 49 06 31 05 03 0A 00 00 85
2017-12-31 21:25:09.307 Z-Wave Debug . . requestVarSensorStatus: node 073, endpoint None, type 3, raw value 0A00...
2017-12-31 21:25:09.308 Z-Wave Debug . . requestVarSensorStatus: 0 lux (float: 0.000000)
2017-12-31 21:25:09.308 Z-Wave Debug received "Kitchen Fibaro Lux" sensor update to 0 lux
2017-12-31 21:25:11.017 Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 05 0E 32 02 21 34 00 00 0C CE 00 00 00 00 00 00 03
2017-12-31 21:25:11.019 Z-Wave Debug . . requestMeterLevel: node 005, endpoint None, meterType 01, raw value 3400...
2017-12-31 21:25:11.020 Z-Wave Debug . . requestMeterLevel: 327.8 W (float: 327.800000)
2017-12-31 21:25:11.021 Z-Wave Debug received "Living Room TV Switch" power load to 327.8 W
2017-12-31 21:25:14.366 Z-Wave Optimizing - starting "143 - Drive Garage Door Motion"
2017-12-31 21:25:14.370 Z-Wave Debug SENT sendPingZwaveCommand: 01 09 00 13 8F 02 00 00 25 01 4C
2017-12-31 21:25:29.367 Z-Wave Optimizing - ping timeout
2017-12-31 21:25:29.368 Z-Wave Optimizing - skipped "143 - Drive Garage Door Motion" (unreachable)
2017-12-31 21:25:30.373 Z-Wave Optimizing - starting "145 - Living Room Neo Motion"
2017-12-31 21:25:45.379 Z-Wave Optimizing - ping timeout
2017-12-31 21:25:45.381 Z-Wave Optimizing - skipped "145 - Living Room Neo Motion" (unreachable)
2017-12-31 21:26:14.467 Z-Wave Error no ack/nak/busy reply (143) for sendPingZwaveCommand (re-sending)
2017-12-31 21:26:14.469 Z-Wave Debug SENT sendPingZwaveCommand: 01 09 00 13 8F 02 00 00 25 01 4C
2017-12-31 21:26:19.494 Z-Wave Debug SENT sendPingZwaveCommand: 01 09 00 13 8F 02 00 00 25 01 4C (re-sent because no response)
2017-12-31 21:26:24.514 Z-Wave Debug SENT sendPingZwaveCommand: 01 09 00 13 8F 02 00 00 25 01 4C (re-sent because no response)
2017-12-31 21:26:29.531 Z-Wave Debug SENT sendPingZwaveCommand: 01 09 00 13 8F 02 00 00 25 01 4C (re-sent because no response)
2017-12-31 21:26:34.544 Z-Wave Debug SENT sendPingZwaveCommand: 01 09 00 13 8F 02 00 00 25 01 4C (re-sent because no response)
2017-12-31 21:26:39.557 Z-Wave Debug SENT sendPingZwaveCommand: 01 09 00 13 8F 02 00 00 25 01 4C (re-sent because no response)
2017-12-31 21:26:44.568 Z-Wave Debug SENT sendPingZwaveCommand: 01 09 00 13 8F 02 00 00 25 01 4C (re-sent because no response)
2017-12-31 21:26:49.589 Z-Wave Debug SENT sendPingZwaveCommand: 01 09 00 13 8F 02 00 00 25 01 4C (re-sent because no response)
2017-12-31 21:26:54.607 Z-Wave Debug SENT sendPingZwaveCommand: 01 09 00 13 8F 02 00 00 25 01 4C (re-sent because no response)
2017-12-31 21:26:59.629 Z-Wave Debug . . sendPingZwaveCommand: requeuing 11 unsolicited packets
2017-12-31 21:27:00.629 Z-Wave Debug stopping node healing thread
2017-12-31 21:27:00.970 Z-Wave Debug stopping node status polling thread
2017-12-31 21:27:01.971 Z-Wave Debug stopped zwave packet parser thread
2017-12-31 21:27:01.973 Z-Wave Error send sendPingZwaveCommand failed after 9 attempts
2017-12-31 21:27:01.974 Z-Wave Error restarting serial connection in 5.0 seconds
2017-12-31 21:27:05.277 Interface Failure lost connection with interface
2017-12-31 21:27:06.978 Z-Wave Debug starting serial connection loop
2017-12-31 21:27:06.982 Z-Wave Debug starting zwave packet parser thread
2017-12-31 21:27:06.984 Z-Wave Debug SENT getVersion: 01 03 00 15 E9
2017-12-31 21:27:11.998 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because no response)
2017-12-31 21:27:17.005 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because no response)
2017-12-31 21:27:22.016 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because no response)
2017-12-31 21:27:25.451 Z-Wave Debug RCVD getVersion: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.453 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because retransmit request)
2017-12-31 21:27:25.453 Z-Wave Debug RCVD getVersion: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.454 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because retransmit request)
2017-12-31 21:27:25.455 Z-Wave Debug RCVD getVersion: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.455 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because retransmit request)
2017-12-31 21:27:25.456 Z-Wave Debug RCVD getVersion: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.457 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because retransmit request)
2017-12-31 21:27:25.457 Z-Wave Debug RCVD getVersion: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.458 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because retransmit request)
2017-12-31 21:27:25.458 Z-Wave Debug RCVD getVersion: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.459 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because retransmit request)
2017-12-31 21:27:25.460 Z-Wave Debug RCVD getVersion: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.460 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because retransmit request)
2017-12-31 21:27:25.461 Z-Wave Debug RCVD getVersion: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.461 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because retransmit request)
2017-12-31 21:27:25.462 Z-Wave Debug RCVD getVersion: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.463 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because retransmit request)
2017-12-31 21:27:25.463 Z-Wave Debug RCVD getVersion: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.464 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because retransmit request)
2017-12-31 21:27:25.464 Z-Wave Debug RCVD getVersion: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.465 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because retransmit request)
2017-12-31 21:27:25.466 Z-Wave Debug RCVD getVersion: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.466 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because retransmit request)
2017-12-31 21:27:25.467 Z-Wave Debug RCVD getVersion: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.467 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because retransmit request)
2017-12-31 21:27:25.468 Z-Wave Debug RCVD getVersion: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.468 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because retransmit request)
2017-12-31 21:27:25.469 Z-Wave Debug RCVD getVersion: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.470 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because retransmit request)
2017-12-31 21:27:25.470 Z-Wave Debug RCVD getVersion: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.471 Z-Wave Debug SENT getVersion: 01 03 00 15 E9 (re-sent because retransmit request)
2017-12-31 21:27:25.471 Z-Wave Debug RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 33 2E 39 35 00 01 99
2017-12-31 21:27:25.472 Z-Wave Debug . . getVersion: requeuing 13 unsolicited packets
2017-12-31 21:27:25.473 Z-Wave Debug . . getVersion: Z-Wave 3.95 static controller
2017-12-31 21:27:25.473 Z-Wave Debug SENT getHomeID: 01 03 00 20 DC
2017-12-31 21:27:25.474 Z-Wave Debug RCVD getHomeID: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.474 Z-Wave Debug SENT getHomeID: 01 03 00 20 DC (re-sent because retransmit request)
2017-12-31 21:27:25.475 Z-Wave Debug RCVD getHomeID: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.476 Z-Wave Debug SENT getHomeID: 01 03 00 20 DC (re-sent because retransmit request)
2017-12-31 21:27:25.476 Z-Wave Debug RCVD getHomeID: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.477 Z-Wave Debug SENT getHomeID: 01 03 00 20 DC (re-sent because retransmit request)
2017-12-31 21:27:25.477 Z-Wave Debug RCVD getHomeID: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.478 Z-Wave Debug SENT getHomeID: 01 03 00 20 DC (re-sent because retransmit request)
2017-12-31 21:27:25.478 Z-Wave Debug RCVD getHomeID: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.479 Z-Wave Debug SENT getHomeID: 01 03 00 20 DC (re-sent because retransmit request)
2017-12-31 21:27:25.480 Z-Wave Debug RCVD getHomeID: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.480 Z-Wave Debug SENT getHomeID: 01 03 00 20 DC (re-sent because retransmit request)
2017-12-31 21:27:25.481 Z-Wave Debug RCVD getHomeID: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.481 Z-Wave Debug SENT getHomeID: 01 03 00 20 DC (re-sent because retransmit request)
2017-12-31 21:27:25.482 Z-Wave Debug RCVD getHomeID: 01 08 01 20 E0 BB 7F A8 01 5B
2017-12-31 21:27:25.482 Z-Wave Debug . . getHomeID: requeuing 14 unsolicited packets
2017-12-31 21:27:25.483 Z-Wave Debug . . getHomeID: E0BB7FA8, nodeID: 001
2017-12-31 21:27:25.484 Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9
2017-12-31 21:27:25.484 Z-Wave Debug RCVD getInterfaceFeatures: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.485 Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9 (re-sent because retransmit request)
2017-12-31 21:27:25.486 Z-Wave Debug RCVD getInterfaceFeatures: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.486 Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9 (re-sent because retransmit request)
2017-12-31 21:27:25.487 Z-Wave Debug RCVD getInterfaceFeatures: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.487 Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9 (re-sent because retransmit request)
2017-12-31 21:27:25.488 Z-Wave Debug RCVD getInterfaceFeatures: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.489 Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9 (re-sent because retransmit request)
2017-12-31 21:27:25.489 Z-Wave Debug RCVD getInterfaceFeatures: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.490 Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9 (re-sent because retransmit request)
2017-12-31 21:27:25.490 Z-Wave Debug RCVD getInterfaceFeatures: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.491 Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9 (re-sent because retransmit request)
2017-12-31 21:27:25.492 Z-Wave Debug RCVD getInterfaceFeatures: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.492 Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9 (re-sent because retransmit request)
2017-12-31 21:27:25.493 Z-Wave Debug RCVD getInterfaceFeatures: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.494 Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9 (re-sent because retransmit request)
2017-12-31 21:27:25.494 Z-Wave Debug RCVD getInterfaceFeatures: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.495 Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9 (re-sent because retransmit request)
2017-12-31 21:27:25.496 Z-Wave Debug RCVD getInterfaceFeatures: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.496 Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9 (re-sent because retransmit request)
2017-12-31 21:27:25.497 Z-Wave Debug RCVD getInterfaceFeatures: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.498 Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9 (re-sent because retransmit request)
2017-12-31 21:27:25.498 Z-Wave Debug RCVD getInterfaceFeatures: 01 04 01 05 1C E3
2017-12-31 21:27:25.499 Z-Wave Debug . . getInterfaceFeatures: requeuing 16 unsolicited packets
2017-12-31 21:27:25.500 Z-Wave Debug . . getInterfaceFeatures: 1C
2017-12-31 21:27:25.500 Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB
2017-12-31 21:27:25.501 Z-Wave Debug RCVD getInterfaceApiCapabilities: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.501 Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB (re-sent because retransmit request)
2017-12-31 21:27:25.502 Z-Wave Debug RCVD getInterfaceApiCapabilities: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.503 Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB (re-sent because retransmit request)
2017-12-31 21:27:25.503 Z-Wave Debug RCVD getInterfaceApiCapabilities: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.504 Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB (re-sent because retransmit request)
2017-12-31 21:27:25.505 Z-Wave Debug RCVD getInterfaceApiCapabilities: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.505 Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB (re-sent because retransmit request)
2017-12-31 21:27:25.506 Z-Wave Debug RCVD getInterfaceApiCapabilities: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.506 Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB (re-sent because retransmit request)
2017-12-31 21:27:25.507 Z-Wave Debug RCVD getInterfaceApiCapabilities: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.508 Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB (re-sent because retransmit request)
2017-12-31 21:27:25.508 Z-Wave Debug RCVD getInterfaceApiCapabilities: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.509 Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB (re-sent because retransmit request)
2017-12-31 21:27:25.509 Z-Wave Debug RCVD getInterfaceApiCapabilities: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.510 Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB (re-sent because retransmit request)
2017-12-31 21:27:25.510 Z-Wave Debug RCVD getInterfaceApiCapabilities: 01 2B 01 07 01 00 00 86 00 01 00 5A FE 81 FF 88 4F 1F 00 00 FB 9F 7D A0 67 00 00 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00 FB
2017-12-31 21:27:25.511 Z-Wave Debug . . getInterfaceApiCapabilities: requeuing 17 unsolicited packets
2017-12-31 21:27:25.511 Z-Wave Debug . . getInterfaceApiCapabilities: supportedFuncIDs: 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 1C 20 21 22 23 24 27 29 2A 2B 2C 2D 41 42 44 45 46 47 48 49 4A 4B 4C 4D 50 51 53 54 55 56 57 5E 60 61 62 63 66 67 80 90 92 93 98 B4 B6 B7 B8 B9 BA BD BE BF D2 D3 D4 EE EF
2017-12-31 21:27:25.512 Z-Wave Debug . . getInterfaceApiCapabilities: serialApi 1.00, manufactureId 0086, productType 0001, productId 005A
2017-12-31 21:27:25.512 Z-Wave connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodemFA131 (firmware 1.00)
2017-12-31 21:27:25.513 Z-Wave Debug SENT forceSUC: 01 05 00 54 01 01 AE
2017-12-31 21:27:25.513 Z-Wave Debug RCVD forceSUC: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.514 Z-Wave Debug SENT forceSUC: 01 05 00 54 01 01 AE (re-sent because retransmit request)
2017-12-31 21:27:25.514 Z-Wave Debug RCVD forceSUC: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.515 Z-Wave Debug SENT forceSUC: 01 05 00 54 01 01 AE (re-sent because retransmit request)
2017-12-31 21:27:25.515 Z-Wave Debug RCVD forceSUC: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.516 Z-Wave Debug SENT forceSUC: 01 05 00 54 01 01 AE (re-sent because retransmit request)
2017-12-31 21:27:25.522 Z-Wave Debug RCVD forceSUC: 01 04 01 54 01 AF
2017-12-31 21:27:25.523 Z-Wave Debug . . forceSUC: requeuing 18 unsolicited packets
2017-12-31 21:27:25.524 Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE
2017-12-31 21:27:25.524 Z-Wave Debug RCVD getInitialNodeData: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.525 Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE (re-sent because retransmit request)
2017-12-31 21:27:25.525 Z-Wave Debug RCVD getInitialNodeData: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.526 Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE (re-sent because retransmit request)
2017-12-31 21:27:25.526 Z-Wave Debug RCVD getInitialNodeData: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.527 Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE (re-sent because retransmit request)
2017-12-31 21:27:25.645 Z-Wave Debug RCVD getInitialNodeData: 01 25 01 02 05 08 1D B9 00 00 08 40 00 40 00 00 01 10 30 54 00 F9 7B C0 7F EB FD FC 07 00 00 00 00 00 00 00 05 00 D8
2017-12-31 21:27:25.646 Z-Wave Debug . . getInitialNodeData: requeuing 18 unsolicited packets
2017-12-31 21:27:25.647 Z-Wave Debug . . getInitialNodeData: is static update controller
2017-12-31 21:27:25.648 Z-Wave Debug . . getInitialNodeData: [1, 4, 5, 6, 8, 28, 39, 55, 73, 85, 93, 94, 99, 101, 103, 113, 116, 117, 118, 119, 120, 121, 122, 124, 125, 126, 127, 135, 136, 137, 138, 139, 140, 141, 142, 143, 145, 146, 148, 150, 151, 152, 153, 155, 156, 157, 158, 159, 160, 163, 164, 165, 166, 167, 168, 169, 170, 171]
2017-12-31 21:27:25.648 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB
2017-12-31 21:27:25.649 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.650 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB (re-sent because retransmit request)
2017-12-31 21:27:25.650 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.651 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB (re-sent because retransmit request)
2017-12-31 21:27:25.652 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.652 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB (re-sent because retransmit request)
2017-12-31 21:27:25.653 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 93 16 01 02 02 01 33
2017-12-31 21:27:25.653 Z-Wave Debug . . getNodeProtocolInfo: requeuing 20 unsolicited packets
2017-12-31 21:27:25.654 Z-Wave Debug . . getNodeProtocolInfo: node 001, class name: Static Computer Controller
2017-12-31 21:27:25.655 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
2017-12-31 21:27:25.655 Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
2017-12-31 21:27:25.656 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
2017-12-31 21:27:25.657 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.657 Z-Wave Debug . . getNodeProtocolInfo: features: beaming
2017-12-31 21:27:25.658 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 04 BE
2017-12-31 21:27:25.658 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.659 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 04 BE (re-sent because retransmit request)
2017-12-31 21:27:25.660 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 93 16 01 02 02 01 33
2017-12-31 21:27:25.660 Z-Wave Debug . . getNodeProtocolInfo: requeuing 20 unsolicited packets
2017-12-31 21:27:25.661 Z-Wave Debug . . getNodeProtocolInfo: node 004, class name: Static Computer Controller
2017-12-31 21:27:25.661 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
2017-12-31 21:27:25.662 Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
2017-12-31 21:27:25.662 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
2017-12-31 21:27:25.663 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.664 Z-Wave Debug . . getNodeProtocolInfo: features: beaming
2017-12-31 21:27:25.664 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 05 BF
2017-12-31 21:27:25.665 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.665 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 05 BF (re-sent because retransmit request)
2017-12-31 21:27:25.666 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 10 01 ED
2017-12-31 21:27:25.666 Z-Wave Debug . . getNodeProtocolInfo: requeuing 20 unsolicited packets
2017-12-31 21:27:25.667 Z-Wave Debug . . getNodeProtocolInfo: node 005, class name: Relay Power Switch
2017-12-31 21:27:25.667 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
2017-12-31 21:27:25.668 Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
2017-12-31 21:27:25.668 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27
2017-12-31 21:27:25.669 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.669 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:25.673 Z-Wave Debug stopped polling of "005 - Living Room TV Switch"
2017-12-31 21:27:25.674 Z-Wave Debug started polling of "005 - Living Room TV Switch" approx every 3600 seconds
2017-12-31 21:27:25.675 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 06 BC
2017-12-31 21:27:25.676 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.677 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 06 BC (re-sent because retransmit request)
2017-12-31 21:27:25.677 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 10 01 ED
2017-12-31 21:27:25.678 Z-Wave Debug . . getNodeProtocolInfo: requeuing 20 unsolicited packets
2017-12-31 21:27:25.678 Z-Wave Debug . . getNodeProtocolInfo: node 006, class name: Relay Power Switch
2017-12-31 21:27:25.679 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
2017-12-31 21:27:25.680 Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
2017-12-31 21:27:25.680 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27
2017-12-31 21:27:25.681 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.681 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:25.685 Z-Wave Debug stopped polling of "006 - Living Room Display Lights"
2017-12-31 21:27:25.686 Z-Wave Debug started polling of "006 - Living Room Display Lights" approx every 3600 seconds
2017-12-31 21:27:25.687 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 08 B2
2017-12-31 21:27:25.687 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.688 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 08 B2 (re-sent because retransmit request)
2017-12-31 21:27:25.688 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 10 01 ED
2017-12-31 21:27:25.689 Z-Wave Debug . . getNodeProtocolInfo: requeuing 20 unsolicited packets
2017-12-31 21:27:25.690 Z-Wave Debug . . getNodeProtocolInfo: node 008, class name: Relay Power Switch
2017-12-31 21:27:25.690 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
2017-12-31 21:27:25.691 Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
2017-12-31 21:27:25.691 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27
2017-12-31 21:27:25.692 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.692 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:25.696 Z-Wave Debug stopped polling of "008 - Living Room Christmas Tree"
2017-12-31 21:27:25.697 Z-Wave Debug started polling of "008 - Living Room Christmas Tree" approx every 3600 seconds
2017-12-31 21:27:25.698 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1C A6
2017-12-31 21:27:25.698 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.699 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1C A6 (re-sent because retransmit request)
2017-12-31 21:27:25.699 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 10 01 ED
2017-12-31 21:27:25.700 Z-Wave Debug . . getNodeProtocolInfo: requeuing 20 unsolicited packets
2017-12-31 21:27:25.701 Z-Wave Debug . . getNodeProtocolInfo: node 028, class name: Relay Power Switch
2017-12-31 21:27:25.701 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
2017-12-31 21:27:25.702 Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
2017-12-31 21:27:25.702 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27
2017-12-31 21:27:25.703 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.703 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:25.707 Z-Wave Error module 028 included in controller no longer matches device "En Suite Floor Heating Thermostat" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwThermostatType (4, 8, 6))
2017-12-31 21:27:25.716 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 27 9D
2017-12-31 21:27:25.718 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.718 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 27 9D (re-sent because retransmit request)
2017-12-31 21:27:25.719 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 08 06 F2
2017-12-31 21:27:25.720 Z-Wave Debug . . getNodeProtocolInfo: requeuing 20 unsolicited packets
2017-12-31 21:27:25.720 Z-Wave Debug . . getNodeProtocolInfo: node 039, class name: General Thermostat (v2)
2017-12-31 21:27:25.721 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Thermostat : General Thermostat (v2) (04 : 08 : 06)
2017-12-31 21:27:25.721 Z-Wave Debug . . getNodeProtocolInfo: base class command: 40
2017-12-31 21:27:25.722 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 40 72 43 86
2017-12-31 21:27:25.722 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.723 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:25.726 Z-Wave Error module 039 included in controller no longer matches device "039 - Dimmable Load" type (controller module type: zwThermostatType/zwDimmerType (4, 8, 6), indigo device type: zwDimmerType (4, 17, 1))
2017-12-31 21:27:25.737 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 37 8D
2017-12-31 21:27:25.738 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.739 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 37 8D (re-sent because retransmit request)
2017-12-31 21:27:25.740 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 11 01 EC
2017-12-31 21:27:25.740 Z-Wave Debug . . getNodeProtocolInfo: requeuing 20 unsolicited packets
2017-12-31 21:27:25.741 Z-Wave Debug . . getNodeProtocolInfo: node 055, class name: Dimmable Power Switch
2017-12-31 21:27:25.741 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01)
2017-12-31 21:27:25.742 Z-Wave Debug . . getNodeProtocolInfo: base class command: 26
2017-12-31 21:27:25.742 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 26 27
2017-12-31 21:27:25.743 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.743 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:25.747 Z-Wave Error module 055 included in controller no longer matches device "Front Door Keypad Lock" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwLockType (4, 64, 3))
2017-12-31 21:27:25.755 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 49 F3
2017-12-31 21:27:25.756 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.757 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 49 F3 (re-sent because retransmit request)
2017-12-31 21:27:25.758 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 DC 00 04 40 03 7E
2017-12-31 21:27:25.758 Z-Wave Debug . . getNodeProtocolInfo: requeuing 20 unsolicited packets
2017-12-31 21:27:25.759 Z-Wave Debug . . getNodeProtocolInfo: node 073, class name: Keypad Door Lock
2017-12-31 21:27:25.760 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Entry Control : Keypad Door Lock (04 : 40 : 03)
2017-12-31 21:27:25.760 Z-Wave Debug . . getNodeProtocolInfo: base class command: 62
2017-12-31 21:27:25.761 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 62 63 86 72 98
2017-12-31 21:27:25.762 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.762 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming, security, frequentWaking
2017-12-31 21:27:25.765 Z-Wave Debug overriding node 073 type from zwLockType to zwOnOffSensorType
2017-12-31 21:27:25.766 Z-Wave Error module 073 included in controller no longer matches device "Kitchen Fibaro Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 64, 3), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-31 21:27:25.796 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 55 EF
2017-12-31 21:27:25.799 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.800 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 55 EF (re-sent because retransmit request)
2017-12-31 21:27:25.801 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 07 01 7A
2017-12-31 21:27:25.802 Z-Wave Debug . . getNodeProtocolInfo: requeuing 20 unsolicited packets
2017-12-31 21:27:25.803 Z-Wave Debug . . getNodeProtocolInfo: node 085, class name: Notification Sensor
2017-12-31 21:27:25.804 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01)
2017-12-31 21:27:25.804 Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
2017-12-31 21:27:25.805 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
2017-12-31 21:27:25.805 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.806 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:25.811 Z-Wave Error module 085 included in controller no longer matches device "Server Room Repeater Controller Switch" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-31 21:27:25.821 Z-Wave Debug stopped polling of "085 - Server Room Repeater Controller Switch"
2017-12-31 21:27:25.822 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 5D E7
2017-12-31 21:27:25.823 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.824 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 5D E7 (re-sent because retransmit request)
2017-12-31 21:27:25.825 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 10 01 ED
2017-12-31 21:27:25.826 Z-Wave Debug . . getNodeProtocolInfo: requeuing 20 unsolicited packets
2017-12-31 21:27:25.826 Z-Wave Debug . . getNodeProtocolInfo: node 093, class name: Relay Power Switch
2017-12-31 21:27:25.827 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
2017-12-31 21:27:25.828 Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
2017-12-31 21:27:25.828 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27
2017-12-31 21:27:25.829 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.830 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:25.833 Z-Wave Error module 093 included in controller no longer matches device "Keyfob (FGKF601)" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwCustomType (4, 24, 1))
2017-12-31 21:27:25.843 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 5E E4
2017-12-31 21:27:25.845 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 10 01 ED
2017-12-31 21:27:25.846 Z-Wave Debug . . getNodeProtocolInfo: requeuing 20 unsolicited packets
2017-12-31 21:27:25.847 Z-Wave Debug . . getNodeProtocolInfo: node 094, class name: Relay Power Switch
2017-12-31 21:27:25.847 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
2017-12-31 21:27:25.848 Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
2017-12-31 21:27:25.849 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27
2017-12-31 21:27:25.850 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.850 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:25.854 Z-Wave Debug overriding node 094 type from zwRelayType to zwOnOffSensorType
2017-12-31 21:27:25.855 Z-Wave Error module 094 included in controller no longer matches device ".En Suite Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2017-12-31 21:27:25.864 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 63 D9
2017-12-31 21:27:25.866 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.868 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 63 D9 (re-sent because retransmit request)
2017-12-31 21:27:25.870 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.871 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 63 D9 (re-sent because retransmit request)
2017-12-31 21:27:25.872 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 07 01 7A
2017-12-31 21:27:25.872 Z-Wave Debug . . getNodeProtocolInfo: requeuing 21 unsolicited packets
2017-12-31 21:27:25.873 Z-Wave Debug . . getNodeProtocolInfo: node 099, class name: Notification Sensor
2017-12-31 21:27:25.874 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01)
2017-12-31 21:27:25.875 Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
2017-12-31 21:27:25.875 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
2017-12-31 21:27:25.876 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.877 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:25.883 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 65 DF
2017-12-31 21:27:25.885 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 07 01 7A
2017-12-31 21:27:25.886 Z-Wave Debug . . getNodeProtocolInfo: requeuing 22 unsolicited packets
2017-12-31 21:27:25.887 Z-Wave Debug . . getNodeProtocolInfo: node 101, class name: Notification Sensor
2017-12-31 21:27:25.887 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01)
2017-12-31 21:27:25.888 Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
2017-12-31 21:27:25.889 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
2017-12-31 21:27:25.890 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.890 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:25.897 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 67 DD
2017-12-31 21:27:25.899 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.900 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 67 DD (re-sent because retransmit request)
2017-12-31 21:27:25.901 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 07 01 7A
2017-12-31 21:27:25.901 Z-Wave Debug . . getNodeProtocolInfo: requeuing 22 unsolicited packets
2017-12-31 21:27:25.902 Z-Wave Debug . . getNodeProtocolInfo: node 103, class name: Notification Sensor
2017-12-31 21:27:25.903 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01)
2017-12-31 21:27:25.903 Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
2017-12-31 21:27:25.904 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
2017-12-31 21:27:25.905 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.905 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:25.910 Z-Wave Debug overriding node 103 type from zwOnOffSensorType to zwRelayType
2017-12-31 21:27:25.911 Z-Wave Error module 103 included in controller no longer matches device "En Suite Floor Heating Switch" type (controller module type: zwRelayType/zwRelayType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2017-12-31 21:27:25.928 Z-Wave Debug stopped polling of "103 - En Suite Floor Heating Switch"
2017-12-31 21:27:25.930 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 71 CB
2017-12-31 21:27:25.931 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 07 01 7A
2017-12-31 21:27:25.932 Z-Wave Debug . . getNodeProtocolInfo: requeuing 22 unsolicited packets
2017-12-31 21:27:25.933 Z-Wave Debug . . getNodeProtocolInfo: node 113, class name: Notification Sensor
2017-12-31 21:27:25.933 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01)
2017-12-31 21:27:25.934 Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
2017-12-31 21:27:25.934 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
2017-12-31 21:27:25.935 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.936 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:25.941 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 74 CE
2017-12-31 21:27:25.943 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.944 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 74 CE (re-sent because retransmit request)
2017-12-31 21:27:25.945 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.945 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 74 CE (re-sent because retransmit request)
2017-12-31 21:27:25.946 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 07 01 7A
2017-12-31 21:27:25.947 Z-Wave Debug . . getNodeProtocolInfo: requeuing 24 unsolicited packets
2017-12-31 21:27:25.947 Z-Wave Debug . . getNodeProtocolInfo: node 116, class name: Notification Sensor
2017-12-31 21:27:25.948 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01)
2017-12-31 21:27:25.948 Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
2017-12-31 21:27:25.949 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
2017-12-31 21:27:25.949 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.950 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:25.955 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 75 CF
2017-12-31 21:27:25.956 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 07 01 7A
2017-12-31 21:27:25.957 Z-Wave Debug . . getNodeProtocolInfo: requeuing 24 unsolicited packets
2017-12-31 21:27:25.957 Z-Wave Debug . . getNodeProtocolInfo: node 117, class name: Notification Sensor
2017-12-31 21:27:25.958 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01)
2017-12-31 21:27:25.959 Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
2017-12-31 21:27:25.959 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
2017-12-31 21:27:25.960 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.961 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:25.966 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 76 CC
2017-12-31 21:27:25.967 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.968 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 76 CC (re-sent because retransmit request)
2017-12-31 21:27:25.969 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.970 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 76 CC (re-sent because retransmit request)
2017-12-31 21:27:25.971 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 07 01 7A
2017-12-31 21:27:25.971 Z-Wave Debug . . getNodeProtocolInfo: requeuing 24 unsolicited packets
2017-12-31 21:27:25.972 Z-Wave Debug . . getNodeProtocolInfo: node 118, class name: Notification Sensor
2017-12-31 21:27:25.972 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01)
2017-12-31 21:27:25.973 Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
2017-12-31 21:27:25.973 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
2017-12-31 21:27:25.974 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.975 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:25.979 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 77 CD
2017-12-31 21:27:25.980 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 07 01 7A
2017-12-31 21:27:25.981 Z-Wave Debug . . getNodeProtocolInfo: requeuing 24 unsolicited packets
2017-12-31 21:27:25.982 Z-Wave Debug . . getNodeProtocolInfo: node 119, class name: Notification Sensor
2017-12-31 21:27:25.982 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01)
2017-12-31 21:27:25.983 Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
2017-12-31 21:27:25.984 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
2017-12-31 21:27:25.984 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.985 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:25.989 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 78 C2
2017-12-31 21:27:25.991 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.991 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 78 C2 (re-sent because retransmit request)
2017-12-31 21:27:25.992 Z-Wave Debug RCVD getNodeProtocolInfo: 18 (RETRANSMIT REQUEST)
2017-12-31 21:27:25.993 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 78 C2 (re-sent because retransmit request)
2017-12-31 21:27:25.993 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 07 01 7A
2017-12-31 21:27:25.994 Z-Wave Debug . . getNodeProtocolInfo: requeuing 24 unsolicited packets
2017-12-31 21:27:25.995 Z-Wave Debug . . getNodeProtocolInfo: node 120, class name: Notification Sensor
2017-12-31 21:27:25.996 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01)
2017-12-31 21:27:25.997 Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
2017-12-31 21:27:25.997 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
2017-12-31 21:27:25.998 Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
2017-12-31 21:27:25.999 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2017-12-31 21:27:26.003 Z-Wave Error module 120 included in controller no longer matches device ".Bedroom 1 Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwOnOffSensorType (4, 86, 104))
2017-12-31 21:27:26.013 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 79 C3
2017-12-31 21:27:26.015 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 05 04 56 68 46
