Z-Uno ZUNO_METER
Wed Dec 27, 2017 6:50 pm
rom1011 offline
Z-Uno ZUNO_METER
I created a 2 channel water flow meter using ZUno but I don't get any values reported back to Indigo as I do not see any device state with either one of the two devices that get created.
Inclusion seems to work fine.
This is my ZUno configuration
ZUNO_SETUP_CHANNELS(ZUNO_METER(ZUNO_METER_TYPE_WATER, METER_RESET_ENABLE, ZUNO_METER_WATER_SCALE_GALLONS, METER_SIZE_FOUR_BYTES, METER_PRECISION_ZERO_DECIMALS, getterIndoor, resetterIndoor),
                    ZUNO_METER(ZUNO_METER_TYPE_WATER, METER_RESET_ENABLE, ZUNO_METER_WATER_SCALE_GALLONS, METER_SIZE_FOUR_BYTES, METER_PRECISION_ZERO_DECIMALS, getterOutdoor, resetterOutdoor));
   Z-Wave                          Syncing - started for "052 - Meter"
   Z-Wave                          Syncing - retrieved module neighbors list: 4
   Z-Wave                          Syncing - assigning return route to "052 - Meter"
   Z-Wave                          Syncing - retrieved manufacture and model names: Duwi - 0115, Simple Meter - 01100001
   Z-Wave                          Syncing - retrieved protocol version 4.38, app version 2.11
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Meter : Simple Meter (04 : 31 : 01, base 32)
   Z-Wave                          Syncing - retrieved command classes: 20v1 60v4 85v1 86v1 72v1 8Ev1 70v1 32v4 73v1 59v1 7Av1 5Av1 5Ev1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, beaming
   Z-Wave                          Syncing - retrieved multi-endpoint types: 1:(31 : 01), 2:(31 : 01)
   Z-Wave                          Syncing - retrieved multi-endpoint classes: 1:[32], 2:[32]
   Z-Wave                          Syncing - retrieved group 1 associations: [1]
   Z-Wave                          Syncing - group 1 association to interface already exists (skipping)
Mon Jan 22, 2018 12:06 pm
rom1011 offline
Re: Z-Uno ZUNO_METER
Is there a formal way to request support for new devices in Indigo?
Mon Jan 22, 2018 12:29 pm
Use the Submit Device Info button in the device config dialog. That adds it to a list on our side. If the button doesn't show, then there's already some level of support.
