Heiman HS2SK-Z UK 240V Smart Plug
Sat Dec 02, 2017 9:36 am
CliveS offline
Just got 2 of these from eBay at £22.49 each but with buy one get 1 half price they are £16.87 each and 1st class postage free!
https://www.ebay.co.uk/itm/Heiman-HS2SK-Z-Smart-Plug-White-/253260185417
Much smaller than the TKB TZ69E/TZ88E @ £35.95 plus P+P and fractionally bigger than the Aeotec Smart Switch 6 @ £60.00 plus P+P
Heiman UK Power Switch.jpg (62.63 KiB) Viewed 3911 times
Sync and Properties
2 Dec 2017, 14:24:35
   Z-Wave                          started controller inclusion mode
2 Dec 2017, 14:24:53
   Z-Wave                          controller included module: 159 - Relay Power Switch
   Z-Wave                          stopped controller inclusion mode
   Z-Wave                          Syncing - started for "159 - Relay Power Switch"
   Z-Wave                          Syncing - retrieved module neighbors list: 8, 150, 151, 153, 157, 158
   Z-Wave                          Syncing - assigning return route to "159 - Relay Power Switch"
   Z-Wave                          Syncing - retrieved manufacture and model names: Heiman - 0260, Relay Power Switch - 80061000
   Z-Wave                          Syncing - retrieved protocol version 4.34, app version 1.01
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
   Z-Wave                          Syncing - retrieved command classes: 20v1 25v1 86v1 27v1 72v1 32v4 73v1 59v1 5Av1 5Ev1 85v1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, beaming
   Z-Wave                          Syncing - retrieved group 1 associations: []
   Z-Wave                          Syncing - added group 1 association to interface
   Z-Wave                          Syncing - created device "159 - Relay Power Switch"
   SQL Logger                      creating table device_history_177144225 for "159 - Relay Power Switch"
   SQL Logger                      adding column "accumenergytimedelta" to table device_history_177144225 ("159 - Relay Power Switch")
   SQL Logger                      adding column "accumenergytotal" to table device_history_177144225 ("159 - Relay Power Switch")
   SQL Logger                      adding column "curenergylevel" to table device_history_177144225 ("159 - Relay Power Switch")
2 Dec 2017, 14:25:23
   Z-Wave                          Indigo Device "159 - Relay Power Switch" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.111
Node ID: 159
Model: Relay Power Switch
Model ID: 80061000
Manufacturer: Heiman
Manufacturer ID: 0260
Protocol Version: 4.34
Application Version: 1.01
Model Definition Version: 0
Library Type: 6
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 25v1 86v1 27v1 72v1 32v4 73v1 59v1 5Av1 5Ev1 85v1
Features: routing, beaming, energyMeter
Neighbors: 8, 150, 151, 153, 157, 158
Associations: 1:[1]
Config Values: - none -
   Z-Wave                          received "159 - Relay Power Switch" energy total to 16.9 kWh
   SQL Logger                      adding column "accumenergytimedelta_ui" to table device_history_177144225 ("159 - Relay Power Switch")
   SQL Logger                      modifying column "accumenergytotal" type of table device_history_177144225 ("159 - Relay Power Switch") from integer to REAL
   SQL Logger                      adding column "accumenergytotal_ui" to table device_history_177144225 ("159 - Relay Power Switch")
2 Dec 2017, 14:25:58
   Z-Wave                          sent "159 - Relay Power Switch" on
   Z-Wave                          sent "159 - Relay Power Switch" off
   Z-Wave                          sent "159 - Relay Power Switch" status request
   Z-Wave                          sent "159 - Relay Power Switch" energy status request
   Z-Wave                          sent "159 - Relay Power Switch" energy usage reset
   Z-Wave                          received "159 - Relay Power Switch" energy total to 0.0 kWh
2 Dec 2017, 14:26:47
2 Dec 2017, 14:27:31
   Enabling plugin "Z-Wave Sensor Logger 1.0.27"
   Starting plugin "Z-Wave Sensor Logger 1.0.27" (pid 14596)
   Started plugin "Z-Wave Sensor Logger 1.0.27"
   Z-Wave Sensor Logger Debug      startup called
2 Dec 2017, 14:29:10
   Z-Wave Sensor Logger Debug      -----
   Z-Wave Sensor Logger Debug      Raw command: 01 15 00 04 00 9F 0F 32 02 21 54 00 00 00 00 00 00 00 00 00 00 00 3B
   Z-Wave Sensor Logger Debug      Scale2: 0, Rate: 01, Meter: 00001, DP: 010, Scale1: 10, ScaleT: 010, ByteLength: 100
   Z-Wave Sensor Logger Debug      Bitmask: 0b10000101010100, Scale2: 0, Rate: 1, Meter: 1, DP: 2, Scale1: 10, ScaleT: 2, ByteLength: 4
   Z-Wave Sensor Logger Debug      Power Reported: 0.0 w
   Z-Wave Sensor Logger            Power Reported: 0.0 w
2 Dec 2017, 14:29:30
   Z-Wave Sensor Logger Debug      Raw command: 01 15 00 04 00 9F 0F 32 02 21 24 00 00 00 00 00 00 00 00 00 00 00 4B
   Z-Wave Sensor Logger Debug      Scale2: 0, Rate: 01, Meter: 00001, DP: 001, Scale1: 00, ScaleT: 000, ByteLength: 100
   Z-Wave Sensor Logger Debug      Bitmask: 0b10000100100100, Scale2: 0, Rate: 1, Meter: 1, DP: 1, Scale1: 00, ScaleT: 0, ByteLength: 4
   Z-Wave Sensor Logger Debug      Energy Reported: 0.0 kWh
   Z-Wave Sensor Logger            Energy Reported: 0.0 kWh
2 Dec 2017, 15:13:33
   Z-Wave                          received "159 - Relay Power Switch" power load to 65.83 W
   Z-Wave Sensor Logger Debug      Raw command: 01 15 00 04 00 9F 0F 32 02 21 54 00 00 19 B7 00 00 00 00 00 00 00 95
   Z-Wave Sensor Logger Debug      Power Reported: 65.83 w
   Z-Wave Sensor Logger            Power Reported: 65.83 w
   Z-Wave Sensor Logger            Debug logging disabled
   Model  Smart Metering Plug HS2SK-Z-UK
   Working Voltage   AC220V (full voltage)
   Av power consumption  ≤0.5W
   Power Range  <3000W
   Voltage Range   100~240VAC
   Current Range   <13A
   Networking  Z-Wave Ad-Hoc Network
   Networking Distance  ≤100m (in open area)
   Working Environment  -10℃~+50℃
   Environment Humidity  Maximum 95%RH
   Dimension  79.6*67.9*62.8mm
CliveS
Sat Dec 02, 2017 1:19 pm
Re: Heiman HS2SK-Z UK 240V Smart Plug
Thanks for the details. Is it working well with Indigo?
Sat Dec 02, 2017 2:11 pm
CliveS offline
Yes they both respond correctly to On/Off, they are the first devices I have seen that don't have any Configuration Parameters and so "Modify Configuration Parameters" does not have their device numbers in the pull down list.
Heiman Device Details.png (33.02 KiB) Viewed 3876 times
The only thing missing at present is the tick box to hide status and energy messages and I can't get round that like I did with the TBK TZ69E as their are no config parameters to modify so I am getting every 30 seconds
2 Dec 2017, 19:53:28
Z-Wave received "Garden Lights" power load to 9.91 W
2 Dec 2017, 19:54:08
Z-Wave received "Garden Lights" power load to 10.49 W
2 Dec 2017, 19:55:28
Z-Wave received "Garden Lights" power load to 10.41 W
2 Dec 2017, 19:56:08
Z-Wave received "Garden Lights" power load to 10.13 W
But I ( patiently ) wait for 7.1.2 ;)
CliveS
Tue Dec 05, 2017 8:20 am
siclark offline
Thanks for this. I'm keen and happy without the parameters for some use cases but definitely don't want my log bombarded by all those energy updates. Hopefully there is a way to exclude in indigo of you can't turn off on the device
Tue Dec 05, 2017 9:49 am
CliveS offline
I am very impressed with them, I just ordered another 2 but until 7.1.2 arrives hopefully with a tick box to hide energy and status messages I will just use them as gen5 repeaters as 4 of them plus the HeatiT thermostat blasting out messages every few seconds (even when it has a hide temp tick box that does not work) it could get congested in the log department!
I just wish for an incoming log filter to be added, that would be well received by many I am sure.
CliveS
Tue Dec 05, 2017 11:58 am
siclark offline
Cheers. Have no need for a repeater yet and yes, already have a qubino relay that blasts power updates every 10 seconds so don't fancy more. Might wait for a sale again then get them and wait for 7.1.2
Sat Dec 09, 2017 12:28 pm
We will definitely get the Hide status and energy message broadcasts in Event Log checkbox added for this module to a future Indigo release.
Sat Dec 09, 2017 12:44 pm
CliveS offline
Thanks Matt :)
CliveS
Sun Feb 18, 2018 3:03 pm
siclark offline
If anyone else considering these, whilst they work well as on / off switches, and seem to report power reasonably well, if not over frequently, see above, the energy reporting is pretty flakey . A shame a the main reason I am bought one of them.
Fri Sep 28, 2018 1:14 pm
Indigo 7.2.0 is now available for download and will now show the Hide status and energy message broadcasts option.
Fri Sep 28, 2018 1:51 pm
CliveS offline
Just Sync'ed 3 plugs and get
Heiman Power Plug.jpg (434.3 KiB) Viewed 3058 times
CliveS
Fri Sep 28, 2018 1:53 pm
Exclude, re-include, and re-sync again. The log is showing that they are reporting a manufacturer and model ID of 0 (or not reporting back at all).
Fri Sep 28, 2018 2:02 pm
CliveS offline
That sorted it :) , all working and it does now show the Hide status and energy message broadcasts option.
Thanks Matt
CliveS
Fri Dec 14, 2018 5:04 am
degreecy offline
Does anyone know where you can buy these still ? I am struggling to find a reasonably priced z-wave plug !
Fri Dec 14, 2018 5:36 am
CliveS offline
Having got a few of these I tried to find some more but I have now moved to the Neo UK sockets at £26.60 each, not as cheap as the Heiman but smaller and reliable.
Have a look at my post about the Neo's at https://forums.indigodomo.com/viewtopic.php?f=58&t=21327
Take note that Neo also do a cheaper WiFi version that you do NOT want.
The only place that is selling them is AliExpress at present (shipping time usually 12-20 days but with Christmas could be longer) and you can see them at https://www.aliexpress.com/item/-/32919175421.html?spm=a2g0s.8937460.0.0.5ad82e0enypHgz
If you do order from them put a note with the order that it is for UK frequency and UK 240v Socket, seems obvious to us but you could end up with the Euro version !!
CliveS
