Change Philio PST02-1A to report in Centigrade
Tue Nov 28, 2017 12:12 pm
joesan offline
How do I change the temperature measurement unit in this sensor? Anyone know? I can't see anything in the instruction sheet that accompanied it.
(PS I bought this while I wait for the guys to add a definition for the Zipato multisensor. I can confirm that the Zipato and the Philio appear to be exactly the same units.)
Tue Nov 28, 2017 9:01 pm
Re: Change Philio PST02-1A to report in Centigrade
Inside the device settings for the module try changing the Operation Flags edit field to 16. Set to 0 to go back to °F.
Wed Nov 29, 2017 4:07 pm
joesan offline
Thanks Matt but I can't see any parameter called Opertation Flags. Here's what I can see when choosing "Edit Device Settings..."
Am I missing something?
Philio Device Settings.jpeg (148.26 KiB) Viewed 1266 times
Wed Nov 29, 2017 7:07 pm
Try scrolling that view in the window up a bit. The Operation Flags should be immediately after the Battery Interval.
Thu Nov 30, 2017 7:11 am
johnpolasek offline
If all else fails, you can always use the Adapters Plugin (http://forums.indigodomo.com/viewtopic.php?f=134&t=15793) to convert it yourself and then display the variable.
Thu Nov 30, 2017 8:56 am
CliveS offline
On my 2 x PST02's I have them set to 8 for Centigrade, 16 gives me Farenheight.
30 Nov 2017, 12:26:21
Z-Wave device "113 - Kitchen PST02 Motion Sensor" parameter 5 "Operation flags" changed to 16
30 Nov 2017, 12:26:47
Z-Wave received ".Kitchen PST02 - NOT USED - Temperature" units changed to °F
30 Nov 2017, 13:27:40
Z-Wave device "113 - Kitchen PST02 Motion Sensor" parameter 5 "Operation flags" changed to 8
30 Nov 2017, 13:36:22
Z-Wave received ".Kitchen PST02 - NOT USED - Temperature" units changed to °C
CliveS
Sat Dec 02, 2017 11:32 am
joesan offline
Thanks folks. Just confirming that Clive's parameter is the one that did the trick. Reporting nicely in centigrade now.
Users browsing this forum: No registered users and 26 guests
