Hi!
I just bought a GE EZ Smart Motion Sensor, gambling that it would work with Indigo. I can include in and get it to sync. It will report the battery level. It won't do anything else. Indigo is not able to get any motion sensing messages from the sensor, so at the moment, it is not particularly useful as a motion sensor. I chose this sensor because it was small (a cube about 1.5 inches square), battery powered, and inexpensive at just $28.
I did submit the info via the handy form that is available via the "Edit Device Settings" box. I'm running Indigo 7.1.1.
The device information from the log is also here:
Z-Wave Indigo Device "Z-Wave - Motion Sensor - Laundry Room" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.111
Node ID: 38
Model: Notification Sensor
Model ID: 49533133
Manufacturer: General Electric
Manufacturer ID: 0063
Protocol Version: 4.24
Application Version: 5.25
Model Definition Version: 0
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 71v1 72v1 73v1 59v1 7Av1 5Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 1, 4, 11, 13, 14, 16, 18, 21, 24, 27, 34
Associations: 1:[1]
Config Values: - none -
--Pete
