- Posted on
Sat Nov 25, 2017 3:25 pm
matt (support)
offline
- Site Admin
The increase/decrease UI in the main window and Indigo Touch always perform 1°C (or 1°F) increments. However, you can specify half degree deltas when executing the heat setpoint command, as well as when you create actions using the increase/decrease heat setpoint action types. So you could, for example, create a custom Control Page that has UP and DOWN controls that increment/decrement in 0.5 °C deltas.
I agree using 0.5° C deltas in the default UI and Indigo Touch device UI would be better. Not all hardware supports half degree setpoints though, so improving that will require some changes to a lot of Indigo's device definitions.
