Anyone tried an EZMultiPli Z-Wave Multi-Sensor, Plug-In?
Thu Nov 23, 2017 7:03 am
Professor Falken offline
Was thinking about ordering one of these for use in my attic and crawlspace. Wondering if anyone had experience syncing with Indigo. This would be my first foray into Z-wave, as I've mainly lived in the Insteon ecosystem.
https://www.amazon.com/EZMultiPli-Z-Wav ... 00Q3OR0CI/
Thu Nov 23, 2017 9:37 am
Different Computers offline
Re: Anyone tried an EZMultiPli Z-Wave Multi-Sensor, Plug-In?
If you don't care about the night light feature, this Monoprice sensor does all the same stuff and is known to work with Indigo. But it's not a plug in device, it's battery powered.
I could see why you would want something mains powered in the attic.
Thu Nov 23, 2017 2:21 pm
We have definitions for 2 different iterations of this device. If this one doesn't work it might not be a big effort to get it working. But we won't know for sure until someone tries it.
Fri Nov 24, 2017 5:25 am
Yes, I like the idea of having it plugged in. But I'm not opposed to going with one of the battery options (Monoprice, Aeotec) if this one won't play nice.
I went ahead and ordered one. Will report back once I have given it a try. I'm looking forward adding some z-wave to my system.
Tue Nov 28, 2017 8:23 pm
After getting a z-wave network up and running, I attempted to add this device in.
The device setting box says Indigo doesn't have a definition for the device.
Here is the log report with device details:
Nov 28, 2017, 9:19:37 PM
Z-Wave Indigo Device "Crawlspace Multisensor" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.68
Node ID: 2
Model: Notification Sensor
Model ID: 00040001
Manufacturer: Express Controls
Manufacturer ID: 001E
Protocol Version: 4.54
Application Version: 1.10
Model Definition Version: 0
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 33v1 85v1 86v1 71v1 70v1 31v6 72v1 73v1 77v1 59v1 5Av1 7Av1 5Ev1
Features: routing, beaming
Neighbors: - none -
Associations: 1:[1] 2:[]
Config Values: - none -
Tue Nov 28, 2017 8:57 pm
That is apparently the same modules as the HomeSeer HSM200 sensor. Indigo currently supports the HSM100, but not yet the 200. I'm adding it to our module request list and we will look into it.
Sun May 12, 2019 3:45 pm
Indigo 7.3 (and 7.3.1) are now available and should support the Express Controls Multisensor (EZMultipli).
