Fibaro smoke alarms/detectors
Wed Nov 22, 2017 6:04 am
Asconasny offline
Hi.
i have several Fibaro smoke alarms, and having issues with false alarms. which is kinda annoying.
Whole house goes in to survival mode :)
I cant find any reason why it sets of, and when Indigo receives the ON command, the siren on the fibaro does not set off. No fire alarm on the fibaro unit.
I know they work properly, when testing it with "smoke spray" the siren goes off.
Anyone else having similar issues?
2017-11-22 12:38:23.597   DEBUG   RCVD sensorSetLevel: 01 09 00 04 00 48 03 20 01 FF 67
2017-11-22 12:38:23.597   DEBUG   . .  sensorSetLevel: node 072, endpoint None, cmdClass 20, value 255
2017-11-22 12:38:23.597   INFO   received "Branndetektor - Skap Gang" status update is on
2017-10-23 01:42:29.706   DEBUG   RCVD sensorSetLevel: 01 09 00 04 10 41 03 20 01 FF 7E
2017-10-23 01:42:29.706   DEBUG   . .  sensorSetLevel: node 065, endpoint None, cmdClass 20, value 255
2017-10-23 01:42:29.706   INFO   received "Branndetektor - Yttergang" status update is on
Wed Nov 22, 2017 11:47 am
Re: Fibaro smoke alarms/detectors
Can you resync the module in Indigo (you might have to wake it for the sync to succeed) and copy/paste the Event Log window results in a reply for me? I'd like to see how it is configured.
Wed Nov 22, 2017 2:24 pm
Asconasny offline
Heres the sync.
   Z-Wave                          Syncing - started for "Branndetektor - Skap Gang"
   Z-Wave                          Syncing - retrieved module neighbors list: 3, 4, 5, 10, 11, 12, 13, 15, 16, 17, 19, 20, 23, 24, 30, 31, 32, 35, 47, 48, 49, 50, 51, 58, 59, 69, 70, 71
   Z-Wave                          Syncing - assigning return route to "072 - Branndetektor - Skap Gang"
   Z-Wave                          Syncing - retrieved manufacture and model names: Fibaro System - 010F, Smoke Sensor (FGSD002) - 0C021002
   Z-Wave                          Syncing - retrieved protocol version 4.05, app version 3.03
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
   Z-Wave                          Syncing - retrieved command classes: 20v1 80v1 22v1 84v2 85v1 86v1 71v1 8Ev1 70v1 31v8 72v1 73v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, battery, beaming, security, waking
   Z-Wave                          Syncing - retrieved wake interval of 720 minutes
   Z-Wave                          Syncing - device "072 - Branndetektor - Skap Gang" wake interval changed to 720 minutes
   Z-Wave                          Syncing - retrieved group 1 associations: [1]
   Z-Wave                          Syncing - retrieved group 2 associations: [1]
   Z-Wave                          Syncing - retrieved group 3 associations: []
   Z-Wave                          Syncing - retrieved group 4 associations: []
   Z-Wave                          Syncing - retrieved group 5 associations: [1]
   Z-Wave                          Syncing - group 1 association to interface already exists (skipping)
   Z-Wave                          Syncing - group 2 association to interface already exists (skipping)
   Z-Wave                          Syncing - group 5 association to interface already exists (skipping)
   Z-Wave                          Syncing - retrieved parameter 2 "Notification flags" is 3
   Z-Wave                          Syncing - retrieved parameter 10 "Group 2 command type" is 0
   Z-Wave                          Syncing - retrieved parameter 11 "Group 2 command value" is 255
   Z-Wave                          Syncing - retrieved parameter 1 "Smoke sensitivity" is 3 "Low"
   Z-Wave                          Syncing - retrieved parameter 3 "Visual alerts" is 0 "Disabled"
   Z-Wave                          Syncing - retrieved parameter 4 "Audible alerts" is 0 "Disabled"
   Z-Wave                          Syncing - retrieved parameter 20 "Temperature interval" is 1 * 10 seconds
   Z-Wave                          Syncing - retrieved parameter 21 "Temperature sensitivity" is 10 * 0.1°C
   Z-Wave                          Syncing - retrieved parameter 30 "Temperature threshold" is 70 °C
   Z-Wave                          Syncing - retrieved parameter 31 "Temperature alarm" is 1 "10 Seconds"
   Z-Wave                          Syncing - retrieved battery level of 100%
Syncing - started for "Branndetektor - Yttergang"
   Z-Wave                          Syncing - retrieved module neighbors list: 3, 5, 10, 17, 19, 20, 23, 30, 31, 32, 35, 48, 49, 51, 58, 59
   Z-Wave                          Syncing - assigning return route to "065 - Branndetektor - Yttergang"
   Z-Wave                          Syncing - retrieved wake interval of 240 minutes
   Z-Wave                          Syncing - device "065 - Branndetektor - Yttergang" wake interval changed to 240 minutes
   Z-Wave                          Syncing - retrieved parameter 30 "Temperature threshold" is 65 °C
Hope this is any help
Wed Nov 22, 2017 7:26 pm
That all looks good to me.
Is there any pattern as to when the errors occur? There are 3 basic "something happened" commands I think that module sends: smoke detection, tamper alert, and temperature alert. Could it possibly be one of the latter two? Looks like your temp threshold is 65 °C, which I would be very surprised if it got to (unless the sensor is malfunctioning).
Users browsing this forum: No registered users and 32 guests
