Zipato Multisensor Quad reports only battery level
Sun Nov 19, 2017 9:35 am
joesan offline
I've just bought a Zipato Multisensor Quad. I strongly suspect that this is the exact same item as the Philio PST02-A/B/C (which is definable and usable in Indigo).
At the moment I've included it to Indigo and it reports only battery level reporting. Also, when I move the magnet near the sensor it reports the battery level update ie the device is communicating with Indigo.
Is there any way to force Indigo to define this as the Philio PST02-A/B/C so that I can use the sensor functions?
Sun Nov 19, 2017 11:36 am
Re: Zipato Multisensor Quad reports only battery level
Re-sync it in Indigo and copy/paste the Event Log results into a reply for me so we can see how it identifies itself. There isn't a way to force it to use a different definition, but if it just needs a Philio definition then we'll get it added to the next bug fix release.
Sun Nov 19, 2017 12:33 pm
joesan offline
Thanks Matt. That would be a great help!
Here's the log from my sync this afternoon:
19 Nov 2017 at 15:05:56
Z-Wave started controller inclusion mode with encryption
Z-Wave controller included module: 006 - Notification Sensor
Z-Wave querying module for encryption support
Z-Wave starting encryption key exchange with module
Z-Wave completed encryption key exchange with module
Z-Wave stopped controller inclusion mode
Z-Wave received "01 Meter Total" power load to 266.733 W
Z-Wave received "01 Meter Total" energy total to 909.425 kWh
Z-Wave stopping controller inclusion mode
Z-Wave Syncing - started for "006 - Notification Sensor"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 5
Z-Wave Syncing - assigning return route to "006 - Notification Sensor"
Z-Wave received "Clamp 1" power load to 271.738 W
Z-Wave Syncing - retrieved manufacture and model names: Zipato - 0131, Notification Sensor - 0002000C
Z-Wave Syncing - retrieved protocol version 4.05, app version 1.24
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 8Fv1 98v1 59v1 5Av1 5Ev1 20v1 70v1 71v1 30v1 31v5 72v1 73v1 7Av1
Z-Wave Syncing - retrieved encrypt commands: 80 30 84 85 31 70 71
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, security, waking
Z-Wave Syncing - retrieved wake interval of 1440 minutes
Z-Wave Syncing - device "006 - Notification Sensor" wake interval changed to 60 minutes
Z-Wave received "Clamp 1" energy total to 909.425 kWh
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - created device "006 - Notification Sensor"
SQL Logger creating table device_history_554264348 for "006 - Notification Sensor"
Z-Wave Syncing - complete
SQL Logger adding column "batterylevel" to table device_history_554264348 ("006 - Notification Sensor")
SQL Logger adding column "batterylevel_ui" to table device_history_554264348 ("006 - Notification Sensor")
Z-Wave received "006 - Notification Sensor" status update battery level 100%
Wed Nov 22, 2017 3:32 pm
Got it. It does look just like the Philio. We'll get it added to 7.1.2.
Wed Jan 17, 2018 5:46 am
joesan offline
Just wondering if this definition was available yet?
Wed Jan 17, 2018 11:53 am
No, 7.1.2 is not yet available. We don't have an ETA for it yet, but it will include the new definition you need.
Wed Jan 17, 2018 1:13 pm
joesan offline
Fair enough Matt. Something to look forward to!
Users browsing this forum: No registered users and 64 guests
