Why do non-battery devices not Ack all the time?
Sat Nov 18, 2017 1:40 pm
trevorsmith offline
I have a heating relay (a Hortsmann Channel Boiler Actuator (SSR303 / ASR-ZW)) which usually works fine to turn my heating on and off. It is a mains-powered device (ie no batteries). However, now and then it fails to respond to Indigo's request to switch on.....the log shows
send "CH Relay" mode change to heat failed
and a quick look on the Indigo UI shows it as not responding with an Ack.
I thought that mains-powered ZWave devices would not "time-out" like this, as they have no batteries to conserve. Am I incorrect?
Sat Nov 18, 2017 2:12 pm
Re: Why do non-battery devices not Ack all the time?
I believe that you're correct, but I don't think that's what's going on.
I had a couple of old "Home Manageables" dimmer modules that would periodically no ack on me. I'd wake up in the morning and one string of over-cabinet lights would be on. Had to unplug and replug the device to get it to respond. Since replacing those two units with Aeon Smart Dimmer 6 modules, I have had zero problems. In fact, the only problem I've had recently is where the HVAC guy unplugged a multi sensor in the attic and failed to plug it back in.
Sat Nov 18, 2017 3:14 pm
autolog offline
This device has to be kept awake by sending it a command every hour otherwise it drops into fail-safe mode i.e. off.
You need a script that says something like: if it is off, turn it off else turn it on. Run this on a schedule every 55 minutes. :)
For more details, see this post: http://forums.indigodomo.com/viewtopic.php?f=58&t=10911&p=73900&hilit=ssr303#p73900
Sun Nov 19, 2017 2:43 am
trevorsmith offline
Thanks guys. I am already doing that every 10 mins or so, but I had forgotten that I had, at some point in testing, disabled the check throughout the night......I've removed that so will see later if that sorts it.
Thanks again.
Users browsing this forum: No registered users and 62 guests
